Drivetrain OBX header... how good or bad
Originally Posted by 34Mini
I am running the OBX header on the stock cat attached to the M7 pipes and I really like the combo. Sounds great! However, there is no flex joint in the header and it did not come with a donut gasket. I went and got one, installed it, but I did have a heck of a time getting a rattle eliminated... It would buzz from like 2800-3k rpm. I had to install some longer bolts and stronger springs on the flange. Worked like a champ.
Originally Posted by Dr Obnxs
on "thermal barrier coating" in your favorite search engine..... You can often find local companies that will do it for you.
Matt
Matt
http://www.hpcoatings.com/services/pricelist.aspx
Looks like it would cost about $150-200...
I can comment on this
Originally Posted by SpiderX
can anyone say definitively the gauge of steel used and is the plate stainless?
I just installed mine on Sunday, all my bolts fit with no interference with the runners. I had slightly chamfered all bolt holes on outside face of flange.
From past experience this solves the PITA problem of getting the header bolts started when the runners are close.
I had posted pictures of the OBX header before and after cleaning up the ports then having it Jet-Hot coated inside and out.
Installed an OBD2 compliant Magnaflow CAT 2.5" in/out connected to a 2.5 inch Magnaflow CAT back.
This morning I got on it a bit, man is the mid range improved, really woke it up!
Backpressure, who needs backpressure...
Originally Posted by norm03s
The OBX is all stainless steel, pipe is 16 gauge, most SS are, whereas the better mild steel headers are 14 Ga., the flange is actually thicker than the OEM flange but I didn't measure that just an observation.
About backpressure, Webb doesn't seem to think it's necessary with his 3" Exhaust which makes more HP AND TQ than any exhaust on the market, both closed AND open valve. Not to mention the future release of a Header with a 3" Downpipe... As for me, I care more about Top End power than Low End so I couldn't care less for backpressure, hehe...
Originally Posted by 02///MCS
I'm really between the OBX and Megan Headers because of the price. Has the problems with bolt holes lining up with the OBX been fixed? Or is that more of an indepent problem varying from header to header?
Why is it so hard to communicate with text?
There is no problem with the flange drilling of the holes, they are spot on.
You can check it with a new OEM header gasket laid up against the flange.
The MINI sure has MINI exhaust ports so the header provides a generous step to prevent reversion.
I'm talking about exhaust ports and headers here wasn't that clear?
Why don't you start a new thread if you want to talk about intake ports and report back here. How about that!
Your right of course
Originally Posted by dmh
Sorry, I think you took that the wrong way. No harm intended here. They are related is what I was trying to say. The exhaust actually can travel up past the intake port and into the intake manifold.
Yes I know that from first hand experience with carbureted air cooled VW engines.
It would amaze some to know that reversion without a balance port or tube between intake ports depending on crank shaft configuration and Cam shaft overlap will cause a gas cloud up to 4 inches above the top just (remembered it's termed fuel standoff) of a single/2 barrel carb feeding both cylinder banks, or twin single barrel carbs each feeding 2 cylinders each or Dell'Orto/Weber carbs with one Venturi per cylinder.
Also that you want to have a step on the intake, but in this location the intake port must be larger than the intake runner. Reversion pulses pass all the way into the intake manifold. These fundamentals apply to all piston engines regardless of aspiration technique.
So now I'm way off topic.
Here's what it takes...
But I'd say that going catless is only appropriate for a track car..... And that the thrown code won't change how the car runs....
Matt
Yes...of course of course...I will also obey the speed limit and never waste fuel with lead foot accelerations...of course...
I was at the Blackhawk auto museum..
they have Clark Gables Duesenburg. It has an exhuast cut out that could be done with a manual lever on the floor of the car. You can't see it during normal tours, but if you go to special events there, you can get close enough to the car to see it, just hangin there, for all (that are close enough) to see!
Cut outs have been around for a long, long, time!
Matt
Matt
