Drivetrain Exhaust question for a race mini...
Old Apr 30, 2006 | 01:10 AM
jjasonbbo's Avatar
jjasonbbo
On a race mini that is not a daily driver would it be benificial to just go with mandrel bent straight pipes w/ no muffler or cat?? Back in the day I done alot of research on forced induction cars and found that the more flow the better I was wondering if its the same on a mcs?? I know you couldn't do it for a daily driver cause its a environment killer... What kinda sound would it be also?
Old Apr 30, 2006 | 05:24 AM
MSFIT's Avatar
MSFIT
LOUD....and I would recommend if its a race mini cut the battery box out and just go straight back out with a straight pipe.
Or if you are going to drop a fuel cell in, with the oe tank out you could dump it right before one of the rear wheels then build a nice rear splitter out of all the room in the back.
Old Apr 30, 2006 | 06:29 AM
snid's Avatar
snid
Remember that some tracks have sound level limits...
Old Apr 30, 2006 | 04:47 PM
MSFIT's Avatar
MSFIT
for those you have a different setup
Old Apr 30, 2006 | 05:22 PM
onasled's Avatar
onasled
Many tracks have a db limit, and it's usually quite restrictive.
I was using a Minimania header, no cat, into a Miltek resonator and straight out the back with the battery box removed into a Flowmaster 40 series muffler and it was quite loud. Ask Snid, he hated it...
Worked very well. It was just able to pass at two tracks in the northeast.
Old May 1, 2006 | 07:49 PM
Mini Works's Avatar
Mini Works
I would recommend still using a cat,
there are a lot of high flow cats available, also they will not bring a check engine light, regarding the muffler, like Onasled said, a lot of track now check for noise, so you will need a muffler.
Also the Mini being a small displacement engine does need some back pressure, if you run a straight pipe from the header back, I will not be surprised if you actually loose power.
Victor
Old May 1, 2006 | 08:14 PM
jjasonbbo's Avatar
jjasonbbo
Thanks for the input!!!
W0TM8
Dec 19, 2019 07:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
elightbo
Aug 17, 2015 01:50 PM
ki7hy
Aug 12, 2015 07:07 PM
Aug 12, 2015 01:24 PM
