Drivetrain Cosworth MINI Finally Back from the Dyno
Old Oct 6, 2005 | 07:10 AM
  #76
ingsoc's Avatar
ingsoc
The road is different from a load-bearing dyno. The road will obviously provide a somewhat uniform resistance to your tires. A load-bearing dyno gauges the load on it, but will vary the pre-load/resistance on the rollers. It does this, as I understand it, amongst other reasons, to protect itself from being spun wildly. Thus, on-road acceleration tests are PERFECT gauges of 'area under the curve' while dyno acceleration tests are affected by a computer-determined variable, the load on the wheels. This changes from run to run. I hope this helps.
Originally Posted by 62Lincoln
I'm confused. Why is it okay to do this:
But in Randy Webb's pulley eval thread, when he wrote this:
Here are the acceleration numbers:
3rd gear
Time from 3500 to 6000 RPM
Before: 7.5 seconds
After: 6.6 seconds
That is the average of five runs in each mode. The times were recorded using a Rubic stopwatch.
Andy wrote:
That's a 14.3 % difference in horsepower, or 25 WHP on a 175 WHP car. I have trouble believing that sort of gain, even with a crank pulley that has no mass at all.
When Randy performed actual dyno tests that showed a differential in time (averaged over 5 attempts), the results were dismissed.
But isn't the same sort of calculation being performed with Andy's comparison? Except it's a calculation based on one dyno run, not the average of several? Isn't this the same number that was dismissed in Randy's eval?
I'm confused, help!
Old Oct 6, 2005 | 07:18 AM
  #77
J0kER's Avatar
J0kER
hmmm...
where is this 'thread' u mentioned?
whats it tittled?
3rd gear
Before: 7.5 seconds
After: 6.6 seconds
I'm confused, help!
Old Oct 6, 2005 | 07:22 AM
  #78
62Lincoln's Avatar
62Lincoln
whats it tittled?
Joker, it's here: http://store.webbmotorsports.com/for...er=asc&start=0
Old Oct 6, 2005 | 07:24 AM
  #79
62Lincoln's Avatar
62Lincoln
Ingsoc, are Andy's calculations from a quarter mile thread, or something like that? As opposed to dyno numbers?
Old Oct 6, 2005 | 07:39 AM
  #80
ingsoc's Avatar
ingsoc
No, he data logged the dyno runs.
Old Oct 6, 2005 | 07:47 AM
  #81
k-huevo's Avatar
k-huevo
Nice try in post #76 ingsoc but the DynoJet is not a true load bearing dyno. http://www.germanmotorcars.com/Dyno_...0inertia_1.htm
Old Oct 6, 2005 | 08:06 AM
  #82
CooperSS's Avatar
CooperSS
Originally Posted by spillman
Sure, my next question would be what was the air temp and humidity on both days these numbers were recorded?
If you look at the first dyno sheet on the first post it lists the conditions for both runs. To save you the trouble of going back and reading the first post I will reiterate them here.
Base run: 68.68 degrees F, 29.84 in-HG, Humidity 24%
Best run: 81.11 degrees F, 29.76 in-HG, Humidity 28%
Bill
Old Oct 6, 2005 | 08:09 AM
  #83
spillman's Avatar
spillman
Bill
Sorry I made my question a little unclear. I was refering to the runs with and without race gas.
Old Oct 6, 2005 | 08:22 AM
  #84
CooperSS's Avatar
CooperSS
Ok, I understand.
Straight 91 Octane 197.95 WHP: 77.73 degrees F, 29.80 in-HG, Humidity 32%
Race Gas Mix 195.95 WHP: 71.68 degrees F, 29.73 in-HG, Humidity 50%
Bill
Old Oct 6, 2005 | 11:06 AM
  #85
62Lincoln's Avatar
62Lincoln
Originally Posted by k-huevo
Nice try in post #76 ingsoc but the DynoJet is not a true load bearing dyno. And yes, on an inertia dyno the car wheels have to turn two heavy drums. http://www.germanmotorcars.com/Dyno_...0inertia_1.htm
Keith, how's your car coming along? Anyway, based on your quote, I'm back to square one. Help!
Old Oct 6, 2005 | 11:28 AM
  #86
ingsoc's Avatar
ingsoc
Keith is saying the dyno used is not load bearing. I did not know this. But, Alta still said that dynos change the resistance based on different factors, so I believe that the fact is that you can't compare time-to-speed on the dyno. That is what they said, and I've read similar information somewhere or another. Keith didn't refute what Alta said. I too am waiting for an authority. Again, have a great day everyone.
Old Oct 6, 2005 | 02:10 PM
  #87
CooperSS's Avatar
CooperSS
Originally Posted by andy@ross-tech.com
I calculated torque from the change in speed over the change in time. The numbers are a bit off (+/- 2 lb-ft or so) from what the dyno showed due to smooth, rounding, and sample rates, but the finishing order should be the same:
1 Bob Nigbor 183.3 lb-ft (181.8 peak whp)
2 Mike Leggit 163.3 lb-ft (191.6 peak whp)
3 Tamoosh 161.6 lb-ft (179.8 peak whp)
4 Dave Chen 157.6 lb-ft (169.4 peak whp)
5 Cosworth 157.2 lb-ft (201.8 peak whp)
6 Jason Partin 148.6 lb-ft (168.5 peak whp)
7 Robert Works 148.5 (171.7 peak whp)
Andy,
An interesting comparison would be the Max Mass Airflow figures from your data sampling.
Can you post that?
Bill
Old Oct 6, 2005 | 02:36 PM
  #88
k-huevo's Avatar
k-huevo
Here are some observations I’ve made doing the calculation using personal data collected on an inertia dyno (DynoJet), load bearing dyno ( Mustang), and WOT 4th gear on the street. The equation is closest to matching the DynoJet numbers for my torque, my acceleration times were the fastest on that dyno as well. I was much slower accelerating on the Mustang and the end numbers from the equation were further off. On the street, forget it, I was a slug and it sure didn’t feel that way at the time.
It seems to me that calculations done in a controlled environment (dyno shop) with the same measuring device (onboard diagnostics) and the same treatment (equation) applied to all participants would yield the best chance of internal validity. I don’t see how this can be considered an evil plot. We all have confirmation biases as a dimension of personal constructs, sometimes it helps to look at things objectively. I think the data shows differences not winners and losers.
Bill, the air mass numbers would be an interesting comparison, objectively speaking:smile:.
Old Oct 6, 2005 | 03:09 PM
  #89
RoyalGrayMINI's Avatar
RoyalGrayMINI
BEWARE: Opinion/Commentary Below. And it may be off topic to the current statuss of this thread
***BEGIN
I like the sound of that... differences, not winners or losers.
It makes me wonder, after seeing the first version of this thread topic, if there will ever be satisfaction that there ARE differences rather than "winners vs losers".
I cannot find the logic where one would fight so hard to negate a system, product, person, thing or service.
Coming from a tuning background, - Rolling with Vtech's, V8's, Sideways Slidestars, and now the MINI (well, starting to roll MINI Style as soon as it arrives) I've seen this same sort of thing happen in every community. Granted some more than others. Some less. I was hoping that this would be one of those "less than others".
Nothing seems substantiated enough for huge and heavy arguements. A hp her a hp there, +/- a couple torque pts... Whaa Whaa
The basis I feel, with this tuners community is that we need to do what WE feel is correct. Be it a Cosworth (which I'm diggin') or JCW or whatnot. If we feel there are valid advantages to our decisions as consumers, no one.... NO ONE, should create a turbulant arguement in regards.
Expressing and sharing data is one thing, which is very valid, but when you inject a personal agenda, opinion, "your ideals", into the data shared... You Flaw the data.
**** END
Now back to the discussion.
Old Oct 6, 2005 | 07:28 PM
  #90
isellem's Avatar
isellem
Of course, the valves didn’t create the difference alone . My point was/is “other factors manipulated in concert with the larger valves” create a possible trade off or probable gain.
Valves opening sooner have to do with cam lobe profile or degreeing the camshaft via an adjustable sprocket and I’m not aware of how a change in valve spring might facilitate earlier opening.
Damn this rural dial-up can be frustrating by the time I process my reply, I’m already behind because of all those very nice, but too large for my dinky throughput, pictures.
your gain in horsepower was not from bigger valves... it was from a ported head and possibly larger valves... i myself have done testing and my car with a ported head and stock valves has flowed as much if not more than other cylinder heads and has made more power down low...
just my $.02
Old Oct 6, 2005 | 09:13 PM
  #91
RECOOP's Avatar
RECOOP
More in-gear acceleration times (ranked from fastest to slowest):
3k-4k
1 Bob Nigbor 1.772467527
2 Tamoosh 2.029757192
3 Mike Leggit 2.079485931
4 Dave Chen 2.096348363
5 Cosworth 2.103638261
6 Robert Works 2.223386673
7 Jason Partin 2.22884801
4k-5k
1 Bob Nigbor 1.842807356
2 Mike Leggit 2.000836206
3 Tamoosh 2.067704005
4 Cosworth 2.080506331
5 Dave Chen 2.106076667
6 Jason Partin 2.196385933
7 Robert Works 2.228617325
5k-6k
1 Bob Nigbor 1.921279301
2 Mike Leggit 2.057320782
3 Tamoosh 2.063780155
4 Cosworth 2.069408896
5 Dave Chen 2.177570489
6 Jason Partin 2.232134713
7 Robert Works 2.38586033
6k-7k
1 Bob Nigbor 2.064840188
2 Mike Leggit 2.080236452
3 Cosworth 2.106465594
4 Tamoosh 2.205212907
5 Jason Partin 2.601890374
6 Robert Works 2.607119855
7 Dave Chen 2.759495512
Andy,
Many thanks for the analysis. The next time there's a dyno event, I'll try to get some more Bim-Com data. I find it very interesting that the M7 modified car had the equivalent of an 18% pulley, and showed some pretty poor times going from a-to-b (rpm). Also, what is your objective take on the poor torque results for the M7 modified vehicle? Thanks...
Old Oct 6, 2005 | 09:24 PM
  #92
RECOOP's Avatar
RECOOP
Perhaps this has been addressed elsewhere, but I had trouble finding info.
1. What is the actual warranty on an M7 kit like the one installed in Bill's car?
2. If there is a warranty, is it verbal or put in writing?
3. Furthermore, since Cosworth did the rework of the stock head, do they provide any warranty?
4. Finally, if M7 has to replace a defective part or add their recommended modifications to a part they deemed sub-optimal, do they also pay for labor?
Old Oct 6, 2005 | 10:18 PM
  #93
Dr Obnxs's Avatar
Dr Obnxs
No Point....
Anyone who says anything gets reamed a new one. Why post? Mod the way you like, share if you wish, and drive and be happy.
Matt
Old Oct 6, 2005 | 10:30 PM
  #94
zrwon's Avatar
zrwon
Future Cosworth Stage 2 owner
I'm planning on getting the Cosworth Package in Jan 06, I will store the car for the winter and will get on it in Jan.
I almost bought the JCW package but they wanted $7200 plus $1200 for the install and they send back all my original parts, even the exhaust and pulley.
That's in Canadian $$ of course.
But the Cosworth deal will save me money and give me more power and will have a rare car with a name and reputation that will last a long time.
I'm sure there are good tuners out there but all I was looking for was a good alternative to JCW that I can install myself, JCW has to be done by the dealer, they won't let me install it.
Also I can save enough money to pay for my LSD unit, it's a no-brainer.
I'm not looking for the most hp, as long as I have more than the JCW, that's all I want.
I'd pay $50 per driver to see a street race between a JCW and a Cosworth though, hopefully this will be tried before Jan. 06.
Old Oct 6, 2005 | 10:48 PM
  #95
J0kER's Avatar
J0kER
right-0n!
Old Oct 6, 2005 | 10:58 PM
  #96
Dr Obnxs's Avatar
Dr Obnxs
Tsk tsk tsk....
Are you really going to solicite an illegal act? I can think of some that are more fun that watching a race!
Matt
Old Oct 6, 2005 | 11:14 PM
  #97
zrwon's Avatar
zrwon
Matt
Most people want 1/4 mile numbers, I'm more looking for a 0-60 mph time and so far nobody can answer that one, that's why I'd like to see that before I buy mine so I'll have an idea as to what I'm paying for.
MCS 0-60: 6.8 sec.
JCW 0-60: 6.6 sec.
MCS Convertible 0-60: 7 sec.
MCS M7 Stage 2 0-60: sec.
(My ZR1 0-60: 4.1 sec. ) Oups!, did I throw that in there? wrong Forum, sorry
Old Oct 6, 2005 | 11:24 PM
  #98
Paul Webster's Avatar
Paul Webster
My Mini is 4.32 based on my 1/8 mile et and speed. That produced 231 dragstrip fywheel hp at 2510lb
http://www.wallaceracing.com/0-60_equation.php
Old Oct 7, 2005 | 12:05 AM
  #99
Rally@StanceDesign's Avatar
Rally@StanceDesign
MCS 0-60: 6.8 sec.
JCW 0-60: 6.6 sec.
in all honesty....if 0-60 is your main concern, you bought the wrong car. Sorry to say it, but drag racing a MINI seems kinda silly to me
(not aimed at you zrwon....i mean in general)
Old Oct 7, 2005 | 07:05 AM
  #100
zrwon's Avatar
zrwon
I can't sit here and type forever so everybody can understand my thoughts, I'm not trying to get the best 0-60 mph, but YES I DO WANT TO KNOW WHAT IT CAN DO, what's wrong with that? did you ever read a car magazine, even a VW diesel they will tell you what it does, a Dodge Mini van they will tell you what it does, every single car I read about have that spec, why is it a sin to ask what this car can do if I'm willing to spend $5000 on it???:impatient
I only want to know, I do have a ZR1 to drag race and I DO NOT WANT TO DRAG RACE THE MINI, but if all car manufacturers, even trucks can give me that info, I think in this case it's a very simple question that deserves and answer.
