Drivetrain Stock Header With No Pre Cat?
Old Jan 23, 2006 | 02:53 AM
  #26
willy69's Avatar
willy69
[quote=Dr Obnxs]We all know that the nuts, bolts and springs supplied with the OBX suck. What does that have to do with the design principles? I can go find photos of crappy bellows, but it has nothing to do with whether the bellows restric flow more.
Your post is a perfect example of taking something out of context.
So you go get a better pair of springs, and double nut the sucker. $10 bucks more, and the whole kit would be under $200. (Mine was $185 shipped to my door).
Matt[/quot
read my thread starter and quite causing me greif, the question is does the mod stock header work without the pre cat. thats it nothing else.
cheers
Old Jan 23, 2006 | 02:56 AM
  #27
willy69's Avatar
willy69
Originally Posted by Detonics
Willy69,
Are you talking about cutting the section in the picture below?
yes, i am not sure where i will cut it yet, before or after the pre cat.
cheers
Old Jan 23, 2006 | 04:05 AM
  #28
jlm's Avatar
jlm
a bellows doesn't work well if twisted.
Old Jan 23, 2006 | 06:59 AM
  #29
Bahamabart's Avatar
Bahamabart
Originally Posted by willy69
NICEEEEEEE!!!! THIS WAS WITH ONLY ABOUT 160WHP
CHEERS
Did you read the thread where you got this pic from? The nut or nuts came off. I have over 6,000 miles on a obx header using all stock parts with the exception of the nuts. I am using the copper nuts. The set-up is not cheesy - its very basic and simplistic but it works, if installed properly.
back to the thread - please post pics and any dyno results would live to see them.
Old Jan 23, 2006 | 07:28 AM
  #30
Detonics's Avatar
Detonics
I think you should leave the honeycomb where it is and just cut out everything in the blue box and replace with a pipe. I want to do this mod too.. what do you think?
Here is a guy in Australia who did this mod but he is not longer active... too bad or else he could help us on this..
Old Jan 23, 2006 | 09:30 AM
  #31
Dr Obnxs's Avatar
Dr Obnxs
I'd cut all the way to the flex...
Looking at the posted photo
you can see that the bends after the pre cat are smooth, but restrictive. So it seems that from above the pre-cat to right at the welds right about at the end of the blue box is the way to go. You;ll also have to get a bung for the 02 sensor welded on (I know, pretty obvious).
And Will, what do you expect when you're the one that starts calling other technology "Cheesy"... Way I see it, you opened the door.
Matt
Old Jan 23, 2006 | 11:49 AM
  #32
Detonics's Avatar
Detonics
Ok, you mean the whole part in the blue box below?
Old Jan 23, 2006 | 05:23 PM
  #33
Dr Obnxs's Avatar
Dr Obnxs
Nope. Then you lose the bellows, and there's nothing to give when the motor moves. And somethings gotta give! Go to the base of the ring at the left side of the bellows in the photo above your post. Then you keep the bellows (need it in there), and you get rid of the pre-cat, and the part that looks like it's made of two halves welded into a tube....
If this all works well, it will displace the OBX as the price/performance leader!
Dispite the crap I gave Willy69 , I'm very curious to see how this all works out, Much more stealthy than the OBX with the heat shields in place....
Matt
Old Jan 23, 2006 | 06:48 PM
  #34
willy69's Avatar
willy69
Matt
nice pic, you created my blue print . i think you are probably right about the cut area, it will be easy to add the piece to the main cat.
cheers
Old Jan 23, 2006 | 07:24 PM
  #35
Detonics's Avatar
Detonics
Errghh.. I'm not getting this. Matt, can you copy the picture above and remark which part/ section should be cut. Many thanks!!
Old Jan 24, 2006 | 02:52 AM
  #36
willy69's Avatar
willy69
Matt
great pic, this is exactly where i am going to cut . it should be simple to make the connecting pipe to the main cat.
cheers
Old Jan 24, 2006 | 04:23 AM
  #37
Profpatpending's Avatar
Profpatpending
Realistically what sort of gains can be had from this mod and how will it affect emmissions????
Old Jan 24, 2006 | 08:21 AM
  #38
sfjames2's Avatar
sfjames2
Originally Posted by resipsamcs
SFJames2:
I realize you have no empirical data, but did you notice a difference with the pre-cat removed? What are your observations?
I like it alot man! It makes the Borla race sound a little deeper at idle, pulls harder above 5000, but gets LOUD on it's way to redline, mine is still 6950 or whatever stock is, but I know I draw attention. One more thing I've observed since doing this is a loud a$$ BANG when shifting 2nd to 3rd at redline. ....I think I got flames.
Old Jan 24, 2006 | 08:34 AM
  #39
Bahamabart's Avatar
Bahamabart
Matt
Another option would be to go out and purchase some CHEESY PARTS to connect to the Cat. Sorry couldn't help myself.
I too would like to see what this contributes to HP/TQ.
Old Jan 24, 2006 | 09:15 AM
  #40
Detonics's Avatar
Detonics
Sfjames2,
So, did you cut the section in blue box like the picture above and take a plain 2.5" pipe and weld it to the CAT and after the flange? Am I right?
Old Jan 24, 2006 | 09:16 AM
  #41
Coop d'etat's Avatar
Coop d'etat
For the record, Ive had 4 cars with a spring/nut connection system, all of which are FWD, all over 200hp...and none of them ever slipped on me.
Also...even with an aftermarket high-flow cat (usually between 90-150) the OBX is still 1/2 (or less!!) the price of most cats, and equal to the Megan header after shipping. I for one would still consider that a deal.
Old Jan 24, 2006 | 11:35 AM
  #42
Dr Obnxs's Avatar
Dr Obnxs
Emissions..
Shouldn't effect them at all, unless it's really cold out, but will be illegal (technically, you can't modify squat without exemptions on the parts, even if they make the exhaust CLEANER! Go Figure!) so if your local inspectors are ****, make sure it's all dirty and looks like it came that way from the factory... Maybe stamp Mini on the part?
Matt
Old Jan 24, 2006 | 01:26 PM
  #43
minimc's Avatar
minimc
Some richness flashing-off in the cat (which would've regularly been burnt off in the pre-cat)?
Old Jan 26, 2006 | 09:15 AM
  #44
sfjames2's Avatar
sfjames2
Sfjames2,
Kinda, the guy cut the pre cat right where it meets the flex line. Welded the new piece to the flex line, then right to the area under the bell or skirt looking part of the pre cat. I'll see if I can a picture of it on here tonight. Oh, I think the guy used 3" piece in there, it looks huge!
Old Jan 26, 2006 | 09:19 AM
  #45
sfjames2's Avatar
sfjames2
yup yup. that what I think.
Old Jan 26, 2006 | 11:59 AM
  #46
Detonics's Avatar
Detonics
Pics!!
Old Jan 27, 2006 | 01:01 PM
  #47
sfjames2's Avatar
sfjames2
[ATTACH][ATTACH]Stock Header With No Pre Cat?-dscn1280.jpg[/ATTACH][/ATTACH]
there goes the pictures Dudes. I FINALLY FIGURED IT OUT!!!
James
Attached Thumbnails Stock Header With No Pre Cat?-dscn1277.jpg   Stock Header With No Pre Cat?-dscn1278.jpg
Old Jan 27, 2006 | 01:08 PM
  #48
sfjames2's Avatar
sfjames2
a WAH HAPPEN?
Old Jan 27, 2006 | 04:48 PM
  #49
Dr Obnxs's Avatar
Dr Obnxs
Here you go!
Matt
Old Jan 27, 2006 | 06:31 PM
  #50
Detonics's Avatar
Detonics
Cool...so what's your comment on this mod? Let's hear it....
