Drivetrain Throttle bodies hype or helpful
Old Apr 6, 2006 | 01:42 PM
  #26
SpiderX's Avatar
SpiderX
Originally Posted by Dr Obnxs
400+ CFM at redline. And the stock TB can flow this amount as well, it's just that it may drop some pressure, so you're going to get less air into the motor. Any conductance path will have resistance to flow. If the stock TB is one of the larger contributors, getting an worked over one will help. If it's not, then it won't.
On my car, larger TBs didn't give me anything extra.
Matt
I'm pretty sure mine is 63mm and it does its job... I have a head/header/intake manifold and runners honed so I am able to take advantage of the increase. this would not be an early mod as I had the TB before the head and did not notice any sig difference
Old Apr 6, 2006 | 01:50 PM
  #27
obehave's Avatar
obehave
At what RPM would you say this larger TB starts to show an advantage?
Old Apr 6, 2006 | 07:59 PM
  #28
skuzy's Avatar
skuzy
wouldnt t/b only be worthwhile if ur going the full monty?
i mean a bigger t/b (increased airflow etc) would still suffer the same 'bottlenecks' as a stock t/b unless u had ported/polished/ the s/c headwork etc?
fair enuf jsut switching the t/b and nothing else might give u some gains but hwo much are we talking here? 2-5hp? for how much $$???
mdutton11
14
Oct 26, 2015 01:47 PM
caiken
Aug 27, 2015 06:55 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Indimanic
Aug 19, 2015 11:08 AM
