Drivetrain Custom air intake
Old Aug 28, 2006 | 10:12 AM
  #26
ignote's Avatar
ignote
Some filters have a velocity stack built-in.
Old Aug 28, 2006 | 10:19 AM
  #27
obehave's Avatar
obehave
Originally Posted by Dr Obnxs
but you still need to get air to it. This is where the elimination (or reduction) of bad airflow design helps out.
For instance, pretty much all of the K&N type filters have a square edge at the innner rubber on the filter base. This is very, very bad. Air has to make a 90 degree bend in a very short time, and the air veloicites at the corner are huge. This will create huge problems, effectivly reducing the open diameter of the filter exits. A radiusing of just a quarter inch would help this a lot. At each and every junction in the intake path, there is the potential for problems. Sure, post SC there's boost to "push" the air past the rough spots, but there is no free lunch, and the price paid is with increased IATs and more pressure drop between the SC and the intake valves than is required.
And while TB changes on stock Minis may be of little value (I took data that backed that one up), opening up the TB isn't new to the Mini. There are lots of boosted cars that get benefit from larger TBs. And there are modded Minis that get benefit from them too.
Here's (yet) another perpective. If there are people who will change aftermarket intakes over one or two potential HP, why not do it right, get a smooth flow path, and get what there is to be had from the intake? On my modified mustang, we went the cheap route (3" sewer pipe) to improve the flow from the K&N by radiusing the pipe, and having it go into the filter somewhat (hack version of GTT set-up). While there isn't room to do the sexy Webber stacks, there's benefit to be had. There are some of us that are insulating the aftermarket CAI boxes. This type of mod should be considered as well, as it's cheap and effective. I'm just surprised that GTT is the only ones that offer something like this.
Matt
The ole "There are not absolutes in performance" thing.. For example the GTT setup we've mentioned had the 90º issue you're talking about but also has the stack so it's somewhat of a break even deal.
I have noticed that the UniFilter in my Alta and my HDI both have a small radius at the exit.
Being one of the temp reduction chasers I understand the bid for all the free and cheap HP bits floating around.
Old Aug 28, 2006 | 10:25 AM
  #28
obehave's Avatar
obehave
Originally Posted by SHUMopper
The velocity stack intake has actually just been a hit in the 1.8T tuning scene....its proving to generate a much quicker and larger air flow for the turbocharger over standard CAI or filters.
One was released by Evolution motorsports for the 1.8T which has shown VERY good results over the typical CAI or RAM air setup.
Im looking to add this to my current setup, but here is a link to the product. Im sure there has to be something like this available for the MCS.
Any pics of the device? I like looking at cool shiny stuff.
You ever notice how go-fast stuff is almost always shiny?
Old Aug 28, 2006 | 10:28 AM
  #29
Dr Obnxs's Avatar
Dr Obnxs
Google is an amazing thing...
Matt
Old Aug 28, 2006 | 10:55 AM
  #30
jaynicholson's Avatar
jaynicholson
That's it, only some have a velocity stack. When I spoke with the guys at Madness a couple of months ago the said that the filter for their cai has one. The Alta filter only has a bit of one. Unfortunately, I'm not crazy about the whole design of Alta's filter. Fist, the foam seems very thin. Second, if you've seen one used you'll notice that the tip of the filter gets much dirtier that others parts, indicating that a much higher volume of air is coming in through this area. So, I've thinking about swaping mine for a cone shaped k&n filter that has a built in velocity stack.
Old Aug 28, 2006 | 11:00 AM
  #31
obehave's Avatar
obehave
Matt
It is isn't it.
While you were at it why didn't you post the dimensions so I could see if it would fit in the HDI box?
Is that the one you're talking about SHUMopper?
Old Aug 28, 2006 | 11:30 AM
  #32
SHUMopper's Avatar
SHUMopper
This is the V-Flow system as they call it....
Notice the reduction in piping size, well inside the filter is the velocity stack causing the Berunelli (?) effect to increase the air flow into the system.
sorry about the small pic, all i could find on the "inner" part...
Old Aug 28, 2006 | 12:14 PM
  #33
obehave's Avatar
obehave
Hmmmmm?? Might look for that 77 Series truck filter
Most filters in that series appears to have a radius at the outlet.
Old Aug 28, 2006 | 12:46 PM
  #34
polizei's Avatar
polizei
Hrmmm, this thread is starting to change my mind of the ALTA CAI.... Maybe I should go GTT over ALTA...especially since it's blue and will match my car.
-Cody
Old Aug 28, 2006 | 12:56 PM
  #35
obehave's Avatar
obehave
-Cody
Roland recently had a deal going on them. Don't know if it's still true.
Can't hurt to email him. He's a pretty good guy to deal with.
Old Aug 28, 2006 | 01:39 PM
  #36
polizei's Avatar
polizei
I won't be able to buy one for a long time, so as for now it doesn't matter anyway...because I can't get either.
-Cody
chrisx18240
26
Mar 16, 2022 09:56 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
theblackfalcon
Aug 26, 2015 09:18 AM
