Drivetrain Daily driver setup- Your thoughts??
Old May 10, 2006 | 09:01 AM
  #26
bmweater's Avatar
bmweater
Im over that then......
Old May 10, 2006 | 03:34 PM
  #27
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
I've had both #1 and #2, except magnaflow and no tmic. Definately go 19% + inj + GIAC. If you go 15% you'll love it....then start thinking about how much better the 19% would be. That's how the sickness starts. (To see how it ends, read my sig ).
Old May 11, 2006 | 05:07 PM
  #28
bmweater's Avatar
bmweater
Holy smokes!!! Wow now theres a real MCS Veni!!! Have you dyno'd it yet?
Old May 11, 2006 | 09:24 PM
  #29
markldriskill's Avatar
markldriskill
I, too, would dump the IC but i would get Koni FSDs instead. Also, you might think about the 15% sc pulley with a 4% oversized crank instead of the 19% SC pulley. I'm going to go with either the 2 or 4% oversized, lightweight crank pulley as my next mod along with 380 or 400 cc injectors and GIAC ecu tune. Some might say that the lightweight crank pulley is not reliable, but I disagree. I won't go into any detail but suffice to say that I think the odds are better than the smaller SC pulley at 19%, which virtually guarantees faster belt wear.
The other thing you might think about doing instead of the IC is some suspension o brake or wheel mods or dump9ing the run-flats. It depends on how you feel abut the ride and handling. I toyed with the idea of lowering, but I'm in the LA area too, and did not want to fret constantly over potholes and steep driveways. The Konis transformed the car as far as comfort, and with some improvement in handling (although I got a 19mm rr sway bar at the same time, so not really sure which one made the biggest diff. (Probably the sway bar)
The one other thing I think is REALLY important is the brakes. For a small amount, you can upgrade the brakes a bunch (see my sig). I found the first time I drove hard (in a poker rally) for an extended time, the brakes lost their lovin' feelin': mushy pedal, etc. Also, terible stock pads throw dust like crazy and don't stop as well as aftermarkets. That, along with the SSR wheels and Dunlop NON-runflats were the VERY first mods I did.
I'm really happy, but now I want some more horses. The crank pulley, injectors and GIAC are next. And, later, exhaust. I think one-ball is cool, and probably one of the better bang for the buck arrangements. However, a catback exhaust will get you more horses (though expensive). I decided to hold out until I save up enough for the Milltek catback.
Right now, I have the 15% and K&N Typhoon CAI with NGK 22s (only because unlike the Alta, it IS CARB-approved, with a sticker, and I'll never have to remove it to get smogged). I'm pretty happy with that, but I think the lightened crank pulley at 4% will get me BOTH a reduced loss of horses to the 7-pound stock version, AND the 19% "net" SC reduction effect, without straining the serpentine belt. However, before you go with the crank pulley, check out the threads (there are many) and decide whether you think it's right for you. IN fact, read NAM a lot.
Any way you go, you will have a great time. But NAM can help you prevent making a costly mistake.
Motor on!!
Old May 11, 2006 | 09:52 PM
  #30
Soul Coughing's Avatar
Soul Coughing
Go for #2
19% is great, but you don't need anything else other than that. Get the GIAC and injectors for a bit more go, but they aren't absolutely needed. Although i love the current setup i have (see sig), but as Veni said... i got the mod bug and will be following suite with a twincharger within the next few months. You would love the lower down torque the 19 gives! you wont regret it! Good luck and have fun!
Old May 11, 2006 | 10:05 PM
  #31
MINIotaple's Avatar
MINIotaple
100% faster belt wear
X% of engine damage
Old May 12, 2006 | 01:39 PM
  #32
Veni_Vidi_Vici
I haven't dyno'd mine yet because I'm not quite finished (evil laughter). I'm going to get pistons and headwork done after the autocross season is over. My goal is 350 whp. Then I'm finished. Really. Well, maybe straight-cut gears. Then that's it! I guess the only safe thing to do after that is big brakes.....
See how it is?
Old May 14, 2006 | 01:45 AM
  #33
bmweater's Avatar
bmweater
[quote=markldriskill] The Konis transformed the car as far as comfort, and with some improvement in handling
[quote]
I like this ides of putting some Konis on the MCS. How much did it help your ride quality and how much were they?
Old May 14, 2006 | 04:43 AM
  #34
sprp85's Avatar
sprp85
setup #2..
U won't track ur car, why stay with 15%?
Go with 19%, better for daily.
Old May 20, 2006 | 09:08 PM
  #35
bmweater's Avatar
bmweater
Since I am not going to track the car, it seems as if the best idea would be just to do the 19%. So.....I was looking at the M7 page and I like the idea of combining the 16% with the 2% crank pulley. That way I get more boost and less drag. So what say thee?
Old May 21, 2006 | 05:41 AM
  #36
ignote's Avatar
ignote
My 2 cents.
15 or 16% pulley for reliability. 19s eat belts.
Any CAI.
1 Ball exhaust and new MINI exhaust tips. Unless you want particular sound.
Rear Sway Bar.
Better Tires.
I have these two setups running through my head and i would like to know your thoughts and opinions. This car will be driven in downtown LA area so mind you it will have alot deal with alot of stop and go during the week. On the weekends it will travel the open roads for about 100 miles to visit friends and family. Which one is my best bang for my buck? Which one will maintain a high level of dependability?
SETUP #1
15% Pulley
Alta CAI
One Ball Exhuast
Intercooler
What do you estimate the power, and MPG to be?
SETUP #2
19% Pulley
Injectors
GIAC Tunning
Alta Cai
One Ball Exhaust
(maybe top mount) Not sure if i will have enough $$
What do you estimate the power and MPG to be on this setup?
Thank you for your time and knowledge,
Michael
Old May 21, 2006 | 06:09 AM
  #37
sprp85's Avatar
sprp85
I don't recommend crank pulley..
just go 17% or 19% straight. No SC pulley + whatever.
Old May 21, 2006 | 06:52 AM
  #38
Johan's Avatar
Johan
Originally Posted by ignote
19s eat belts.
I drive my car extremely spirited every time I get behind the wheel. I had my belt off after more than 10,000 miles with my 19% to inpect it. It was just as good as the day I intslled it. -- Johan
Old May 21, 2006 | 08:12 PM
  #39
Wake|MCS's Avatar
Wake|MCS
My 2 cents.
15% or 16% isn't any more reliable than a 19% unless you take it to the track, which he clearly isn't going to do. Do you have a 19% pulley that you observed this from? 19% doesn't eat belts...
19% pulley + belt + Denso IK22's + install = $400
Spare belt = $25
Look on the 15%ers face when your 19%er ****** him? = PRICELESS
No need for the injectors and ecu tune, although they do give the extra oomph... I'd go with your setup #2 but scratch the one-ball and get an exhaust... As far as springs go, I went with H-Sports but I hear the m7's are really good too.
Good Luck!
Old May 22, 2006 | 10:18 PM
  #40
bmweater's Avatar
bmweater
Thanks for all the help and advice everyone. After doing alot of research I have decided to go with M7 tunnings stuff because (A) there close to my home and (B) Long Beach will allow me to maintain my warranty if I choose to upgrade with M7's products. As it stands I am looking at this package:
1. 16% Pulley
2. 2% Crank Pulley (may think this one over....want the power tho...)
3. 180 Thermostat (gets hot in LA)
4. One Ball....(shave some weight)
5. AGS System (love the sound!)
6. DFIC (this one is still up in the air....may be a while)
7. Rear Sway bar
8. Tunning in the future...like 4-6 months later
Other than that im going to keep it looking stock. Maybe just pull the back seats and spare hardware
Old May 23, 2006 | 01:57 AM
  #41
etalj's Avatar
etalj
i'd seriously consider getting the DFIC if i were you...looks brilliant. I'd say ditch the thermostat, and go the DFIC and a tuned ECU
1. 16% Pulley
7. Rear Sway bar
Old May 23, 2006 | 12:22 PM
  #42
bmweater's Avatar
bmweater
After talking with Peter for almost an hour, it seems that it is almost a must for me....rather than a desire...lol. In regards to the thermostat do you think that this would only help in the total cooldown of my MCS?
Old May 23, 2006 | 01:43 PM
  #43
deemo's Avatar
deemo
Long Beach and mods
Just curious how you found out that Long Beach will honor your warranty if you go wtih M7's products. Is Long Beach a mod friendly dealer? M7 is in my area too and I picked up my 06 MCSa from Long Beach a couple of motnhs ago and haven't had any experience with their service dept. yet.
Old May 23, 2006 | 10:17 PM
  #44
bmweater's Avatar
bmweater
Well when I spoke to Peter he said that the Long Beach mini would have no problems with those mods that i listed, and then to confirm I called over to the mini dealer and asked to speak to someone in parts department and spoke to them about the dealers stance on mods and he said that they were ok with certain mods such as pulley, thermostat, cai and exhaust. So yah....thats were i got my info.
Old May 24, 2006 | 02:30 AM
  #45
etalj's Avatar
etalj
it would probably keep the car cooler a lot of the time, but i think the car has to run at certain temperatures for the oil to be at the correct viscosity, etc. So when it's hot, it will make the car run a bit better, but will it make it too cold when it isn't hot? I'm not to read up on thermostats and the effects they have....
I'd say save the thermostat for later....
Old May 24, 2006 | 03:45 AM
  #46
d-mini-ero's Avatar
d-mini-ero
My 2 cents I just cut & pasted the list.... just pull out the items that make sence to you personally MINIHERO is my 2nd... Mini Cooper S. It's set it up to be a..."spirited street car"
The following is a description of the features and a listing of the mods....
Dark Silver with Pure Silver Roof
Pure Silver V-bonnet Stripes and "Checkmate Design" on A Panel and Rear License Plate Surround.
Interior: Silver Gray/Panther Black Leatherette
Premiun/Sport/Cold Weather Packages
6 Speed Manual Transmission
Helix 19% Reduction Pulley
Helix Cold-Air Intake
Helix Short Shifter
MTH Tuner Software
H-Sport Lowering Springs
H-Sport Rear Sway Bar
Grafik Dezine Decals/ Window Tinting
Aesthetic Design Center Caps
Whalen Shift Machine
Borla "Street" Exhaust
Garmin 2620 GPS & Ram Window Mount
Kosei K1 TS 17"x 17" (Gray) Rims... w/MINI valve caps
Goodyear Eagle F1 GS D3 Tires (215/45-17)
Pioneer Stereo ... XM/MP3/Ipod Adaptor
Black Aerokit Front Grille
Aerokit side skirts
Interior leather door pull covers
MINIHERO License Plates
MINIHERO Rear Brakelight Cover
Peace,
D
twistedimages
Sep 19, 2024 04:13 AM
W0TM8
Dec 19, 2019 07:50 AM
Piano Man
14
Sep 29, 2015 02:50 PM
thebordella
Aug 31, 2015 01:37 PM
xpunisherx
Aug 10, 2015 10:50 PM
