Drivetrain This header for real?
Old Nov 11, 2005 | 07:54 PM
mdsbrain's Avatar
mdsbrain
Saw on ebay for $199
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Nov 11, 2005 | 08:27 PM
eMINI's Avatar
eMINI
The price is certainly right
Can someone educate me just a little about the pro's & cons of a 4-1 header like this one vs. a 4-2-1 header? All I can really remember is that one is better for torque and the other is better for top end. I think. A little help here?...
Old Nov 11, 2005 | 08:58 PM
kyriian's Avatar
kyriian
i think it was 4-1 was hp, 4-2-1 was torque..... but then again, its one or the other
Old Nov 11, 2005 | 09:02 PM
namwob's Avatar
namwob
Yes, but where & how much across the range of rpm?
Old Nov 11, 2005 | 09:12 PM
not-so-rednwhitecooper
i really dont thing it makes that much of a difference in either HP or tourqe, on our cars at least.
Old Nov 11, 2005 | 09:20 PM
namwob's Avatar
namwob
Really? Why not? A hunch I assume
Old Nov 11, 2005 | 09:33 PM
i mean, look at the header.
with something like a V8, the difference between long tube, equal length or shorties is quite different.
with this, theres hardly a change bewteen 4-1 and 4-2-1
just an guess based on my experience with v8's in general
Old Nov 11, 2005 | 09:53 PM
kyriian's Avatar
kyriian
this is almost like the obx header, cept the obx header is even cheaper isn't it?
Old Nov 12, 2005 | 01:34 AM
norm03s's Avatar
norm03s
Headers
4-1 header = redline Hp
4-2-1 header = mid range torque
Old Nov 12, 2005 | 01:52 AM
norm03s's Avatar
norm03s
All Headers are NOT alike
Think about a MINI engine as half a V8, headers do make a difference depending on configuration.
Motorcycles are a good example of a highly tuned engine that responds well to the proper configuration header.
It's all about scavenging exhast gas from the cylinders. Other elements involved are reversion and velocity this is a deep subject so why not research it?
Old Nov 12, 2005 | 05:18 AM
Bahamabart's Avatar
Bahamabart
This is a 4-1 and comes with a Cat or cat substitute and if it does produce additional hp it should be in the top end range. The OBX is 4-2-1 and does not come with a Cat and if it does produce additional hp should be in the lower/mid range.
Both for around 200.00 giving anyone two viable choices . For this kind of money its a worthy consideration for the enthusiast.
I have the OBX header and like what it did for the car. I started with the OBX header and 1-ball exhaust and felt that my mid range was stronger (i.e. pulled stronger). I have since added a cat back exhaust and feel that the range of "pull" has been broadened into the high rpm range. I also feel the car revs freer. All butt dyno of course, I'd post graghs but my butt doesn't have a usb port so I can't transfer the data.
For this kind of money, its worth doing - even if at then end of the day you just learn something. So I say header up!
Old Nov 12, 2005 | 05:44 AM
mdsbrain's Avatar
mdsbrain
Thanks for the comments guys
I'm looking at this header because for heck $200 including a cat can it work?
I think its crazy how many headers cost $700+
I mean yes it looks like a OBX header but this also comes with a CAT:smile: for the same money
Also I figured it would make my exhaust louder
Old Nov 12, 2005 | 06:50 AM
dominicminicoopers's Avatar
dominicminicoopers
That's a resonator they included in their kit. They say to use your own cat if you want/need to keep it.
Old Nov 12, 2005 | 07:53 AM
4-2-1 seems to make the most sense.
the car could use more help in the midrange tourqe department rather than high end HP.
for what its worth, i know Dr Obnxs could probably back me up, with Mustangs,)ro just small Fords) the best all around header just happens to be the Tri-Y, a 4-2-1.
Old Nov 12, 2005 | 08:06 AM
red rage's Avatar
red rage
Hi,
there is NO CAT included, just a resonator .... Still Need a CAT, either stock one or an aftermarket ? one
Old Nov 12, 2005 | 08:51 AM
Bahamabart's Avatar
Bahamabart
[QUOTE=rednwhitecooper]4-2-1 seems to make the most sense.
the car could use more help in the midrange tourqe department rather than high end HP. QUOTE]
My thoughts parallel yours and for that reason I did the OBX header.
PS - thats a dink of a resonator.
Old Nov 12, 2005 | 09:11 AM
mdsbrain's Avatar
mdsbrain
Help me understand. Why would they include a resonator instead of a CAT? So would this mean that this would not simply replace the stock header?
Old Nov 12, 2005 | 09:38 AM
ingsoc's Avatar
ingsoc
I'm pretty sure that the 4-2-1 is all-around better, actually. Because the gas flows out of the head in a pulsatile fashion, the 4-2-1 allows better mixing with less turbulence, because it allows you to combine the pulse waves more evenly if you pair up ports so that one is flowing and the other is not. See my good friend Samurai Will's post in the Randy Webb exhaust thread:
https://www.northamericanmotoring.co...&postcount=241
A 4-2-1 should flow better at basically all rpms, I believe.
Old Nov 12, 2005 | 09:39 AM
ingsoc's Avatar
ingsoc
That is most definately not a CAT. They include it to make it 'look' like a CAT. That way, it can fool the visual inspection that some states require. It's not a street-legal replacement.
Sep 30, 2015 11:25 AM
Sep 30, 2015 10:58 AM
PhoR53
Sep 30, 2015 06:54 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:11 PM
