Drivetrain Megan header installed. Power loss
Old Aug 28, 2006 | 04:39 PM
coloradomini's Avatar
coloradomini
I have a stock 04S JCW. I installed a Mini Madness CAI. Worked great power was up noticable. Last night I installed a Plio / megan header powder coated with the test pipe provided. Power seems way down. No snap at 5,000 rpms any more just lots of noise. Anyone have any thoughts?
Old Aug 28, 2006 | 05:35 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
That is weird...
It should not make a huge difference, but it should help...
Old Aug 28, 2006 | 05:50 PM
ThumperMCS's Avatar
ThumperMCS
Power lost??? Hmm, the second I drove my car after the header was installed it was very noticeable. Midrange torque added is significant.
Old Aug 28, 2006 | 06:29 PM
kyriian's Avatar
kyriian
did you have a test pipe or a cat? because chances are if you have a race pipe, the power loss below 6k is understandable.... car will ONLY start feeling powerful beyond that point in a straight through exhaust....
otherwise... no idea... i have my obx in and since i've enjoyed more spirited mid-range... and an awesome sound!
Old Aug 28, 2006 | 07:04 PM
TampaMCS's Avatar
TampaMCS
yep, put a cat in it...You do need some backpressure to keep torque up down low....
Old Aug 28, 2006 | 07:56 PM
nypepper's Avatar
nypepper
did you check for leaks
Old Sep 7, 2006 | 09:51 PM
coloradomini
Okay got it figured out went over to my dealer today and he sorted it all out. And man does it run good. oh happy day
Old Sep 7, 2006 | 10:28 PM
kurvhugr's Avatar
kurvhugr
So, what did the dealer do?
Old Sep 8, 2006 | 04:24 AM
dmh's Avatar
dmh
Not exactly. Under vacuum, yes; positive pressure, no.
Old Sep 8, 2006 | 07:12 AM
etalj's Avatar
etalj
this is a myth....backpressure doesn't actually give torque down low. However it's not completely untrue....basically you don't get the scavenging effect with a large diameter exhaust at low rpm (gas velocity is too low). Basically when the exhaust flow is not high (i.e. at low rpm) this usually means that a higher backpressure is preferred to make gas flow fast.
Old Sep 8, 2006 | 11:12 AM
norm03s's Avatar
norm03s
What did the dealer do????
Old Sep 8, 2006 | 01:57 PM
herbie hind's Avatar
herbie hind
really dude this is cruel to say the least.(can you believe it ? this is what these little cars do to people ; i'm sitting here wanting to know what some dealer did to a guys car in colorado for gods' sake !!).
Old Sep 8, 2006 | 02:57 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Me too! What *could* the dealer do to an installed header to give you all that power back? Did you have the gasket in upside down? Inquiring minds need to know...
Old Sep 8, 2006 | 03:19 PM
coloradomini
Okay sorry. When I installed the header the precat 02 was rubbing on the insulation thus shorting it out. The dealer reposition the hole so the 02 would not rub. Replaced the 02. And some remapping and WOW is all I can say.
Old Sep 8, 2006 | 04:12 PM
herbie hind
thank you . i can sleep now .
Old Sep 8, 2006 | 04:47 PM
kurvhugr's Avatar
kurvhugr
Your dealer did "some remapping"? Do you mean flashing the lastest version of ecu s/w or did they actually do some sort of custom work.....not something I would expect from a dealer.....
Old Sep 8, 2006 | 05:10 PM
coloradomini
From what I got from it was reflashing to compensate for the headed. I am scheduled to get remapping with Mr. Webb. I may cancel that appointment. Not sure the car can run any stronger or better. The header does make a difference. Mid range is stronger then the hit at 5,000 rpm is like a blast off. I wish I would have had this a MTTS.
atenzany62
Aug 26, 2015 09:26 AM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
