Drivetrain ALTA short shifter question
Old Feb 13, 2006 | 10:12 AM
oneM1KE's Avatar
oneM1KE
hey everyone.. i just have a few questions about the alta short shifter and its adjustment options. It says its adjustable, but how exactly do you adjust it? Can you just adjust it at anytime after its installed from the drivers seat? Or do you have to go underneath again, take it out, adjust and re-install? I just figure that i would need a few tries at it to get my prefered position.
Also, if anyone has pictures of its lowest position (40% i think), that will kinda help in getting a visual on how much shorter it may be. thanks a lot!
Old Feb 13, 2006 | 10:30 AM
sanddan's Avatar
sanddan
You can access the adjusting screws by removing the shift boot ring. The main pivot ball can slide along the shift stem and is locked in place with 2 set screws. Lowering the shifter shortens the travel and vise versa. The shorter the throw the more force required to shift, so you just need to find your personal sweet spot.
Dan
Old Feb 14, 2006 | 12:25 AM
oneM1KE's Avatar
oneM1KE
Gotcha! thanks a bunch!
Old Feb 14, 2006 | 12:34 AM
oneM1KE's Avatar
oneM1KE
oh yeah.. one more thing. The alta SS can come with the adapter to use the stock shift ****. if i decide on using the stock ****, and want to change it to an aftermarket one, will i have the parts to do so?.. or is there another adapter for that too?... thanks again.
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
