Drivetrain belt wear
Old Apr 16, 2006 | 03:55 PM
weezer2282's Avatar
weezer2282
belt wear
I've had an alta 17% pulley on for about a month and I am noticing some belt wear. The edge closest to the supercharger is beginning to get chewed up. The stock belt was replaced with a Napa belt when the pulley was put on. Could this be due to the pulley being misaligned? Has anyone had a similar problem with the Napa belt? Should I change the Napa belt and replace it with the stock belt or some other belt?
Old Apr 16, 2006 | 07:30 PM
qwertmonkey's Avatar
qwertmonkey
Well, I was told that a 17% would last you about 60,000 miles. Since you got it only a month ago, there might be something wrong. You might want to take it where you got it installed, and ask them.
Old Apr 16, 2006 | 08:15 PM
weezer2282's Avatar
weezer2282
It has been only about 1500 miles since it has been on. The stock belt when removed was in outstanding condition. I am just wondering if people have experimented with different size belts with a 17% and what type of success they've had with them. I am planning to take it back to the place where it was installed because it seems like something is wrong. I need them to take off my oil filter housing too since the dealer service department over-torqued the oil drain plug and the oil filter housing.That is another story...
Old Apr 16, 2006 | 09:02 PM
Petrich's Avatar
Petrich
I'm having the same problem
Weezer2282,
Just changed my serpentine belt this weekend for the same reason. The belt was badly worn on the "inside" edge and a few pieces had actually been gauged out. Looked like MINI had been attacked by mice.
Am using an Alta 15% pulley and the belt has been on only 2000 miles. Wonder if I don't have the pulley seated all the way. Didn't have this problem with the 19% pulley. Will take the car apart this Wednesday and try seating the pulley better.
Regards,
John Petrich in Seattle
OutMotoring
Mar 3, 2017 06:29 AM
vulkandino
Oct 31, 2015 08:29 PM
VanisleRyan
Sep 30, 2015 08:35 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
