Drivetrain whistling noise from the engine
Old Dec 8, 2005 | 12:09 AM
Slowride11's Avatar
Slowride11
hey guys,
I installed my Promini CAI about three days ago and i am noticing this really high pitched whistle noise when i barely step on the gas... it goes away when i push the pedal hard.. is there an air leak going on? I made sure everything was tightend down so i don't know why there would be that noise.. it only happens when the gas is press lightly.. fine cruising and fine on harder acceleration
Old Dec 8, 2005 | 05:43 AM
schulzmc's Avatar
schulzmc
Hopefully someone who knows more than I do will confirm this, but what I think you are hearing is the butterfly valve in the throttle body create a whistle as it is open just a little bit. More pedal opens it more fully and the whistle goes away. Very light pedal and it is not open at all. I could hear this before my CAI, but it is certainly easier to hear now.
Old Dec 8, 2005 | 06:00 AM
Wagnbat's Avatar
Wagnbat
The whistling noise is most likely the CAI.
Just like whistling with your mouth, the shape of your lips, combined with the specific throughput of air, results in noise.
Many CAI's whistle, as air is SUCKED in, and there isn't really anything you can do about it, without inhibiting the performance of the cai... Because you would need to inhibit and/or alter the air travelling through the 'lip' of the CAI en route to the throttle body.
Old Dec 8, 2005 | 10:16 AM
The MINITOR's Avatar
The MINITOR
I have the ProMINI intake and the whistle too. I find myself whistling along sometimes.
Old Dec 8, 2005 | 10:43 AM
ted leist's Avatar
ted leist
I believe that this is correct
Old Dec 8, 2005 | 10:49 AM
Slowride11's Avatar
Slowride11
Thanks guys... makes me feel much better.. thanks for the explanation
Old Dec 8, 2005 | 10:51 AM
DrkSilvrMini's Avatar
DrkSilvrMini
The whistle is the intake, you have opened up the intake path so now you will hear more S/C noise and more "sucking" noise. You should hear the whistle coming off my AGS at part throttle .
Old Dec 8, 2005 | 02:03 PM
trickedmotoring's Avatar
trickedmotoring
my alta does the same, after a few hundered miles and i gets dirty, the sound will go away. When it goes away you know its time for a cleaning
Old Dec 9, 2005 | 07:42 AM
jnlee's Avatar
jnlee
hear it all the time,
sometimes I hold my throttle just to hear that 'spot'
woodstudio
Mar 15, 2020 08:28 AM
makg
Aug 21, 2015 02:49 AM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
