Drivetrain Powercardtuning.com
Old Aug 9, 2006 | 09:47 AM
1FSTMINI's Avatar
1FSTMINI
Powercardtuning.com
A guy in my shop has this card on his Miata and said it made a HUGE difference....Was wondering if anyone was using it, and if so, what they thought about it....Found the link on Mossmini but never heard about this product before....Seems very easy to use when he showed it to me and for the price, it doesnt look to bad.
PowerCard TC2 $199
http://www.powercardtuning.com/produ...eIndexID=53133
PowerCard Pro - No price yet
http://www.powercardtuning.com/produ...pro/index.aspx
DISCUSS!
Old Aug 9, 2006 | 10:47 AM
MiniMacPR's Avatar
MiniMacPR
From the looks of it the TC2 won't work on the MCS, but the Pro looks promising...Anyone seen it in use?
Old Aug 10, 2006 | 02:48 PM
trackster's Avatar
trackster
This is something new. More info please
Mark
Old Aug 14, 2006 | 04:05 PM
1FSTMINI's Avatar
1FSTMINI
bump
Old Aug 15, 2006 | 05:03 AM
stevecars60's Avatar
stevecars60
PowerCard TC2 $199
DISCUSS!
Wow, for the price, it looks great. More info from your Miata guy might help. This is the first time I've seen or heard of PowerCard. Nice find
Old Aug 15, 2006 | 06:26 AM
Dave@ddmworks's Avatar
Dave@ddmworks
Manufacturer
Since we develop parts for the Miata world also, I figured I could give you guys a little info on the powercard. A lot of the Miata kits have been using this or very similar set-ups for fueling when adding a supercharger or turbo to Miata's. The regular powercard is a very simple device in how it works. It has a built in MAP sensor that extends the pulse width of the injector based upon the amount of pressure that it reads. For a given fuel pressure, the longer the pulse width, the more fuel that gets injected. This works very good until you run out of injector, which is a lot easier to do with Miata's then MINI's since the biggest injectors in the Miata's are 230's compared to the stock MINI 340's injectors. When we first started working on the DDM M62 project we had a device similar to the powercard made by BR Performance called the "ELF" ready to go if we needed it, but found out that we did not. The ELF works on the same principle as the powercard, but has some user adjustability built into it. Another thing with the Miata's is that you can not re-flash the factory ECU (pre 2006) so the only option we have is to add piggyback controllers like this.
I have heard the new powercard pro will have a lot more adjustability and have heard that it can do some really neat things, but until I actually see one, I will wait to comment.
Old Aug 15, 2006 | 06:33 AM
stevecars60
Originally Posted by Dave@ddmworks
Since we develop parts for the Miata world also, I figured I could give you guys a little info on the powercard. A lot of the Miata kits have been using this or very similar set-ups for fueling when adding a supercharger or turbo to Miata's. The regular powercard is a very simple device in how it works. It has a built in MAP sensor that extends the pulse width of the injector based upon the amount of pressure that it reads. For a given fuel pressure, the longer the pulse width, the more fuel that gets injected. This works very good until you run out of injector, which is a lot easier to do with Miata's then MINI's since the biggest injectors in the Miata's are 230's compared to the 380's in the MINI stock. When we first started working on the DDM M62 project we had a device similar to the powercard made by BR Performance called the "ELF" ready to go if we needed it, but found out that we did not. The ELF works on the same principle as the powercard, but has some user adjustability built into it. Another thing with the Miata's is that you can not re-flash the factory ECU (pre 2006) so the only option we have is to add piggyback controllers like this.
And, a big thank you.....Sounds like a great product. Are you saying the ProCard is the piece for the SC cars?
Old Aug 15, 2006 | 05:52 PM
1FSTMINI's Avatar
1FSTMINI
Good stuff Dave.
Old Nov 12, 2008 | 10:24 AM
rgc0233's Avatar
rgc0233
Powercard Update?
Anybody have any new info on the Powercard? Has anybody tried it yet?
Old Nov 12, 2008 | 12:50 PM
gnatster's Avatar
gnatster
If you look at their site you will see no MINI application and the same card that was coming soon in 2006 is still coming soon.
I'd consider this a dead end.
Old Nov 13, 2008 | 10:33 PM
seatosky's Avatar
seatosky
Agreed this seems like a lot of other systems out there, not very practical for the MINI because the cars are so smart, they know when they are being tricked and will compensate. Custom remap or go home, folks!
