Drivetrain Thump sound coming from below E-Brake area..Help?
Old Sep 26, 2005 | 07:35 AM
Boludo's Avatar
Boludo
I have a 2005 MCS with about 3k miles. When I begin to accelerate I hear and feel a loud thump that seems like it's coming from below the E-Brake area. Any ideas what this could be?
Old Sep 26, 2005 | 02:46 PM
Bisch's Avatar
Bisch
Most likely a loose front exhaust hanger. I've broken two...
Old Sep 26, 2005 | 03:50 PM
Boludo's Avatar
Boludo
I went under the car and checked what I could without taking anything off and grabbed the exhaust and tried to move it and everything seems tight except without taking off the heat shield, I can't see much. Would I be able to see the exhaust hanger without taking anything off. Because I checked what I could and it seemed fine.
Old Sep 26, 2005 | 08:12 PM
YYC's Avatar
YYC
Are you sure it's not just the ABS self-test?
Clunk
Old Sep 27, 2005 | 07:25 AM
XTREEM's Avatar
XTREEM
I have the same problem with my 02, spent heaps of time trying to find the problem with no luck, You would swear the exhaust is hitting the floor under the drivers seat area, but its nowhere near it, The only thing I can find is the engine moves heaps on the engine mounts
Old Sep 27, 2005 | 09:50 AM
Boludo's Avatar
Boludo
That is EXACTLY what is happening. So is it the engine that's moving that's making it. Does yours still do it.
Old Sep 28, 2005 | 03:24 AM
XTREEM's Avatar
XTREEM
Yes mine is still doing it at the moment, the car is off the road for another reason, so I havnt sorted it out yet, Got a feeling its the gearbox mount (near the throttle body) thats the culprit!!!!
It has slowly got worse over time and has started doing it on deceleration and reversing is also bad.
John.
Old Sep 28, 2005 | 07:45 AM
Boludo's Avatar
Boludo
I have the dealer looking at mine right now, so i'll let you know what they say about mine.
Old Sep 29, 2005 | 06:22 AM
XTREEM's Avatar
XTREEM
Good keep me posted
Old Sep 29, 2005 | 12:18 PM
havnap's Avatar
havnap
Coordinator :: Metroplex MINI
My 03 MCS did that and it was some bolt that had fallen off on a shield or something...it was an awful noise. They fixed it up quick..I hope that's all you have.
Old Oct 1, 2005 | 07:03 AM
XTREEM's Avatar
XTREEM
Any update on this yet???????????????????????????????
Old Oct 1, 2005 | 07:41 AM
Boludo's Avatar
Boludo
Dealer said that whoever installed the full Miltek exhaust did not do it correctly. They tried to fit it in the stock hangers which doesn't work to well so he said that that is the noise that I'm hearing. So once I get that fixed I'll update again to see if that's really the problem but It probably is.
Old Oct 1, 2005 | 08:00 AM
XTREEM's Avatar
XTREEM
OK good luck, mine is the standard exhaust so it must be a different problem
alistaircookie
Oct 8, 2015 10:52 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
makg
Aug 21, 2015 02:49 AM
damncajun
Aug 17, 2015 08:25 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
