Drivetrain Alta short shifter problem? HELP!!!!!
Old Apr 18, 2006 | 07:54 PM
Peter W.'s Avatar
Peter W.
I was trying to install the alta short shifter in my 04 mini cooper S but i can't get the new shifter to fit into the shift box. I ordered the one for the 04 models but somebody said that i might need the one for the 03 cars. Can someone please help me and tell me if i have purchased the right one or do i need to exchange it for the shifter for the 03 models? I would really appreciate the help. Thanks, Peter W.
Old Apr 19, 2006 | 01:07 AM
QB's Avatar
QB
I'm not quite sure I understand your problem....are you saying you have fitted the Short-shift extension piece and now you can't get the white plastic cover back on to the bottom of the selector box?
If this is your problem, there is no problem You are supposed to leave this cover off once you fit the helix!
Sorry if I have misunderstood you and pointed out the obvious to you as I'm pretty sure that this step is clearly outlined in the instructions.
Old Apr 19, 2006 | 07:51 AM
J0kER's Avatar
J0kER
when u remove tha shift boot wat colour is ur shift box, if its white then u have an early shift box u will need to exchange it for a 03 car. u can also tell by lookin' at ur OEM shifter and comparin' tha ends(round *****)where the cables attach to they should be same in size
Old Apr 19, 2006 | 03:45 PM
Peter W.'s Avatar
Peter W.
Thanks for the help, exhchanged for the 03 model and works AWESOME!!!!!!!! I recommend this product highly. It really is a great add on to your mini. Once again thanks for the help!!!!!!!!!!
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
