Drivetrain Question for Tuners
Old Feb 6, 2003 | 02:33 PM
track-toy's Avatar
track-toy
Does anyone have the full alignment specs for track as well as moderate and extreme autocross settings? This info might be posted somewhere but I couldn't find it. RandyBMC? Anybody?
Thanks in advance!
Graham
Old Feb 8, 2003 | 08:17 AM
Zappa's Avatar
Zappa
Yes, I would like this too! Good question.
Rear camber settings anyone?
Thank you!!
Old Feb 8, 2003 | 03:04 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
>>Thanks in advance!
>>Graham
The specs really can't be changed much - it all just bolts up. If you lower the car, you will get a bit more camber.
The toe is neutral in the front and rear. Camber is about .3 negative in the front. Camber is about 1.0-1.5 negative in the rear. These are stock suspension numbers.
You move to about 2 degrees negative in the rear with springs, and .8 or so in the front. These numbers obviously change with compression, but the measurements given were at ride height.
Hope that helps! I hope to have a set of jlm's camber plates next week, and I'll report what's available then.
Randy
donniedarko
Oct 21, 2015 01:15 PM
rob&JCW
Sep 10, 2015 12:06 PM
Robree
Sep 9, 2015 08:43 AM
