Drivetrain Alta problems
Old Feb 22, 2006 | 03:28 AM
SteyrTMP's Avatar
SteyrTMP
Alta problems
I just put on my Alta Intake...
Started around 3:00-3:30am, ended at 6.
First of all, one of those ball screw things was stripped before I even started... either factory or dealership
Secondly, none of the directions, online or the ones that come with the package, mention the grounding wire that goes through the back panel piece. I had to cut a slit to get that out.
Third, my package came without all the mounting screws/bolt.
Fourth, the original intake tube sucks *** when you try to take it off the bottom of the airbox.
Lastly, and worst of all, the silicone tube I got has a very large vacuum tube, and the clamp for the old one doesn't go all the way on. It's half on, and I'm worried. I'm going to try to go to AutoZone and see if I can find something that will fit until Waylan from Way Motor Works stops by to install my swaybar. I also broke one of the tabs off the fuse box cover It's on there, but it's going to be a ***** to get off later.
Anyone else have problems installing theirs? It was tedious, annoying project, and the instructions really suck.
Do you normall get the mounting screws and whatnot? What about the oil for the filter? I didn't get that either.
Old Feb 22, 2006 | 03:47 AM
mdsbrain's Avatar
mdsbrain
Secondly, none of the directions, online or the ones that come with the package, mention the grounding wire that goes through the back panel piece. I had to cut a slit to get that out. What grounding wire? Do you have factory driving lights?
Third, my package came without all the mounting screws/bolt. The package does not come with any mounting screws or bolts. You reuse everything. The package should come with 1 or 2 clamps though.
Fourth, the original intake tube sucks *** when you try to take it off the bottom of the airbox. Thats a MINI design and it comes out with alot of wiggling.
Anyone else have problems installing theirs? It was tedious, annoying project, and the instructions really suck. The best instructions I found are on here by Webb Motorsports.
The filter comes oiled and is good for about 10k miles. The filter should of come to you in a sealed baggy so that it stayed oiled. You need to buy a cleaner and oil kit to reoil it in the future.
Old Feb 22, 2006 | 05:03 AM
onasled's Avatar
onasled
Sounds like you had a bad night
Actually the Alta is considered a pretty easy install, and should really only take about an hour at the most.
I believe one nut and bolt, and maybe a screw, do come with this kit, but it's been a long time.
I gather there may have been some frustration in that you needed to have the car running for the next day? Otherwise in this case it's always good to just walk away from the car and come back after a long break.
Hope it works out in the end for ya
Old Feb 22, 2006 | 07:27 AM
etalj's Avatar
etalj
worst thing about the alta is the silicone hose. So badly made.....mine doesn't sit flush on the throttle body...:(
Old Feb 22, 2006 | 07:44 AM
onasled's Avatar
onasled
deleted by me.....
Old Feb 22, 2006 | 07:45 AM
shankrabbit's Avatar
shankrabbit
i'm thinking of getting an Alta CAI in the next week, should I pass on the silicone hose?
could i just make my own?
Old Feb 22, 2006 | 07:52 AM
J0kER's Avatar
J0kER
yea i've seen this b4 too but sum times it jus needs to be pushed in w/a bit more force!
do ya have a pic. of wat it looks like?
MadHatter's Avatar
MadHatter
I have to ask... what instructions DON'T suck at 3AM?
(Not the best time for my best efforts...)
Old Feb 22, 2006 | 07:54 AM
phil3mac's Avatar
phil3mac
I'm a mechanical nitwit but I had managed to install mine in about an hour and a half. However, I had the Webb instructions, which are great. The little instruction page that comes with the intake is useless, IMHO. Also, my MCS was an auto and Alta originally didn't say that the silicone hose needs to be different for the auto, thus I ended up having to return the hose. Now they allow you to specify auto or manual trans. so you get the correct hose. The factory hose clamps are a bit of a bear to refasten, too. You do need to purchase a separate cleaning/oiling kit but, as previously mentioned, the filter does come pre-oiled. Also, be sure to clean the inside of the neck of the filter really good, too, so that it doesn't slip off the airbox. I was always paranoid about that but it didn't prove to be a problem. Unclamping the ECU leads was frustrating for me as those little locking clips were on pretty tight, especially the one closest to the firewall.
In short, step back, get the Webb how-to guide, read it over a few times first, then dive back into it. If I can do it, anyone can.
Old Feb 22, 2006 | 07:55 AM
Dr Obnxs's Avatar
Dr Obnxs
Joker, I"m so bummed...
you've gone to just a head shot in your sig!
Matt
Old Feb 22, 2006 | 07:56 AM
Dr Obnxs's Avatar
Dr Obnxs
Did you call Alta?
They're pretty helpful if you call them up and get them on the phone....
Matt
Old Feb 22, 2006 | 08:17 AM
onasled's Avatar
onasled
Matt
That's what I was kinda saying in my self deleted post above. Not sure why people just don't call the vendor before they posted it this stuff here...
J0kER's Avatar
J0kER
you've gone to juse a head shot in your sig!
Matt
yea u noe it wuz only a matter of time b4 i would be snitched on by all my fans :O
Old Feb 22, 2006 | 08:33 AM
jlm's Avatar
jlm
dr: you can make of the 63 what you will
Old Feb 22, 2006 | 08:34 AM
Dr Obnxs's Avatar
Dr Obnxs
It's just not the same...
Matt
Old Feb 22, 2006 | 05:51 PM
J0kER's Avatar
J0kER
...or large enough
Old Feb 22, 2006 | 05:58 PM
MSFITOY's Avatar
MSFITOY
I'm gonna miss the BIG part of your sig Joker Could you send a copy to me so I can cherish it in private? I'm serious
As for the guy having troubles installing the Alta...let me know when you have that licked...I'll introduce you to Mr. AGS
Old Feb 22, 2006 | 06:02 PM
garretwp's Avatar
garretwp
I installed the silicon hose on my pilo intake (which I am going to modify anyway). There are some things that are a pain to do when installing the hose. I.e. the hose that goes to the front of the car was a pain to reinstall! To get the hose to sit flush and clamp nicely on the TB, you will need to use some pressure to puch it down on the TB while tightening the clamp! All in all, looks really good and is much bigger then the stock! Now on to modding the pilo intake!
Garrett
Old Feb 22, 2006 | 06:25 PM
J0kER's Avatar
J0kER
msfitoy
i dont noe man i might get banned fer such a thin' !!
Old Feb 22, 2006 | 06:27 PM
garretwp's Avatar
garretwp
haha, The AGS is a whole different story! Talk about taking half the car a part!
Garrett
Old Feb 22, 2006 | 06:29 PM
obehave's Avatar
obehave
This was an issue with the early models. I know Andy and I both posted on this years ago. Hadn't heard about it in a while and thought it might have been remedied.
Took some surgery with a box knife but mine ended up setting flush. Took as long to do that as the rest of the install.
Old Feb 22, 2006 | 06:41 PM
MSFITOY's Avatar
MSFITOY
Garrett
It's the right of passage to becoming a manly man
Old Feb 22, 2006 | 06:42 PM
garretwp's Avatar
garretwp
Well I guess that makes you the man of all men!
Garrett
Old Feb 22, 2006 | 07:16 PM
etalj's Avatar
etalj
well i installed my intake in about an hour, and that was being really careful as i was still a noob . And it sat flush then, after some really heaving pushing.
But i took it off to do the BPV recalibration, and when i tried to put it back on, the bstard didn't wanna sit flush anymore. and i am NOT about to disconnect that ram pipe again. I hate that thing.
Elie
Old Feb 22, 2006 | 07:25 PM
kenchan's Avatar
kenchan
should've went with the pilo~! even easier to install.
