Drivetrain How To Cut Down Weight
Originally Posted by MSFIT
Aren't Pure mag wheels like illegal?
More ideas:
Weld the doors shut and take out the latch and door handle parts,
Remove that big chrome gas cap
Run with only three lug bolts (weld the wheels to the hubs maybe?)
Remove the tire valve stem caps!
Originally Posted by MINI Monkey
I think a big weight savings is to make sure the guy driving isn't too over weight. I see huge guy at the autocross talking about their light weight seats or or how removing their rear seats saved 48lb when they could stand to loss 100lbs.
I'm not making fun I just think it is crazy to spend big money on a light weight mods and not take a look at what's mounted in the seat.
I'm not making fun I just think it is crazy to spend big money on a light weight mods and not take a look at what's mounted in the seat.I saw someone mention carbon fiber bonnet and hatch. Can those be painted to match the original body colors? I like the idea of lightweight, but I don't like the black color of the carbon fiber. Makes my car look like a rice rocket.
I heard in washington you can sell your left...umm...male part for like $75,000 or something...
Originally Posted by jggonzalez
$75K for my left dingleball? That's two MCSs with cash (and the right dingleball) left over. Do you have a phone number?
Originally Posted by Eric_Rowland
UTI?? Uni-******** Institute??
:smile:
Is that one of those REALLY dedicated driving schools? :smile:
:smile:
UTI is actually Universal Technical Institute...its a auto tech school thing
No kidding. I plan to lose 20 lbs. by Xmas and it isn't costing me anything!
Drive around with three or less gallons of gas and save about 60 pounds.
Throw the jack and lug wrench away.
Very similar threads were always floating around on Miarta.net.
Most ideas, if taken seriously, will yield a miserable car to drive.
I had a bare bones '77 Rabbit that weighed less than 2000 pounds off the showroom floor. It also only had about 76 HP. The 700 or so extra pounds of "MINI" are welcome.
Now if that Rabbit would have had 168 HP....
And the nose hairs! Oh and donate a kidney.
Originally Posted by RECOOP
That kidney would only save about 125 gm, or roughly 1/4 lb. Keep the kidney and get rid of the rear seats --- 49 lb weight saving
.Or maybe just remove the back seats---------Your probably right....
It would certainly hurt less.
The Carbon fiber can be painted.
You want a diet for the MCS?
Start with unsprung weight (weight not supported by the suspension), and upgrade these parts to lightweight versions. Unsprung weight is generally considered worth four times its weight in sprung weight, meaning dropping 25lbs of unsprung is the equivalent of removing 100lbs of sprung.
Wheels
Tires
Lugnuts
Brake rotors (HUGE gains to be made here going from iron to aluminum or carbon composite)
Calipers
Suspension pieces
Now move to the sprung weight. If weight is a priority, ensure that you ordered your car with minimal options - no HK stereo, Xenon lights, etc.
Start with low cost, and remove the air conditioner condensor, compressor, and control circuitry. Next, the power steering assembly. That should remove 20-30lbs easily, as well as increase power and mileage. The stereo can go, including any amps, speakers, and wiring. Remove the power window assemblies and install manual cranks (will require modification). Actually, all power assemblies not essential to operation of the vehicle can go - antennas, windows, locks, seats, etc.
Next, move to the interior. The entire interior can be removed, depending on your desired result. Carpet, insulation (except at the firewall, trust me), front passenger seat, rear seats, interior trim, dash, and electronics. Replace all your guages with a single digital cluster. Replace your drivers seat with a Sparco carbon bucket (or similar). Remember to go get the seat fitted by the factory before ordering, or you'll regret it.
Now, the final and most expensive options. Replace all body panels with carbon fiber or carbon composite. Composite is stronger and cheaper, but heavier. Replace all glass with Lexan panels. Strip car to frame, strip, acid dip, and powdercoat all chassis components.
If you do all that, you should curb in under 1500lbs.
Very thorough indeed. We've been talking about this in a couple of current threads in the new Road Race forum here, and seeing 2,000 lbs is starting to look unlikely, or at least very difficult. 1,500?!
Nuzzo's MINI's are about as stripped as a MINI can get, and we believe they are at 2,200 or so:
https://www.northamericanmotoring.co...ad.php?t=42340
You're probably right about 1,500, but I see 2,000 as acheivable.
You go acid dip a unibody car held together more with seam sealer than spot welds and let me know how that works out for you... Still no way you're getting anywhere near $1500 lbs.
Great thread guy's....
As for loosing weight on the MINI I'l gone thru it all, and beleive me 2300lbs
is incredibly hard to accheive. My car had every conceivable part removed
and light weight parts added, they included Titanium ceramic brakes, carbon hood and super light weight front control arms, carbon fiber seats etc....
We just built an SCCA racer (ssc class) and the minimum weight was an incredibly porky 3075lbs with driver and almost empty tank
imagine that.
To reach this mandated weight limit, a bunch of free weights had to be bolted to the floor....
Peter
Team M7
562-608-8123
imagine that.To reach this mandated weight limit, a bunch of free weights had to be bolted to the floor....
Peter
Team M7
562-608-8123
Just to add a bit more detail to what Peter said as I recall these were some of the things we did to get his car as light as possible .
All air bag assemblies removed.
Front aluminum Bumper.
Hood switched to CF.
Steering wheel switched to lightweight race wheel.
Cf race buckets.
Sunroof removed and replaced with CF plate.
Entire interior removed.
Exhaust system changed to straight pipe with one super trap muffler.
Battery box removed.
Lightweight motor cycle battery used.
Rear windshield wiper assembly removed.
12.5 lb wheels + light Toyo ra1 205/40 / 17 tires
Front lower control arms VERY light .
Headliner and all plastic interior pieces removed.
Front headlight assemblies removed .
Titanium ceramic brakes .
Rear lower valence removed.
Well off the top of my head these are the major items I can remember . This got us down to 2325 .
Cf race buckets.
