Drivetrain Blew up stock intercooler.
Old Nov 5, 2005 | 07:36 AM
autoxguy305's Avatar
autoxguy305
Well believe it or not, i blew the dam thing up. I was cruzing around in orlando, and it was about 50 degrees out. I was reading 18psi in 3rd gear and then suddenlt it dropped to 13 psi. I freaked out as i thought the belts was slipping and about to brake (happened before), so i pulled over and inspect it. NO problems there. Then i turn the car on a listen for leaks. sure enough i look at the intercooler and right at the seam where the end tanks meat the core it split!
I can't believe this happened. I'm going to assume that that part of the in was weak from the welding of two peices together. Anyway, the dealer is going to replace this one, and i'm going to purchase a better A/W core. Has this happened to anyone on here before?
Old Nov 5, 2005 | 07:45 AM
TonyB's Avatar
TonyB
Sort of strange that this would happen prior to your boots blowing first. No, never heard of this b4. Any photos to share?
Old Nov 5, 2005 | 07:49 AM
SpiderX's Avatar
SpiderX
Ditto.......what rpm for 18psi? which pulley?
Old Nov 5, 2005 | 08:00 AM
Cooper_Si's Avatar
Cooper_Si
Im shocked your intercooler has gone like that, id have thought the boots would have gone first running 18psi.
Old Nov 5, 2005 | 11:13 AM
autoxguy305
19% pulley, 7200 rpm. I think it was probly just a defective IC. And as far as the 18 psi, thats just what my autometer says. I know autometer gauges aren't acurate to 1-2 psi. It may only be 15 or 16 psi.
Old Nov 5, 2005 | 11:20 AM
autoxguy305
I'll have pics tomorrow. its a very small split.
Ohh and i have ported snounts.
Colt45Magnus
Aug 27, 2024 05:03 AM
USA-RET
Nov 9, 2015 07:27 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
