Drivetrain Blew UP!
Old Sep 29, 2005 | 05:28 PM
  #26
Bisch's Avatar
Bisch
I took a Carrera 4S the other day! Real fun.
Old Sep 29, 2005 | 05:40 PM
  #27
SRTech's Avatar
SRTech
pundit: A source of opinion; a critic: a political pundit.
Old Sep 29, 2005 | 07:13 PM
  #28
spillman's Avatar
spillman
Well guys I think it may just be a burnt valve. I did a comp test today and I saw 50psi. I can't wait to pull the head off this weekend. The moment of truth awaits!
Also I was running stock fuel pressure with a bone stock head. And I am running an open header right now also. The thing sounds nasty idling. I hope when I put a cam in the head it will sound like it does now at idle.
Old Sep 29, 2005 | 07:25 PM
  #29
TonyB's Avatar
TonyB
Great news on the compression check! Indeed, please share what you see with the head removed... Photos would be most cool
Old Sep 29, 2005 | 07:48 PM
  #30
namwob's Avatar
namwob
Ball-o flame out the tail pipe. Exhaust valve
Old Sep 29, 2005 | 10:39 PM
  #31
Paul Webster's Avatar
Paul Webster
You got to admit the engine does bloody well to handle all this abus eyou lot give it when you consider that the camshaft and head is the same one found in the natuallly aspirated cooper and the one(uk).
Sounds like more exhaust duration on the cam is needed to me, does anyone know what a stock head flows???
Old Sep 29, 2005 | 11:30 PM
  #32
J0kER's Avatar
J0kER
stroke it!! ....cant go wrong*****if its possible
20k huh
ever had a stroker motor b4??
the piston rings on minis aaarrr mighty!!
what belts R u using??
Originally Posted by spillman
I had about 20,000 miles with the nitrous on. I don't think the 23% caused this. The added boost was fine it was just the overall cylinder pressure from the 75 shot with 20lbs of boost. I had several people tell me the max for stock pistons is around 250whp. I guess I just got lucky and it lasted this long.
My supercharger is still working awesome. But it does have a healthy appetite for belts.
Old Oct 5, 2005 | 09:21 PM
  #33
spillman's Avatar
spillman
Today's results were bad in ways but good in some. Cylinder #1 is missing a ring land and #3 is almost gone. The head is fine and so are the valves.
Since the stroker kit hasn't been released yet I am just going with the company's 650hp pistons and their 8000rpm head with a big freakin cam. If you don't know what company I am talking about then just look out for a carbon fiber MINI in the high 9's or low 10's this weekend.
Old Oct 5, 2005 | 09:40 PM
  #34
JeffS's Avatar
JeffS
Why the secrecy?
You couldn't possibly be referring to the Fireball... oh what's his name... and crew?
Old Oct 5, 2005 | 09:41 PM
  #35
spillman's Avatar
spillman
Im just gettin kicks out of getting you guys all worked up.
Old Oct 5, 2005 | 09:57 PM
  #36
eMINI's Avatar
eMINI
Tisk, tisk, tisk...
Old Oct 5, 2005 | 11:00 PM
  #37
Paul Webster
Hey Spillman I'm not out till next weekend
Old Oct 6, 2005 | 02:04 AM
  #38
Cooper_Si's Avatar
Cooper_Si
Thats going to be awesome
Old Oct 6, 2005 | 02:40 AM
  #39
Tüls's Avatar
Tüls
Turbius Maximus
Old Oct 6, 2005 | 04:09 AM
  #40
jlm's Avatar
jlm
yours is the fourth I have heard of that has lost a piston land; Hubie, El, Maxiumus, all pushing 250+whp. As expected, seems like the weak link when pushing combustion pressure and temps.
Old Oct 6, 2005 | 06:18 AM
  #41
Paul Webster
Jim does that mean I can spray it another 40 with no probs
Old Oct 6, 2005 | 06:34 AM
  #42
jlm's Avatar
jlm
it rains so much in GB it acts like water injection anyway, so sure.
Old Oct 6, 2005 | 07:11 AM
  #43
spillman's Avatar
spillman
Go two stage and you will be flying.
Old Oct 6, 2005 | 08:53 AM
  #44
Paul Webster
It is the end of the season so I'll see if i can join the piston destroying club
Spillman what jet sizes / fuel pressure are you running??
Old Oct 6, 2005 | 09:45 AM
  #45
mybroscoop's Avatar
mybroscoop
Yeah if anyone is considering a twincharged car, i would suggest upgrading pistons and rods. There are a couple sources for pistons and i know crower makes a nice forged rod for the MINI. Better to do it now then have something blow up and possibly cause other damages later.
Ben
Old Oct 6, 2005 | 11:40 AM
  #46
dominicminicoopers's Avatar
dominicminicoopers
How do you do a compression check?
Old Oct 6, 2005 | 12:04 PM
  #47
Tüls's Avatar
Tüls
Turbius Maximus
with the right tools......lemme know we can do it...but it is most accuarate when the car is cool
Old Oct 6, 2005 | 12:29 PM
  #48
dominicminicoopers
Anytime. I'd like to get it checked sooner than later.
Can you explain the process and tools needed to do something like this with the MINI?
Old Oct 6, 2005 | 12:36 PM
  #49
Tüls's Avatar
Tüls
Turbius Maximus
what do you mean with the Mini...it's a motor...come on!!...the mini is NO different...anywho...you just need a Compression Tester....Google it
Old Oct 6, 2005 | 12:41 PM
  #50
spillman's Avatar
spillman
If you are not running more then 400whp rods are not needed. Only pistons will do just fine.
I am not sure what size jets I am runing I will have to look it up. I am tapped into my test port on my fuel rail, so the pressure is just whatever the stock FPR is set at.
