Drivetrain Uni-Chip ???
Old Oct 25, 2005 | 10:35 AM
koolmini's Avatar
koolmini
Unichip ???
i'm looking for people's opinions on the Uni-Chip
do you like it?
does you kar feel fsater?
anyone done a dyno comparison? (before & after, Map-A & Map-B)
which mapping do you run? (A or B) and why?
if you are you running the B map, what type of gas are you running & why?
etc?
Old Oct 26, 2005 | 09:18 AM
koolmini's Avatar
koolmini
well?
anyone have an opinion/comment/info??
Old Oct 26, 2005 | 09:25 AM
MINIclo's Avatar
MINIclo
7th Gear Gal
I like mine fine, kool. I've been running it on Map B since its install in May at The Dragon. Combined with the 15% pulley, it makes Wanda go ZOOM!
I'm thinking that when I get home next week, I'm going to switch to Map A just to see if there's any difference in performance or in gas mileage.:smile:
My butt dyno says Wanda is much faster!
Clover
Old Oct 27, 2005 | 01:39 PM
Minzilla's Avatar
Minzilla
Hey Kool
I have had it for sometime, ran it on the High Octane map, (can never remember which one that is other than supposed to be the leanest AFR and for 100 octane, never had any problems until I added an M7 /Webb 63MM throttle body and at the same time the 2% oversize light weight crank pulley at the same time, within 100 miles I threw a SES light.
The code threw while cruise control at 75mph, it was a lean condition bank #1, done it twice, so I switched back to the 93 octane map, (no red dioide light). Havent't driven it since, so I don't know if that will solve the lean condition or not.
I have asked Randy about this and await his reply. My impression is that this is a compatibility issue between the new software V 41 and BB throttle bodies in common, and which hasn't been sorted out yet?
From what I know, I think this is the best chip out there, although that statement will surely start opposing views.
But it is a piggy back system, can be mapped specifically to your mods, and is "reprogrammable and tuneable". Plus it only takes a few minutes to remove when taking the car to the service center
You will feel the difference, I have not Dynoed but others have and the gains are dependent on what other mods have been done
Hope that helps
Old Oct 30, 2005 | 10:51 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
We need to remap you Minzilla. I have a new map for the TB and V41.
Randy
Old Oct 30, 2005 | 02:45 PM
Minzilla's Avatar
Minzilla
I love you man! :impatient :smile:
Old Oct 31, 2005 | 05:08 AM
koolmini's Avatar
koolmini
does anyone else with the ubichip have a problem with the DSC turning it's self off, sometimes? (like every 10 starts) ?
Old Oct 31, 2005 | 05:14 AM
cooldaddy's Avatar
cooldaddy
I have the unichip on my car. I like it. Car feels faster & more responsive but I don't have dyno results/comparison (might have that soon though). I run the B map with standard 91 oct. gas. It has never resulted in an SES light and I've never had the DSC change on me...
Old Oct 31, 2005 | 08:40 AM
welshmenwillnotyield's Avatar
Kool, I PMd you earlier, but your post today has prompted this response. I have the UniChip and noticed when it was a week or so old, that the DSC and SES lights came on. I asked Ryephile about it and he said that the chip just needed to acclimate itself to the system. My UniChip has been on my car since the Dragon, in May, but the lights went "out" in early June and I've had no problems since.
WMWNY
Old Oct 31, 2005 | 08:52 AM
onasled's Avatar
onasled
Before you have Randy do a map for your Unichip, you should call them directly and see if there is a Unichip tuner near you. That's what is so great about this system is that in can be so finely tuned.
I have an Excelent tuner near me and I gat mine retuned whenever I make significant changes.
Unichip is a great system, but not offering the softwear to the owners of one is a big drag.
Old Oct 31, 2005 | 08:54 AM
koolmini's Avatar
koolmini
WMWNY
3000+ miles and still waiting for the lights to go out
Old Oct 31, 2005 | 09:01 AM
NekoWoman's Avatar
NekoWoman
From: Fulltime RVer - R53 towed behind a vintage 1979 35' MCI MC-5C Saudi
I've had this sensor pair light up a couple of times... it may be due to the chip or it may be unrelated. For me, it was my steering angle sensor that failed. The dealership diagnosed it with the fault readings even though the lights shortly disappeared. See my old thread...
Old Oct 31, 2005 | 11:44 AM
TonyB's Avatar
TonyB
Greg, curious, but was yours tuned on their unique dyno (direct to the hub), or was it while driving as with Bob, or SpiderX?
Old Oct 31, 2005 | 02:56 PM
onasled's Avatar
onasled
Direct to the hub.
Old Oct 31, 2005 | 03:03 PM
TonyB's Avatar
TonyB
Cool, thanks. I'm due fairly soon, along with an alignment a corner-balance. Refining the set-up...
Old Oct 31, 2005 | 03:06 PM
red rage's Avatar
red rage
The only downfall is the INABILITY to increase the redline, rev limiter
I have had some CEL issues, poor idle with the large TB as well
Old Oct 31, 2005 | 03:22 PM
jlm's Avatar
jlm
sled...your videos keep me going thanks.
Old Oct 31, 2005 | 03:28 PM
SpiderX's Avatar
SpiderX
Find a good Unichip tuner
Old Oct 31, 2005 | 03:33 PM
cooldaddy's Avatar
cooldaddy
what we need is Randy Webb with his own dyno...
Old Oct 31, 2005 | 04:21 PM
What fuel map are you using? I'm on the lowest octane map and like I said, the lights were a bother until the chip and the computer figured one another out. I suppose I may have put around 500 miles on it til it returned to normal. You might contact Ryan or Chad and get their input.
Old Nov 1, 2005 | 10:00 AM
gt5816v's Avatar
gt5816v
Sounds like you need a power supply update on the plug and play harness. Call Randy at Webb and he'll get you squared away.
N2MINI
Jun 30, 2008 06:10 PM
CAP49
Jan 19, 2008 09:17 AM
MiNiBeamer
Apr 30, 2006 10:40 PM
