Drivetrain New helix13 product: Braille Ltw battery box
Old May 24, 2007 | 08:00 PM
  #101
cooper99's Avatar
cooper99
Another interesting find; the specs on Deka's site claim the ETX20L has 270 cca and the smaller ETX18L has 300 cca. Could someone please remind me what the cca are for the oem battery and the minimum you should have for the MCS?
Old May 24, 2007 | 08:56 PM
  #102
El_Griton's Avatar
El_Griton
I am running two amps at a total of around 700 watts. is this to much to ask from this battery? should I just get the old heavy *** red?
Old May 25, 2007 | 02:06 AM
  #103
motonikki812's Avatar
motonikki812
I must of missed it here somewhere...
How much does the stock MCS battery weigh???
If we are replacing the stocker with an 11 lb'r... Whats the weight savings, and is it noticable to the performance of the car???
I do track and often think I can actually feel and notice the mods I am doing to my car... Will this mod have me hootin' around the twisties??
Thanks for the info, I am stoked on this.
Jasun
Old May 25, 2007 | 06:24 AM
  #104
gnatster's Avatar
gnatster
Yes, this is to much for the smaller battery. While BMW did seperate the circuitry required to run the car from the accesories I thiink yuo will find that there is not oomph in the smaller battery to keep up with the power demands of multiple amps. Caps would need to be installed to prevent damaging the amps and clipping the system.
Old May 25, 2007 | 06:27 AM
  #105
hornguys's Avatar
hornguys
I've had the Braille that I bought from Helix for almost two years and over 35,000 miles and nary a problem.
However I do not have the alarm system.
Old May 25, 2007 | 06:32 AM
  #106
gnatster's Avatar
gnatster
Jasun
If I remember correctly the savings was about 14 lbs. However it's in an odd place. The stock battery is out back and down low. Some feel that the weight savings is not worth the cost and that since the Mini is already so light in the rear it changes to the F/R weight balance to much making the rear a tad bit more willing to swap ends with the front. I found that moving the rear sway bar adjustment from soft to medium on my H-sport 19 mm bar that F/R swapability was negated when using the Braille battery.
Also if possible when you mount the battery place it as far to the passenger side rear as possible. That helps ever so slightly with corner balancing.
Old May 25, 2007 | 07:03 AM
  #107
obehave's Avatar
obehave
Originally Posted by cooper99
I need a new battery and will probably get the Deka w/ Helix case if everyone is still satisfied with their purchase. If not the Deka, the Optima 34R Red Top.
Have to get in line for the bracket. Right Eric
Old May 25, 2007 | 09:28 AM
  #108
TonyB's Avatar
TonyB
I'd have to agree... I wouldn't recommend this swap strictly for the weight-reduction that it affords. That said, I'd do it again simply because it was not the primary driving force behind my decision to do so. I wanted the battery box gone for a custom straight exhaust, and a smaller battery, relocated, was the answer...
I believe my notes have the stocker at 35 lbs, so a 24 pound delta.
Old May 25, 2007 | 03:53 PM
  #109
motonikki812
Thanks for the feedback!
Yes I do think that I appreciate the little extra weight that is out back and down low, around high speed off camber turns.
Around Rainey at Laguna I am amazed that the rear sticks at all! I am keeping my Boat anchor until I do a straight thru exhaust.
The Helix Kit sure looks cool though... If I had it, I would take the carpeted piece off the top of the area and just run it open. Bling Bling...
Thanks, Jasun
Old May 25, 2007 | 03:58 PM
  #110
MSFITOY's Avatar
MSFITOY
Brilliant! Now to ditch my Odyssy boat anchor...
Originally Posted by Helix13mini
Here's a few of the install.
Bottom of box in, fitting snugly*.
It's just a wee little guy, but mighty
Zip it up and you're done
*snugly sounds like something I called my sister at age 13.
Filmy
15
Jun 6, 2023 06:27 AM
UncDeo
Nov 4, 2019 04:08 AM
twriter
Oct 2, 2015 03:14 PM
eliseo1981
Sep 30, 2015 01:53 PM
wildwestrider
Sep 6, 2015 06:18 PM
