Drivetrain 19% Reduction Pulley
Old Apr 20, 2006 | 07:59 PM
qwertmonkey's Avatar
qwertmonkey
I just bought a 19% pulley and I plan on installing it myself. Does any body have any tips? I am kinda nervous...so anything would help. What do I need besides:
Tools
Belt/Pulley
Pulley Removal tool
Is there a how to for the automatic?
Old Apr 20, 2006 | 08:18 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I see you have the auto, which will make the install quite a bit more challenging. You will need to remove the wheel liner on the pax side to remove the motor mount. That will allow you to work on the belt tensioner and have some room, because the auto is closer to the unibody than the manual. You will also need to remove the bolts for the fuse box and remove the trans mount bolts to raise the motor, since the gearbox is much larger. You will also need to remove the power steering fan shroud, and the two mounting bolts for the fan as the lower mount is reversed on the auto.
Hope that is a good start. Take a look at our forum for a how-to.
Hope that helps!
Randy
Old Apr 20, 2006 | 08:20 PM
qwertmonkey
I see that the how to is for a manuel. That really stinks that there is that much more work for the auto...
Old Apr 20, 2006 | 08:48 PM
Barnabas's Avatar
Barnabas
Randy's how to is good. I followed it and didn't have any problems. Minor issues with pulling the pulley off. If you follow Randy's suggested changes for the auto, you should be fine.
It is a bit scary jacking up the motor from the oil pan though. Eek!
Old Apr 21, 2006 | 09:58 AM
mdsbrain's Avatar
mdsbrain
qwertmoneky do you plan to do the other mods which usually accompany the 19? Like Injectors and a some kind of ecu remap.
Old Apr 21, 2006 | 10:03 AM
minimort's Avatar
minimort
Don't forget the loctite for the SC bolts.
Injectors and ECU remap are not required...
Old Apr 21, 2006 | 10:40 AM
qwertmonkey
Well, I was thinking of also using colder plugs...
Old Apr 21, 2006 | 10:48 AM
minimort's Avatar
minimort
Colder plugs are always a good idea
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
WhinyR53
Sep 30, 2015 07:36 AM
daviday
Sep 25, 2015 01:31 AM
