Drivetrain Have you done a 1/4 mile in your Cooper S ??
Old 03-22-2003, 04:37 AM
mn_angrybeats's Avatar
mn_angrybeats
mn_angrybeats is offline
Some of you may have seen my 0-100mph & trackday video, well my next outing is a Qtr mile run at Santa Pod drag strip in the uk the 6th of April
I have the Hartge Conversion at the moment however my car goes into AmD in the uk on the 2nd of April for a Milltek exhaust & header and some H&R lowering springs. They intend to Dyno the car before and after I they reakon I should see 225/230hp at the flywheel and over 190lb/ft torque.
What times have you posted in the 1/4 mile and what helped to get you off the line. Revs / tyre pressures etc ?
I have standard 17" wheels and Toyo T1-s Tyres 215x40x17. I want to keep the wheels and dont want to change them to lighter ones.
I will post the 1/4 mile vid after the event.
Old 03-22-2003, 05:24 AM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
The best I've run is a 15 5 This is with an intake, and light weight wheels 16x6.5 (14lbs) and with falken azenis tires at about 23 PSI. My biggest problem is that it has been cold out. so anylaunches above 3000 rpm will lead to wheel spin. I did lower the pressure to about 20 psi and got a better start, but time was slower because no time in between runs. I would say get a good burn out done before you go and then just go at it.
Good Luck
Old 03-22-2003, 08:52 AM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
There's a guy on here that ran 1/4 miles last summer. He has vids posted on his site. I can't remember his MCO name, but he looks like (has his photo in his sig line) that actor from 1970's Emergency TV show. Search for Emergency and you should be able to track him down.
Old 03-22-2003, 02:58 PM
jlm's Avatar
jlm
jlm is offline
chandler had recorded some pretty fast times.
07-16-2020 12:54 PM
phrza81
10-10-2015 11:37 PM
kpl
08-11-2015 04:52 AM
dchang0
08-10-2015 03:37 PM
joelcseymour
08-07-2015 12:43 PM
Quick Reply: Drivetrain Have you done a 1/4 mile in your Cooper S ??
