Drivetrain re-ring
Old Oct 23, 2006 | 05:50 PM
herbie hind's Avatar
herbie hind
re-ring
who's got enough miles on to start thinkin' what's gonna happen come time to re-ring? due to the coating on the bores i'm thinkin' we gotta re-sleeve? can we hone these cylinders? re-sleeving would suck.:impatient 66000mls. and counting.
Old Oct 23, 2006 | 07:00 PM
spillman's Avatar
spillman
I have 72000mls on stock sleeves stock crank and stock rods. The cylinders can be bored to .20 over. I currently only have 10% leak down.
Old Oct 23, 2006 | 08:12 PM
ScottRiqui's Avatar
ScottRiqui
The cylinders can be re-coated after an overbore, although overboring coated cylinders is rarely necessary. Nikasil and the similar coatings are amazingly durable, short of a catastrophic engine failure. I've seen 200,000-mile engines where you could still see the cross-hatch pattern from the bores being honed at the factory.
Old Oct 24, 2006 | 05:33 AM
stevecars60's Avatar
stevecars60
Yes, you see this with early 911s more often than not. I've seen 320k. The car wore. The cylinders? At that point I diden't look.
If the bores are good, don't touch them.
Old Oct 24, 2006 | 06:57 AM
BFG9000's Avatar
BFG9000
No Nikasil coating in an iron block...
Old Oct 24, 2006 | 08:30 AM
gelstudios's Avatar
gelstudios
the block is coated? from what i understand the piston skirts are moly-coated.
Old Oct 24, 2006 | 08:34 AM
Dr Obnxs's Avatar
Dr Obnxs
While the miles are high....
if you aren't leaking, don't worry. Motors last a lot longer than they used to....
Matt
Old Oct 24, 2006 | 01:22 PM
herbie hind
yeah i gotta test it soon . as i may be getting some blow bye . well that's a load off. just check tolerances and pop on another set ; that's awsome. i was wondering where the hell i was gonna find some one to re-sleeve or re-coat this thing .
Old Oct 24, 2006 | 02:10 PM
stevecars60
Seems like low mileage for ring time
I was not aware of any coatings on any internals......
Hey, if the cylinders a straight, be sure to check the bores carefully ( with a bore gauge ), run a scuff hone through the bores, so the new rings seat properly & re ring.
Do Not Try - Unless you know what you are doing:
It's best to remove the motor have the block cooked & cleaned.You need to remove the rods, so why not remove the block too? Put some new bearings in, balence the crank, flywheel, rods, basicly bluprint the bottom end ( by the way the front pulley, fly wheel & clutch assy will be balenced together ). These operations are good bang for the buck. Aftermarket pistons might be worth a thought or 2 for future mods.....
Old Oct 25, 2006 | 01:18 PM
herbie hind
yep there is a super duper wear forever coating on the cyl. walls .what it is is in earlier post. i'd love to balance all of it but it's my daily. so likely i'll be just keeping it going till i gotta do a major. i've decided to keep the car for sure. but i've also decided that when my kids are out of college i'll be picking up a classic. that's when i'll do a major. unless she breaks prior to .
Old Oct 25, 2006 | 01:37 PM
stevecars60
Dont ever use the word BREAK ( bad carma ), the Mini motor is pretty durable. If you do a leak down post the #s, I'll bet it's still in spec
Old Oct 25, 2006 | 04:04 PM
herbie hind
too funny okay i'll post um
redmist
May 9, 2013 09:15 PM
