Drivetrain How the MCS Engine Makes Power
Old Nov 3, 2005 | 10:59 PM
  #26
Tüls's Avatar
Tüls
Turbius Maximus
Originally Posted by ingsoc
Let's all just calm down and enjoy the coming winter weather! Colder air means MORE POWER, right? Let's burn some rubber, boyyyyyeeeeeZ!
that's right...here in arizona we call it BOOST weather...which is about 8 months long...give or take
on a side note great stuff Andy and all who are contributing...nice to see someone trying to properly educate the forum. insted of filling there heads with bubble gum theories and lolly pops from quarter machine type toys for the cars
Old Nov 4, 2005 | 04:17 AM
  #27
jlm's Avatar
jlm
here is a tidbit:
the mini has been shown to be hp limited by the following:
pistons: above 300hp and they can blow ring lands; some have done it above 250 hp. not a detonation or heat problem, more a cylinder pressure problem and a piston design/metal strength issue. with the right pistons, 30psi is reachable.
fuel delivery: right around 300hp, the stock pump and fuel lines cannot keep up. the 400+hp monsters have a complete replacement system.
sc: ultimately, this should go, to be replaced by a turbo only. here hp is going to be reaching for 500+hp.
rpm: sooner or later, valves are going to float and the hydraulic adjusters are going to fail (there are reports of 8,500 rpm minis out there, but only rumors) and rod loads will get excessive, but the big hp nmbers are so far not revving high.
cylinder head: compared to a Honda, this thing is a joke. It is amazing 400+hp can be squeezed out of it. Hondas use twin cams, have no hydraulic adjusters, much larger valves and ports and room for higher vlave lift.
displacement: the bores are too close to allow over-boring; I have again heard rumors. but have never seen a stroker kit..(it needs about 5/8" stroke increase to reach 2 liters.)
Old Nov 4, 2005 | 04:50 AM
  #28
SpiderX's Avatar
SpiderX
Originally Posted by jlm
here is a tidbit:
Great stuff...thanks for the info
Kimolaoha
Jul 5, 2023 01:04 PM
minipopkart
Aug 13, 2015 05:22 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
PatrikKN
Aug 5, 2015 09:10 PM
