Drivetrain how many miles to break in a new cam?
Old May 1, 2006 | 12:43 PM
SpiderX's Avatar
SpiderX
For those of you who have been watching I put the Schrick "race" cam in my car last week and took out the old Schrick "street cam" which they no longer produce..... the results so far are very positive but i have not taken the engine above 4K....so far about 250 mi. I was thinking that 500 mi would be good.....or shoul iwait for 1000..... any experienced folks out there.... the engine has 52K on it now.
Old May 1, 2006 | 12:52 PM
TonyB's Avatar
TonyB
I recall for other rides it was on the order of minutes... ie, let it idle or run at 2,500 for like 20 minutes, and that was it. I'd contact Schrick directly though...
Old May 1, 2006 | 12:53 PM
RED FURY's Avatar
RED FURY
200 should be fine, not sure though
Old May 1, 2006 | 12:56 PM
SpiderX's Avatar
SpiderX
I tried to contact Schrick many times and they have never gotten back to me on anything......nor has Hamann.... I should tell them I am of German stock and see if that helps
I will contact Denon the NA importer/distributor
Old May 1, 2006 | 01:09 PM
TonyB's Avatar
TonyB
Denon? I have their 3801 receiver as the core of my entertainment system . Good luck, and if you do get the scoop, kindly close this loop and share. I too will be doing this when I get a Cosworth head later this Summer...
Old May 1, 2006 | 01:22 PM
BFG9000's Avatar
BFG9000
Every time I've put in a new cam, I've always been most concerned about not idling the engine for very long at first, because that's when the splash-oiled cam lobes receive the least oiling (hence the standard recommendation for revving in neutral for 20 minutes). I don't think high rpm use of a new cam would be a problem.
Old May 1, 2006 | 02:05 PM
motorsports3's Avatar
motorsports3
I had mine idle at 3000rpm for 10 minutes. After that i beat the living sh*t out of the car for a good 2 hours. Never had any problems.
Old May 1, 2006 | 02:13 PM
SpiderX's Avatar
SpiderX
[QUOTE=motorsports3]I had mine idle at 3000rpm for 10 minutes. After that i beat the living sh*t out of the car for a good 2 hours. Never had any problems.[/QUOTE
YES.......my kind of guy
Old May 1, 2006 | 02:35 PM
obehave's Avatar
obehave
Most of the time (V8 info here) you vary the rpms from 1500 to 3000. 15-20 minutes.
I've never heard of a cam break in where you leave it at a constant rpm, it's a bad thing.
You must have applied the proper break in lube as well.
I've always changed the oil right afterwards. The moly is pretty thick and not oil filter friendly.
New oil and filter. Let the engine cool down. then take it out and drive it. Once well warmed you can pretty much run the snot out of it.
Old May 1, 2006 | 02:37 PM
Crashton's Avatar
Crashton
I
Old May 1, 2006 | 02:45 PM
k-huevo's Avatar
k-huevo
The time to ask was before you turned over the engine; anyway, here is an excerpt from and engine break-in article by Larry Widmer “…Lets discuss the apparently-confusing topic of engine break-in. I’ll attempt to make all of this as clear as possible for everyone. There are “other” methods of break-in out there on the internet, so it’s up to you to choose the one that suits your style. First, lets address camshaft break-in. If the camshaft(s), and rocker arms are new, or if previously-run rocker arms are being used on new, or different lobes (rocker arms weren’t kept in order), you should start the engine and bring the revs up between 2500 and 3000 rpm for about 20 minutes. Do not let the engine idle for prolonged periods.”
Old May 1, 2006 | 02:57 PM
SpiderX's Avatar
SpiderX
You know what..... I have been driving the car at varying rpm for 250 or so miles.... it is broken in....... in the words of the 90 year old man who took a 25 year old wife......his 65 and 68 year old sons said, "Dad, you know that could be fatal"....the man did not blink and said to his sons, "if she dies, she dies" and so it goes for my engine.
09R56
Nov 16, 2022 10:49 AM
ebowling
90
Aug 4, 2019 09:15 AM
emulajavi
Dec 24, 2018 09:15 AM
jst_bc
Sep 11, 2015 07:45 AM
imanexcellentdriver
Aug 31, 2015 08:08 PM
