Drivetrain What happens when the FPR vacuum line comes off?
Old Oct 24, 2006 | 10:23 AM
TampaMCS's Avatar
TampaMCS
While driving around yesterday I saw my boost guage drop to 0psi and would not move.
I pulled over to discover the line going to the FPR (Fuel Pressure Regulator) had blown off, the factory boost guage is spliced in between here.
I drove the short >1mile back to my house and zip tied the hose tight on the regulator.
I was just curious if anyone knew what effect a disconnected FPR would have? I didnt see any check engine lights or feel any negative effects but not to say the thing wasnt running lean as could be either.
Old Oct 24, 2006 | 10:26 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I lost this line once, and the car went into limp mode (scarily, in traffic). It restarted but with the SES light on. I eventually discovered it, but it was intermittent until found. I don't think it -hurt- the car meanwhile.
cheers,
Old Oct 24, 2006 | 10:28 AM
spillman's Avatar
spillman
Your FPR will vary the fuel pressure depending on absolute pressure. I believe it is on a 1:1. However as long as you are not going 100% throttle and your car is warmed up you will be in closed loop. And you will be reading off you o2 sensors and your computer will correct for a disconnected FPR.
However if you go boosting then you are going to go way lean.
Old Oct 24, 2006 | 10:58 AM
TampaMCS's Avatar
TampaMCS
Cooll, I kinda thought that was the case, just wanted to know what it would do just for knowledge sake.
Doc Pain
Mar 10, 2021 04:50 AM
gar56
Nov 15, 2016 06:41 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
krohm
Sep 28, 2015 12:16 PM
EVMini
Sep 28, 2015 10:20 AM
