Drivetrain Time for new spark plugs -- Denso question.
Torque values for NGK are listed here and Densos here. Note that you should not trust a torque wrench set to less than 20% of its maximum value.
OEM plugs are NGK BKR6EQUPK as seen in the bottom pic here.
Did anyone ever figure out if the correct NGK plug is BKR6EIX-11 or the ZFR6FIX-11 suggested by the NGK website? I mean one heat range colder than stock should be ZFR7FIX-11, not BKR7EIX-11 if going by their listing, but the OEM number suggests it should be BKR7EIX.
I'm in need of new plugs for my '03 MCS, and I'm searching for the correct NGK like you mentioned. If I go on NGK's website they say the ZFR6FIX-11 is the correct plug for the MCS. If I go to some online stores and use their parts finder they recommend the BKR7EIX-11. Can anyone shed light on what should be used on a bone-stock MCS?
ZFR6FIX-11 is the stock heat range for the MINI, and factory-gapped at 0.044".
BKR7EIX-11 is one stage cooler than stock plugs, and factory-gapped at 0.030".
Seems that you should be using ZFR6FIX-11 if you're looking for OEM replacement plugs.
I've had my Denso IK22's for just over a year now and I want to change them. I was thinking about going down to IK24's or the equivalent NGK plugs. I haven't had any problems with my Denso's so I think I'm going to stick with those. However, would anyone advise AGAINST stepping down a heat range to IK24's. My mods are listed in my sig. I live in Miami wheres it gets REALLY hot... TIA
Are there any drawbacks going with colder plugs in the northern states? Should be fine for summer, what about winter?
It would do this badly until the car was properly warmed up in anything less then 35 degrees.
Now that I live in Tennessee I have been running the colder plugs in the cooler weather. The car will still stumble a bit when starting from sitting for more then 4 hours. However it will only do it first heavy throttle. Not after that.
With my stock plugs this behavior is rare but still there to a much much lesser extent. Supposedly an ecu update will fix this but I have to see that.
I have another question along with what prime was stating. I'm going to change out my plugs soon, because I feel that I should be running colder. My mods will include intake, pulley, and header, including a cat-back later on. Should I run one step colder (NGK BKR7EIX)?
I live in Ohio, where winters are harsh, and last winter I had several very bad times where the MINI just didn't want to start, and ran very rough until the engine was warm. Would running one step colder improve or hurt this?
Thanks!
-Cody
Thanks!
-Cody
Thanks!
-Cody
Thanks!
-Cody
).I was planning on the Denso IK22s when I get pullied based on my perception that they were the plugs of choice from people's sigs, but if the NGKs are as good or better option, I'll be happy to save a few bucks.
Just to verify, the NGK part #s listed above (BKR7EIX for 1 step colder and BKR8EIX for 2 steps colder) are gapped correctly for the MCS out of the box?
Alta seemed to recommend one step colder for a 17% reduction and 2 steps colder for 19% in their Q&A thread. Are there any potential long term negatives (aside from possibly some issues w/ cold starting) to running two steps colder w/o the 19%? Seems like colder would be better...
TIA
Given the mods I will have, should I run one step or two steps colder? Every now and then, I'll hear and feel my MINI stumbling at a light, like it putts....almost as it wants to stall, but it doesn't. Is this due to the timing retard on my plugs? Would running colder plugs help with this? BTW: This has been happening on and off for about a year with the OEM plugs, with a M7 16% pulley and ALTA intake.
Thanks,
-Cody
Thanks,
-Cody
I believe the idea of the colder plugs is to offset the effects of the additional heat from the faster rotation of the SC and added boost, but I'm no mechanical engineer so I couldn't say for sure...
I switched back from two ranges colder to one range in January of this year.
Car simply ran better.
Also, went to NGK for greater durabilty over the Densos.
Have to say that if I weren't doing track events on hot days here in the South, I'd want to try the stock range again, just to see what happens.
Might anyway...
Might anyway...
I was running the Denso IK22 for the last year or so. Recently experiencing slightly harder starting than usual. Felt it was time for new plugs. I picked up NGK ZFR6FIX-11 (OEM match) at Summit Racing because they didn't have the next step colder available. Have to say the MINI starts up much faster now, but they are new so it should. I was a little concerned that the insulator/firing end was a little longer than the Denso's I removed but had nothing to compare against for the OEM length.
btw, the NGK website has a nice technical article on the spark plug and what colder plugs do.
OEM in red (realOEM.com)
Cooper:
NGK BKR6EQUP Platinum+4, NGK BKP6EIX Iridium 0.030 gap
one heat range colder: NGK BKP7EIX Iridium 0.030 gap
CooperS:
NGK BKR6EQUP Platinum+4, NGK ZFR6FIX-11 (also BKR6EIX-11?) Iridium 0.044 gap; Denso IK20
one heat range colder: NGK BKR7EIX-11 Iridium 0.044 gap (no valid ZFR7FIX-11 part#), Denso IK22
JCW CooperS: NGK BKR7EQUP Platinum+4, NGK BKR7EIX-11 Iridium 0.044 gap, Denso IK22
one heat range colder: NGK BKR8EIX-11 Iridium 0.044 gap; Denso IK24
(these of course do not include R56 MINIs, or other vendors)
09R56
Nov 16, 2022 10:49 AM
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
