Drivetrain Fuel Pressure Test
Old Sep 29, 2005 | 02:02 PM
Paul Webster's Avatar
Paul Webster
Fuel Pressure Test
Set up a guage today and found the following;
42psi at idle
WOT through 1st 2nd 3rd 57psi dropping to 54psi on gear change.
Will hopefully try it with the nitrous tomorrow
Old Sep 29, 2005 | 02:32 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Did it change at all as you accelerated from idle to redline or was it a steady 57 psi?
Old Sep 29, 2005 | 10:30 PM
Paul Webster
As soon as you touch the throttle it goes from 42 to 57 quicker than the eye can see I presume it must sense you touching the throttle and increases the voltage to the pump accordingly.
I have got an old data logger off a Pro Mod car which I will fit on for next season, just running out of time at the moment.
Old Sep 30, 2005 | 03:15 AM
jlm's Avatar
jlm
isn't the fuel presuure regulator vauum controlled?
Old Sep 30, 2005 | 06:11 AM
andy@ross-tech.com
What I'd like to know is if you are driving down the road, say in 3rd gear, and you floor the throttle and keep it to the floor - does the fuel pressure stay at exactly 57 psi at 2,000 rpm, 3,000 rpm, etc. all the way to redline?
Old Sep 30, 2005 | 08:17 AM
ingsoc's Avatar
ingsoc
Isn't that easy to test, Andy?
Old Sep 30, 2005 | 08:18 AM
andy@ross-tech.com
Yep, if you have a fuel pressure gauge hooked up and visible while you are driving.
Old Sep 30, 2005 | 10:18 AM
ingsoc's Avatar
ingsoc
BIM-COM logging?
Old Sep 30, 2005 | 10:24 AM
RECOOP's Avatar
RECOOP
I'll let you know later this morning...
Old Sep 30, 2005 | 10:44 AM
Paul Webster
57psi all the way Andy if you've your foot flat to the floor
Kimolaoha
Jul 5, 2023 01:04 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
David.R53
Sep 1, 2015 06:49 PM
Sep 1, 2015 03:36 PM
