Drivetrain MINI Mania Short Shift Kit
Old Apr 3, 2003 | 08:54 AM
0wen0's Avatar
0wen0
OK, I know they just put this up on their site today. What do you all think of this?
http://new.minimania.com/NewMiniSear...p;ShowIcons=No
Old Apr 3, 2003 | 11:12 AM
6f7's Avatar
6f7
I would really like to get this. However, I'm a little hesitant until I hear that the dust cover does not need to be modified (like the alta kit).
Old Apr 3, 2003 | 11:31 AM
0wen0's Avatar
0wen0
I think the description mentions that you can leave the stock dust cover or use the one that comes with the kit.
Owen
Old Apr 3, 2003 | 12:57 PM
kenatminimania's Avatar
kenatminimania
>>Owen
Owen, the stock dust cover can be 'left off' as an alternative to modifying it. The shifter box area is well protected from the elements via the heat shield that runs the length of the center tunnel. Some have chosen to leave the cover off. (The stock dust cover is not 100% sealed from the elements, it is simply a 'clip on' piece.)
Our dust cover attaches to the stock cover after some trimming - this is necessary to accommodate the increased length of the shifter rod and the resulting greater throw. For those concerned about weatherproofing the box, we include a tube of silicone sealant to finish the job.
Ken
Old Apr 3, 2003 | 01:52 PM
MiniPilo's Avatar
MiniPilo
For the same **** movement with the alta, you would need to modify the box, if you want to stay at around 10% less, then the alta doesn't need to be modified, but to get a real short shift, you need to modify the cover with the alta as well
Old Apr 3, 2003 | 02:37 PM
0wen0's Avatar
0wen0
...be nice, it's not that bad
Old Apr 3, 2003 | 02:39 PM
0wen0's Avatar
0wen0
Thanks for the clarification, Ken. Guess I needed to re-read the description.
Owen
Old Apr 4, 2003 | 06:43 AM
'*Ace*''s Avatar
'*Ace*'
Does the shift boot need to be trimmed or anything? I just think that if you kept the stock one on, it might get in the way. Am I worng? I want this kit too!
chrisx18240
26
Mar 16, 2022 09:56 AM
andrewjg1994
Jan 29, 2021 07:45 PM
Toolman
Jan 20, 2016 06:50 AM
wheresaldo
Oct 23, 2015 10:17 AM
