Drivetrain IC After 50k miles....
Old Aug 8, 2006 | 04:25 PM
  #26
polizei's Avatar
polizei
Glad I could help some. I drove mine today and it also felt like my MINI had a little more kick to it. Almost like it was eager to get on it!
-Cody
Old Aug 8, 2006 | 04:40 PM
  #27
gizzer777's Avatar
gizzer777
That was the greatest!
-Cody
Cody....
Eager to get it on?....
I have had to tie mine down in the garage since this morning....It Keeps making these growling sounds and the garage door keeps going up...had to hide the opener!
Your instructions/photos were fantastic and I am usually "afraid" to mess with the Mini....Just jumped right into this one!
Wonder how many Hundred the dealer would charge or if they have ever even serviced one as we have just done! Min they get is $135 per hour...
You should package a video and some "custom" cleaner ("Cody's Combustion Chamber Cleaner"...." specially formulated to cleanout IC's!..... and sell it!
Old Aug 8, 2006 | 07:23 PM
  #28
polizei's Avatar
polizei
Yea, too bad I don't know the first thing about marketing something, let alone making it!
Thanks for your kind words! I'm glad I can give back a little bit to the MINI community, because they have offered me so much. And honestly, without NAM I doubt I would have a MINI today. It pushed me that extra little bit to get one and man am I glad I did.
Happy motoring!
-Cody
Old Aug 9, 2006 | 04:25 PM
  #29
etalj's Avatar
etalj
Originally Posted by latte hiatus
I never thought of this part of the equation - most articles deal with the loss of efficiency due to the heavier oils coating the IC. Thank you for the enlightening expose!
Pleasure. Just going by common sense, as i've seen oil deposited on both IC boots, which means some of the oil suspension is making it past the IC and into the Intake Manifold....
Old Aug 9, 2006 | 04:29 PM
  #30
latte hiatus's Avatar
latte hiatus
Based on your common sense, I ordered a OCC to see if it could help at all in reducing the pinging I've been getting. Thanks again!
Old Aug 9, 2006 | 04:45 PM
  #31
chows4us's Avatar
chows4us
Originally Posted by obehave
There needs to a warning on this thread.
The pictures may be too graphic for some
First definitive evidence I've ever seen. Good job Polizei
50K miles ... hmm.
Old Aug 9, 2006 | 04:56 PM
  #32
yumhaggis's Avatar
yumhaggis
Now you tell me, You know some things seen, can't be unseen
Old Aug 9, 2006 | 06:59 PM
  #33
polizei's Avatar
polizei
Everyone quick, go order a quality OCC! And then send $5 to me for unleashing this awesome evidence.
-Cody
Old Aug 9, 2006 | 08:35 PM
  #34
etalj's Avatar
etalj
No prob I doubt it will completely stop the pinging, but hey, if you catch the oil before it goes into the IC, at least you'll be eliminating one possible cause of the pinging. Make sure you clean your IC thoroughly before installing the OCC though.
Can you elaborate on the pinging you get? I hear you guys in the US get crappy fuel. Most likely it is due to crappy fuel. Try getting some sort of octane booster and see if that helps....
By the way, to get the ultimate in oil catching, it's adviseable to put another OCC on the other PCV line. The PCV line that most put OCCs on is on the left (crankcase to SC), and there is another line (crankcase to intake hose) that some people install another OCC onto. However, most just stick with the one, but if you're still seeing gunk/oil in the IC or around the boots/horns/etc, I'd recommend installing a second OCC. For now though, just try the one, drive around for 10k, and have a look, if there's nothing, keep going, and check every 10k.
Old Aug 9, 2006 | 09:17 PM
  #35
polizei's Avatar
polizei
Are you in the UK? The Octane we use over here (93) I believe is equivilent to you're 97 or 98.
Just thought I'd share. Could be wrong.
-Cody
Old Aug 9, 2006 | 09:25 PM
  #36
Yucca Patrol's Avatar
Yucca Patrol
And Yucca, I did not drop the oil yet. Do you think all of the solvent would be gone after almost 24hours of sitting in that pan? If so, I'll go re-take some pics and see if there is any less-oil.
-Cody
I'm not sure how long it would take for the solvent to evaporate. I do know that the oil will slow the evaporation significantly, and you'd probably have to boil off the solvent to really know for sure that actual volume of oil.
But the important thing is that it only takes a thin film of oil inside the intercooler to affect the efficiency of the system. I'd guess that there might be no more than a couple teaspoons of oil, but that is still significant.
My plan now is to clean the intercooler at least every other oil change. I'll be curious to see what it looks like after only 10k miles or so.. . .
Old Aug 9, 2006 | 09:45 PM
  #37
latte hiatus
Definitely - I'm putting the OCC on when I install the DFIC. When I removed the IC to install the JCW injectors, there was definitely a good amount of oil coating the IC boots, but I didn't clean the IC at that time (at 8500 miles).
There have been several threads where those of us in CA bemoaned the poor 91 octane fuel available to us, and the consequent timing retard/pinging. The consensus is that octane boosters aren't price-performance economical. However, those of us who have tried 100 octane racing petrol are convinced that we need at least 93 octane in California.
Thanks for the advice! I thought about going with two catch cans, but refrained due to budgetary constraints.
Old Aug 9, 2006 | 10:28 PM
  #38
etalj's Avatar
etalj
oh ok, you guys only get 91. That would probably explain the pinging.
I'd only go with a second catch can if there is any oil in/on your IC/boots after installing the first OCC.
Polizei, i live in Australia. I think your 93 is the equivalent of our (and the UK's) 97/98.
Old Aug 10, 2006 | 08:22 AM
  #39
obehave's Avatar
obehave
91 octane is that pee pee gas they have to use in California
The rest of us get 93 octane
Old Aug 10, 2006 | 10:16 AM
  #40
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
And if you live in some of the "western" states: here in New Mexico (still part of the USofA) we only get 91. There's a place in Alb that sells 101, so some of us mix it with the super swill to get better ooomph. It works. I ran an altitude adjusted 14.7sec 1/4 mile on 101 octane a couple of months ago!
cheers,
Old Aug 11, 2006 | 08:17 PM
  #41
etalj's Avatar
etalj
oh ok....poor California ppl...
Old Aug 13, 2006 | 12:55 AM
  #42
latte hiatus
We don't want your pity - just your good petrol!
Old Aug 13, 2006 | 01:18 AM
  #43
etalj's Avatar
etalj
i'd gladly swap our good petrol availability for your good tuner/vendor availability. Do you know how many tuners there are that know MINIs in Oz? One, and his shop is about a 10 hour drive.....just shipping springs from M7 to Aus is USD150 !! Count your blessings!
Doc Pain
Mar 10, 2021 04:50 AM
cashbyvt
R55 :: Clubman Talk (2008+)
Oct 3, 2015 08:09 AM
Flyboycoy
14
Sep 24, 2015 06:32 AM
goneFXcrazy
Sep 22, 2015 02:33 PM
Ntety
Sep 2, 2015 08:39 PM
