Drivetrain Some thoughts on porting Roots SCs..
Good stuff, Matt!
BTW, I would suspect that the "abradable coating" is one that allows plastic deformation, rather than one that has chunks that come off. Then again, maybe the MINI can tolerate a little fiber in its diet.
I am pretty sure that the M62 will not fit, plus new mounting positions would need be fabricated. The idea's been raised before, as has been said, so that probably is enough empirical evidence that it isn't feasible. I personally think that a complete replacement for the SC [with another non-Roots SC thank you!
] is the way to go, if you want dramatic changes in power.
] is the way to go, if you want dramatic changes in power. Joined: Sep 2004
Other SCs...
There are really only two viable other solutions, a cetrifugal and a twin-screw. The first is more effecient, but acts more like a turbo and won't keep our nice flat torque curve (but since the BP valve is there, it doesn't really matter below 3000 RPMs) and the twin-screw isn't cheap. Whipple has some listings for small twinscrews on their site, but the links go to pages under construction.
I'm not sure that the M62 is the way to go, it seems like a big PTIA to get stuffed into our cars. The twinscrews are a nice compact package, so one could get better efficencies without trying to stuff a rather large square peg into a small round hole!
As for sourcing, try wrecking yards and eBay!
Matt
Matt
I’ve had a good look at five assembled MINI superchargers one of them being a 05 model, also two completely disassembled 03 build units, only one 02 build high mileage unit had no flaking of the rotor coating other than the usual wear scuffs. The low mileage 05 model interior case had polished surface swipes and corresponding marks on the rotors without the characteristic shiny lobe scuffs of the early models. That is why I conclude the case surface is being scraped by the later build rotors to a greater extent than the early type of coating.
I don’t think one should lose sleep over the occasional minor bits of glued on rotor coating or case material that may find there way out of the SC but for some really scary looking pictures look here http://www.theoldone.com/articles/damaged%2Dblower/. This is an old example and not representative of the current generation of Eaton’s products.
For some pictures and one manufacturers propaganda you can see the twin screw here http://www.whipplesuperchargers.com/....asp?PageID=65. A Google search will reveal more.
One big difference....
Originally Posted by fishbulb
what is the difference between out Roots-style Eaton & the Twin Screws?
thanks!
-jac
thanks!
-jac
The twin screw compresses as it pumps. this leads to greater effeciencies, but also requires closer tolerance machining.
So the twin-screws are more expensive to make. They also create heat by compressing the charge all the time, even at low engine loads.
It's extra credit for those that want to thing about what this means in day to day driving....
Matt
Matt
Matt
. Means more power down low but also higher wear and tear because of higher IAT. Right?
Ingsoc gets 5 points!
Originally Posted by ingsoc
Ooohh, me! me!
Matt
3) So why doesn't boost keep climing to the sky? After all, each rotation adds more air than the motor can swallow.... There are several answers to this.
3.1) some leakes back because the clearences aren't 0. There are a few thousanths of an inch clearence, and some intake charge squeeks by.
3.2) there is some volume between the lobes of the rotors that gets pumpted backwards, and this is just due to the shape of the rotors. It's a few % of the pumped volume. And note that this volume is filled with boosted intake charge, so the leakage is about twice what you would expect from just looking at the volume.
3.3) as the boost climbs, more molecules can be digested by the motor (there's a larger pressure gradient between the intake and the cylinder, this is why blowers are used), so as the boost climbes, there is a boost level at which the motor can swallow all the air pumped by the blower.
Since the roots SC simply moves air without compressing it, it seems as if the thermal efficiency should drop considerably as the pressure on the downstream side increases. Anyone with info on this? If so, it seems that the best way to increase SC efficiency would be to improve the flow thru the valves & head & exhaust to lower the boost pressure and thus the improve thermal efficiency.
Both will work.
The fact is that the Roots design gets much worse as a function of higher boost and RPM. http://automotive.eaton.com/product/...argers/M45.asp
This shows the behaviour of the M45 vs RPM for temp, drive power etc.
And for the relative contributions to steady state boost levels, I've read (but haven't measured) that rotor-case leakage is a bit less than 5%, reversion is a bit less than 10%, and the rest would be flowing into the head. Since I live a science life, I guess I forget that most people don't think of the ideal gas law any time pressures of gasses are discussed, but I guess I should keep this in mind, as most discussions are about boost (pressure) and not molecular density (absolute pressure divided by absolute temp), which tells you how many molecules are available to burn.
So, the "conventional wisdom" about heads not mattering with boosted motors is just wrong. Anything that gets more air into the combustion chamber has the potential to create more power. Head work definantly falls into this category.
jlms point is right on, if you want the best bang for the buck, run each item at it's most efficeint point. And for the Roots blowers, that isn't at it's redline or at very high pressure deltas.
For those interested in pros vs cons of different SCs, here's a very short description....
http://www.automotivearticles.com/12...Choices_.shtml
If you want to see what a twin-screw has to offer, check this out....
http://www.kennebell.net/techinfo/ge...REWvsROOTS.pdf
Matt
Matt
Navigation & Audio Portable Navigation XL Wiring
mikeandtricie
Sep 4, 2015 01:42 PM
