Drivetrain DOHC head
Old Feb 6, 2003 | 10:21 AM
RandyS's Avatar
RandyS
I just read that the bore spacing for the Mini/Chrysler engine is 85.5mm. The Mazda Miata 1.6 engine is 86mm. Hmmmmmm........
Old Feb 6, 2003 | 10:53 AM
RandyS's Avatar
RandyS
My God, I just recieved like 8 email about this and I just posted a few minutes ago.
I don't know what would be involved, all I know is that the bore spacing is close which at least put it in the ball park.
Next would be to determine the compatability of bolt holes and oil/coolant passages and what would have to be fabricated. Then a review of the combustion chamber and pistons to see if they are compatible (open/closed chamber) and if they produce the desired compression ratio.
If all that checks out then there is a lot of fabrication ahead and it will not a be a bolt-on. Swapping heads for better breathing is not uncommon though.
This is all just academic anyway as Mini will probably introduce a DOHC in the new few years anyway.
Randy
_________________
<P>'03 Cooper. Sport, Premium, Cold, cloth seats <IMG SRC="http://members.aol.com/FE3N/Mini100502_TN.jpg">
Old Feb 6, 2003 | 10:59 AM
bhcvc's Avatar
bhcvc
The effort required would be far more work (and money) than it's worth. Just becuz the bore sizes match does not meaning anything else will. Guaranteed nothing else will line up, making sealing a major problem (the early frankenstein setups on hondas had leak issues) and you'd end up w/ an extremely unreliable engine. A SOHC engine isn't bad. The main advantage of a DOHC is the independent control of intake and exhaust valves, which, for the most part isn't useful unless you get cams and such, which on a FI car like the S isn't nearly as beneficial as NA.
bhcvc's Avatar
bhcvc
sorry, got a fast trigger finger
NYMADMINI
Dec 14, 2016 02:33 PM
OutMotoring
Nov 16, 2015 07:04 AM
Doc Pain
Oct 28, 2015 07:09 PM
Fordgt4
Oct 10, 2015 10:42 AM
silence2-38554
Sep 28, 2015 12:19 PM
