Drivetrain Will there be any MCS gear ratio mods in the future?
Old Mar 17, 2003 | 05:03 PM
Albert's Avatar
Albert
Anyone know if shorter gearing (via final drive) will be available any time soon? I gotta ask this b/c I'm sick of the tall stock 1st gear in my MCS. Nothing worse than a Tractor beating you off the line! just kidding! But seriously, I know we've heard this complaint before about 1st being too tall. But also, I feel like 6th is pretty useless too. For me (and my magnaflow), I like to use 6th on the freeway when I feel like I could use some more drone in the cabin hehehehe. But otherwise, I don't find myself going over 100mph (over 100mph here in SoCal is an automatic reckless driving citation), so 6th could stand to be a little shorter too.
I know this is a tough proposition, and costly too, since we've got two final drives in our trannies. But any info or speculation would be appreciated.
Thanks in advance!
Old Mar 18, 2003 | 03:32 PM
Albert's Avatar
Albert
Old Mar 18, 2003 | 03:44 PM
MG-BGT's Avatar
MG-BGT
can't answer your question, but for me 1st gearing is just right, I like it as is, and same with 6th. To avoid being beaten off the line by a tractor, bring revs to about 3-3.5k rpm and drop clutch. I think slow off the line-ness is more of an issue of not having S-charger spooled up to kick in.
Just my 2c worth.
Old Mar 18, 2003 | 04:36 PM
Ryephile's Avatar
Ryephile
Albert, the taller 1st gear is better suited for track-time than neck-snapping, tire-roasting-Woodward-cruising acceleration
Cheers,
Ryan
P.S. I would doubt MINI would want to change the gearing on the S, and isn't not as simple as changing the pig in your Ford 9" rear-end; the final drive ratios are integral to the transmission! (read: new tranny for this idea to become reality)
Old Mar 18, 2003 | 10:10 PM
Minian's Avatar
Minian
Albert: Mini Mania offers an LSD with final drive choices, a bit pricy. Also I believe you can get a final drive change from Quaife. If you can't find it then ask RandyBMC.
_________________
Minian (^-^)
sevin
May 2, 2026 06:11 AM
Ryephile
Aug 25, 2015 06:51 AM
minipopkart
Aug 13, 2015 05:22 AM
RHcoopers
Aug 6, 2015 07:33 AM
