Drivetrain How to get 80% thermal efficiency from the stock IC & scoop
Old Jul 18, 2007 | 07:41 AM
  #76
Dr Obnxs's Avatar
Dr Obnxs
Yep...
but I guess it's not stock anymore!
Matt
Old Mar 13, 2011 | 05:22 PM
  #77
louisut's Avatar
louisut
I followed the how-to on insulating my intercooler today and I just wanted to update the thread on where to get supplies. I got the Thermo-tec tape (the sticky aluminized glass mat) from Amazon. Summit Racing also still sells it, but for a few bucks more. It comes in sheets too, though the tape worked well. Make sure to use gloves when cutting the strips; it's just as irritating as fiberglass insulation.
For the silicone foam (for the top and bottom), I picked up a 5-pack of 9" x 9" x 1/4" sheets from ebay. It's also known as silicone sponge. Mine is made by 3M and is supposedly good up to 800 F. 1/4" was just the right thickness.
I only used a little more than half a sheet, which means I have four new sheets still available. If you're interested, I'll send you a sheet for $4 plus postage (prob ~$6 total). I'm not looking to make any money, just want to cover my cost.
I'm planning to take a look at the scoop next. The seal between the hood and the IC cover looked fine; there are marks on the cover where it rubs the foam. There is a gap between the cover and the hood scoop. Maybe something like a garage door seal would work. Until next weekend...
Originally Posted by inimmini
The stock scoop & IC work reasonably well. Various figures have been reported for thermal efficiency of the stock set-up (i.e., [Tin-Tout]/[Tin-Tamb], so that at 100% efficiency the outlet temp = ambient). These range from 55% to 70%, and mostly sit around the low 60's. My own tests have shown 55% to 68%, which is in line with what others have measured.
To do better than stock, paying $500-$800 for a bigger IC seems to be the rule. I could find a thermal efficiency posted for only one after maket IC, the M7 DFIC, at 71%. You can do better than this, for less than $50 and a bit of time! Follow these steps to get a reliable TE of around 80%:
Insulate the IC
That's right - the IC has many surfaces exposed to hot air from the engine, not exposed to cold flowing air. These include the front and back, and the bottom surfaces of the channels (between the fins, facing the engine). I think many of the after market ICs really suffer from heat absorption, especially those that extend back over the spark plugs. I'll go out on a limb and say that the main benefit of the M7 DFIC is relative immunity from engine heat, due to its horizontal orientation. You can do just as well, though, with some insulation on the stock IC.
Here is a pic of my IC with the ends insulated with silicone foam, and the bottom insulated with self-stick woven glass fiber with reflective aluminum (not great for reducing heat conduction, but good for radiant heat transfer).
https://www.northamericanmotoring.co...=&ppuser=16996
I've also insulated the inlet manifold from the radiator hose and the SC exit horn. These are very hot items, and close to the air inlet manifold. Although the IC outlet air temps are not directly affected by the downstream intake manifold, it just seemed like the right thing to do, and very easy as well.
Make a better IC diverter
The stock diverter, as many have attested, could use some improvements. It doesn't use the air from the right side of the scoop, it has only one fin to divert the air downwards, it leaves gaps on the left and right sides of the IC, as well as a big gap between it and scoop. You could buy the Alta version, or make you own that is probably better. Here is mine. It has 2 fins, and additional foam to prevent leakage. I've left the stock foam "U" in place. As you can see, my diverter extends much farther forward than than stock piece, so it can meet up with the scoop (more this later).
To get the diverter to mate up well with the scoop, I found I had to remove the two front IC mounting brackets. These hold the diverter up too high, so if extended it runs into the scoop instead of under it. Here is a pic of the IC on the car. If you look closely at the far left side, you can see a black "undermount" bracket I made, so that the IC is at least held on 3 of the 4 corners:
Open up the stock "mailbox slot", and eliminate the scoop - diverter gap
The stock scoop has two pieces - the outer painted part, and a black plastic inner piece. The bottom section of the inner piece forms an overly narrow slot, and also interferes with extending the diverter forward to eliminate the gap. Cut the bottom of the inner scoop off, like this:
https://www.northamericanmotoring.co...0&ppuser=16996
This probably gives at least 20% more area for flow. Next, glue some rubber strips on the bottom of the painted outer scoop, so they extend over your diverter. Here are the rubber strips I glued on:
Since the rubber is black, you can't see them from the outside. The scoop looks totally normal. The idea is to have the scoop and the diverter mate up like this drawing tries to show, so that the engine can move back and forth without opening up a gap:
If you do all this, what do you get?
Here is some data I logged today, under a variety of conditions. I forgot to mention in the table that ambient temp ranged from 60 to 62 F, so I used 61 F for the calcs. The best TEs are found during acceleration, probably because the thermal mass of the IC helps cool the inlet air during these brief periods. Averaging just the cruising values, though, gives 79.9% TE .
If you do nothing else, take the first step and insulate the IC. I did the diverter/scoop mod first, but adding the insulation makes a noticeable in the seat-of-the-pants, particularly after idling the engine a while.
Also keep in mind, I have no OCC! So there is still room for some small improvement!
Old Apr 30, 2011 | 10:55 PM
  #78
mini_racer's Avatar
mini_racer
Thanks for the freshening up on this thread. The Al backed glass fiber tape is eas to find on Amazon, but I did not find the silicon foam you mentioned on Ebay. So, if you have any more ideas......
Colt45Magnus
Aug 27, 2024 05:03 AM
embiggenedmini
Oct 15, 2015 12:36 PM
Swaan
Sep 8, 2015 07:46 AM
Sep 2, 2015 11:15 AM
MiniSMan
Sep 1, 2015 06:49 PM
