Drivetrain diamond racing 200hp kit
Old Mar 18, 2003 | 07:09 PM
SMG's Avatar
SMG
their graph is identical to my uk ggr 200hp kit....
is it the same thing???
diamond racing kit
Old Mar 18, 2003 | 07:14 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Yes.
Have you gotten yours on the dyno yet?
I wonder where Diamond is getting their pulleys from as well.
I used the same software - the GGR/Superchips, and didn't see the same thing on the dyno that the Superchips chart was showing. Just curious if you were able to check it out on a dyno yet SMG.
Old Mar 18, 2003 | 07:53 PM
SMG's Avatar
SMG
hi randy,
my shop is too busy with their race cars......i'll hv to wait......but the performance of my car has improved quite a bit after putting on my new wheels...
should've got these wheels long time ago... :???:
i emailed ggr about the dyno chart and the guy told me it was dyno'ed on a stock car with just the pulley & ecu....
what figure did u get from just the intake, ggr pulley & supership ecu?
Old Mar 18, 2003 | 08:42 PM
Sleepless's Avatar
Sleepless
I really think this conversation is tough to continue until someone does a before and after dyno run using the ggr pulley and superchip ECU. The dyno graph that they are providing is basically useless because, 1) they are computing crank HP without providing the % driveline loss they are using (I'm guessing 15%), and, 2) they did not provide a before and after dyno run on the same car.
Old Mar 18, 2003 | 09:38 PM
SMG's Avatar
SMG
i'll try to get a wheel hp dyno graph from GGR...
Old Mar 18, 2003 | 10:47 PM
SMG's Avatar
SMG
i think this dyno graph shows the before & after dyno results.
Original :
165hp @ 6510rpm
150lb @ 4081rpm
GGR :
207hp @ 6613
187lb @ 3875
_________________
hamann diffuser, mat, pedals, hand brake, shiftknob, rays ce28n forged wheels, yoko 215/45/17 a048R, kw v2 coilovers, 8000k HID, magnecor & iridium plugs, aero grille, madness inatke, GGR S200
Old Mar 19, 2003 | 09:01 AM
dave's Avatar
dave
pug poo picker-upper
Originally posted by diamini in the Vendor Announcements Forum:
Mini Cooper 'S' Pulley and Software Upgrade
Following the massive interest shown for the Mini Cooper 'S' we are pleased to announce that, Diamond Racing and SuperChips, now have a package available for the vehicle to give it 200 + BHP.
The conversion consists of alterations to the drive ratio of the supercharger and a modification to the engine management system mapping (using S.P.S) to account for the alterations. The effect of this modification on the vehicle in the UK shows an increase in power from 165 - 207 BHP & the torque from 150 - 195 LB/FT.
Dyno Chart
As the new pulley is only slightly smaller than the original, the standard belt tensioning arrangement is sufficient.
The engine management system is then reprogrammed serially using ODB II port.
PRICE: $1500.00 installed.
For more information Contact:
Diamand Racing Tech Tech@diamondracinggroup.com
The installation would have to be done in the S.Cal area. Outside of this area we would have to make some kind of arangements.
Diamond Racing does employe a European Master Mechanic that conducts all customer upgrades and assist's with the modifications to our own two cars.
_________________
Diamond Mini
I thought Diamond had two CVT Coopers. Did you get a Cooper S to do a product eval on this? If so, how many miles are on it now with the pulley/software? Any real world impressions?
    When Randy dyno'd his Cooper S, he got to 200 hp, but it took a lot more than a pulley and software. He had the Madness Intake, the Magnaflow, the London Stainless header, the larger throttle body, the 15% pulley and the software. The JCW kit has a lot more to it than a pulley and ECU programming to get to 200 hp as well.
    Anyhow, just curious.
    _________________
    cranes folded: 670
    to go: 330
    YahooIM: denvermini
    Old Mar 19, 2003 | 06:32 PM
    SMG's Avatar
    SMG
    ""When Randy dyno'd his Cooper S, he got to 200 hp, but it took a lot more than a pulley and software. He had the Madness Intake, the Magnaflow, the London Stainless header, the larger throttle body, the 15% pulley and the software. The JCW kit has a lot more to it than a pulley and ECU programming to get to 200 hp as well""
    pls. kindly post a dyno graph.
    200hp at crank or at wheel?
    Old Mar 19, 2003 | 06:43 PM
    dave's Avatar
    dave
    189 hp at the wheels
    11% assumed for driveline loss
    209 hp estimated at the crank
    Randy's discussion of his dyno results
    Old Mar 19, 2003 | 06:48 PM
    SMG's Avatar
    SMG
    i'd also like to point out that GGR car & Hartge car was tested in the Cars & Cars Conversion march issue (uk megazine) and the tester commented that the torque increase of 37lb over stock is identical on these 2 cars......they end up think the GGR car is the one to pick coz the price is 2/3 of hartge's kit and similar power increase.
    i checked out the hartge kit also but they don't seem to be able to provide a wheel dyno graph as well....the graph on the bird's uk site is just similar on the superchip graph......
    will u guys query about the real power of hartge's car as welll?? that car has the ecu & pulley only..(they used stock header/cat/cetre pipe with a quad pipe silencer)....and they claimed 210hp & 185lb torque...
    any comment?
    Old Mar 19, 2003 | 06:57 PM
    mars31971's Avatar
    mars31971
    SMG try going to mcshp.org they have information on several upgrades including Hartge. they show HP, torque, and pricing. Some have dyno's and sound as well.
    Old Mar 19, 2003 | 07:09 PM
    SMG's Avatar
    SMG
    mars31971 - tks. for the suggestion. i check that site regulary......great site......and i believe all tuners post their crank hp / torque graph instead of wheel hp / torque graph so there's no way for us to guess the actual wheel hp / torque result.
    sleepless - ""The dyno graph that they are providing is basically useless because, 1) they are computing crank HP without providing the % driveline loss they are using (I'm guessing 15%), and, 2) they did not provide a before and after dyno run on the same car. ""
    i guess not much true info we can get from all graphs from most tuners.
    Old Mar 19, 2003 | 07:15 PM
    travelkids's Avatar
    travelkids
    What stuff can be done not to void the factory warranty?
    Old Mar 19, 2003 | 07:16 PM
    SMG's Avatar
    SMG
    just found a thread from mini2...
    BHP ??
    quote:
    Originally posted by Dark Mini
    Podger as I live in Leicester near GGR and know the company quite well was thinking of getting the chip and the Magnaflow exhaust from them.
    What BHP are you pushing out??
    I'm getting 212 bhp,on an rolling road I use in the Midlands and that was with a PiperCross Cone filter, that was/is not part of the GGR Conversion, as I already had it.
    I would really advice anybody not to be to hung up about max bhp though, it's torque and drive-ability that is most important.In standard form GGR would claim around 207 bhp I think ?.Their test car had not been run in when I drove it with less than 900 miles on the clock,but it has big brakes , which I didn't have.
    I have 11,000 miles on the clock.
    Old Mar 19, 2003 | 10:12 PM
    bbt4's Avatar
    bbt4
    enough talk already,
    so is this deamond racing 200hp kit for real or what?
    bbt4
    Old Mar 19, 2003 | 10:20 PM
    Sleepless's Avatar
    Sleepless
    >>bbt4
    Yeah, I think I said that about a dozen replies ago. Until an independent source shows me a before and after dyno that shows wheel horsepower this whole conversation is pure fantasy.
    Old Mar 19, 2003 | 10:27 PM
    SMG's Avatar
    SMG
    i'm happy with it....and i think 212hp on rolling road is not bad as a reference....and again.....no driveline loss % is present so no way to know the actual wheel power.
    Old Mar 20, 2003 | 12:08 AM
    RandyBMC's Avatar
    RandyBMC
    Temporarily Banned
    To answer a couple of questions, I am happy with the pulley mod - the Superchips/GGR software is only worth about 6 horspower more than with the pulley alone. I had 180 hp and 159 ft-lbs of torque with the pulley and all of the other stuff - intake, throttle body, header with cat, and Magnaflow. When I added the GGR software, I got a whopping 186 hp and 159 ft-lbs of torque. These are wheel numbers on a warm car.
    I think you will be happy with the pulley - it makes great power all on its own. I'm still working on the software to go with it, as I'm just not happy with the fuel curves even after the Superchips/GGR upgrade.
    As far as the 200 hp being real - dynos are easy to make numbers you want to show. Apply any driveline loss you like to get the numbers where you want them, run the car cold, run the car with an ice packed intercooler, etc. I'm not implying this was done, I just haven't been able to verify the numbers they have gotten.
    Here's what I think - you do the pulley alone and you typically see a 17 or so wheel hp increase. If you add 6 wheel horsepower to that, you get 23. The stock runs we have done show 147-150 pretty consistently. That would give you around 170-175 at the wheels for the GGR conversion. Using the same 11% driveline loss, you will get around 192 hp at the flywheel with this conversion. The question becomes, is it worth the extra 6 or so horsepower for the software. My personal opinion was no. Take the 185 flywheel from the pulley and be happy with the $200 part. Then see what comes available - I will offer whatever software I figure out to be the best as a retro fit.
    Let me know if any clarifications are needed. I'll get some digital pics of the Dyno charts and post them once I dig out of my house here in Denver - we got snowed in like nothing I've ever seen before (and that includes time in Chicago and NJ!).
    Randy
    Old Mar 20, 2003 | 01:30 AM
    SMG's Avatar
    SMG
    randy, tks. for your comment.
    is it possible to show me the increase of wheel hp & torque after each mod.???
    1. base - 147 (+0)
    2. intake - ??? (+??)
    3. intake + exhaust - ??? (+??)
    4. intake + exhaust + throttle - ??? (+??)
    4. intake + exhaust + throttle + header w/ cat - ??? (+??)
    5. intake + exhaust + throttle + header w/ cat + superchip - 186 (+39)
    this is my question : (estimate wheel hp increase only)
    car (A) - intake, header w/ cat, exhaust = (+15)
    car (B) - intake, pulley & ecu = (+25)
    if car (A) adds a pulley and ecu, can you say car (A) becomes (+40)???
    and if car (B) adds intake, header w/ cat & exhaust, can u say car (B) becomes (+40)???
    it doens't work like that , does it?
    let's say adding an exhaust on a base car then it'll be (+10)
    add an exhaust on a "already pulleyed & ecu'ed" car.......then you can't just add +10 onto what it's already is, rite? i'll guess the exhaust gain on this car will be less than +10....correct me if i'm wrong.
    from base 147 to now 186 = 39hp increase.....and if hp is not cumulative, can u really say that the ecu itself only adds 6hp ???
    pls. advise.
    Old Mar 20, 2003 | 04:14 AM
    jlm's Avatar
    jlm
    focusing on hp only is misleading. a chip that lets the engine rev to 7500 will almost guarantee more hp, with no other change to the power curve. what you really want to look at is the torque curve. It will typically max out around 4000 or so (and you want the max to be as high as possible) and then stay reasonably flat until it starts to fall off. the less it falls off the better.
    Torque is the primary quantity measured by the dyno and shows you the engine efficiency over the rpm range. the shape of curve is every bit as important as he max reading. It will point out where you have weird breathing problems, resonances, etc.
    Old Mar 20, 2003 | 08:12 AM
    SMG's Avatar
    SMG
    i totally agree with you jim...i felt alot more torque from 4000rpm up after the pulley & ecu mod.
    but it's really hard for me to tell if it's the pulley or the ecu to get me that extra 37lb torque and at 500rpm lower than standard.
    W0TM8
    Dec 19, 2019 07:50 AM
    Aug 21, 2015 11:25 AM
    Aug 7, 2015 09:51 AM
    Aug 7, 2015 08:10 AM
