Drivetrain OBX header... how good or bad
Old Sep 28, 2006 | 06:49 AM
  #51
Wake|MCS's Avatar
Wake|MCS
Originally Posted by MSFITOY
So...since OBX is cat-less, has anyone run without the cat and what do you do with the post cat O2 sensor? Is it even possible to run without a cat?
Yes you can run without a cat. The only thing you need is an o2 simulator of some sort. Theres the electrical ones which you need to splice/solder wires and are known to sometimes not work. And there are the "mechanical" ones, it is simply a spacer on the o2 bung so that the o2 sensor isn't as far in to the exhaust and it doesn't get a complete reading, in turn the ECU doesn't sense that the car is cat-less. Theres a thread about it somewhere on NAM...
Old Sep 28, 2006 | 09:25 AM
  #52
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by 02///MCS
... And there are the "mechanical" ones, it is simply a spacer on the o2 bung so that the o2 sensor isn't as far in to the exhaust and it doesn't get a complete reading, in turn the ECU doesn't sense that the car is cat-less...
I think this is how they work: o2 sensors detect temperature and turn it into an electrical current, or modify an electrical current based on temperature. With a cat, the temperature/current should be different before and after the cat, and the ECU expects this differential. If you run without a cat and don't want SES lights you need to "fool" the ECU with a false differential. This can be provided by the simulator chip, or by moving the sensor far enough out of the exhaust stream to produce sufficient temperature differential.
or not...
Old Sep 28, 2006 | 11:48 AM
  #53
bomboasy's Avatar
bomboasy
Msfitoy,
The first link below has some really good pictures and lots of comments about it. Enjoy.
http://www.ssrfanatic.com/forum/showthread.php?t=7208
http://www.hardcars.com/headerman/dodge/exhaust.jpg
Old Sep 28, 2006 | 12:23 PM
  #54
MSFITOY's Avatar
MSFITOY
Originally Posted by bomboasy
Msfitoy,
The first link below has some rally good pictures and lots of comments about it. Enjoy.
Thanks bomboasy
Finhead
105
Aug 14, 2023 07:51 AM
Kimolaoha
Dec 5, 2020 09:32 PM
woodstudio
Mar 15, 2020 08:28 AM
minipopkart
Aug 13, 2015 05:22 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
