Drivetrain Better SC?
Old Sep 8, 2005 | 02:52 PM
  #76
ingsoc's Avatar
ingsoc
Originally Posted by andy@ross-tech.com
Here's some dimensions comparing the MP45 and MP62
Looks like the body cross section is the same, just different length. Of course, you'd need to find an alternate way to circulate coolant.
Great catch... Yeah, I guess length is the issue, then. But, I know that mounting locations and plumbing would for sure need changing. Plus, the might be too long to be practical??
Old Sep 8, 2005 | 03:02 PM
  #77
andy@ross-tech.com's Avatar
andy@ross-tech.com
Originally Posted by ingsoc
PS: The other thing to remember is- the bigger the SC, the more parasitic loss. The stock blower already robs too much [%-wise] down low for my taste. I cannot imagine the lag with a SC for an engine twice ours' size. [I think that the 62 is for V6's around 4 litres, no?]
That's only true if you are turning the same rpm at the same pressure (which would result in massively increasing the boost in the MCS). With a larger supercharger taking in larger gulps of air, you could slow it down and make the same boost using less power and creating less heat. Again, fitting it under the hood and mating everything up would be a huge challenge. This is an excellent book on supercharger design, theory and practice:
http://www.bentleypublishers.com/product.htm?code=gsup
Old Sep 8, 2005 | 03:14 PM
  #78
conehead's Avatar
conehead
Andy just out of curiosity do Uwe and Linda have any idea how much company time you spend on here ?
Old Sep 8, 2005 | 03:17 PM
  #79
andy@ross-tech.com
Yes. Why do you ask? If I fail to perform my duties at my job, I'm sure they'd have a problem with that.
Old Sep 8, 2005 | 03:20 PM
  #80
ingsoc's Avatar
ingsoc
Andy, but you have to remember that the SC spins exactly as fast as the belt system tells it. It currently runs off stock or smaller pulleys, except for the TC guys. You would need to change the pulley to achieve less boost and rotation. That means a bigger belt AND a bigger pulley. I doubt that a pulley big enough would fit in that space. (1/2 boost would require a pulley with 2x the circumference, ie a diameter of 2*the original!
Old Sep 8, 2005 | 03:25 PM
  #81
andy@ross-tech.com
BTW, my employer appreciates that I don't hide behind an anonymous username. I don't think I caught your name and employer ... they are?
Old Sep 8, 2005 | 03:36 PM
  #82
jlm's Avatar
jlm
" (1/2 boost would require a pulley with 2x the circumference, ie a radius of [the square root of 2]*original. That is roughly 1.41 times as large in diameter!"
better brush up on your seventh grade math, eighth grade physics.
Old Sep 8, 2005 | 03:50 PM
  #83
SpiderX's Avatar
SpiderX
That is funny No offense to conehead but that is funny
Old Sep 8, 2005 | 04:09 PM
  #84
ingsoc's Avatar
ingsoc
Yipes, my bad...::edits::! It needs to be twice as big. Thumbs up for peer editing! Anyways, the pulley needs to be a lot bigger.
Old Sep 8, 2005 | 04:19 PM
  #85
RECOOP's Avatar
RECOOP
Originally Posted by Bilbo-Baggins
The MCS has forged pistons, connecting rods and crankshaft. The MC does not. To supercharge the MC block would just be asking for trouble, IMHO
I have been told that the MCS really does not have forged pistons, even though some have suggested it does. I'd be interested in the source of your information. Many thanks...
Old Sep 8, 2005 | 04:50 PM
  #86
Eric_Rowland's Avatar
Eric_Rowland
Crank - yes
Rods - yes
Pistons - no
Supposedly from a MINI training manual:
Crankshaft Assembly
The MINI COOPER crankshaft is machined from nodular cast iron. The MINI COOPER S crankshaft is machined from forged steel. Both crankshafts provide a mounting point for the crankshaft sensor reluctor ring that is retained by three bolts. The drive for the oil pump is provided by machined flats towards the front of the crankshaft. The auxiliary drive belt pulley is a press fit on the crankshaft and retained by a bolt.
Crankshaft Bearings
All MINI COOPER engines use five main bearings. Lubrication is supplied through holes in the upper shell directly from the main oil gallery. The upper shell is grooved to transport oil to the lower plain shells located in the bearing ladder.
A thrust washer built into the center upper main bearing shell controls crankshaft end float. The connecting rod and main bearing shells are made of an aluminum base that is rolled onto a carbon steel backing.
Connecting Rods
MINI COOPER connecting rods are manufactured from 'non-coplanar' powder metal. They are manufactured in one piece and then fractured across the big end journal. The MINI COOPER S connecting Rods are manufactured from forged steel to provide additional strength and are fractured. The big end bearings are of a conventional plain shell design with oil supplied from a hole in the crankshaft.
Pistons
The pistons are aluminum construction with a grafal coating applied to the skirt to reduce noise, friction, and scuffing.
The MINI COOPER pistons have flat tops. The MINI COOPER S has a concave piston top with a volume of 1.66cc to reduce the compression ratio. Grafal coating consists of a fine colloidal graphite which is bonded with resin. It is between 10 and 20 micrometers thick and is applied by means of a printing process, followed by curing. Improved adhesion properties are achieved by a thin metallic phosphate layer or other proven methods which are applied prior to coating.
Old Sep 8, 2005 | 05:12 PM
  #87
RECOOP's Avatar
RECOOP
[QUOTE=Eric_Rowland]Crank - yes
Rods - yes
Pistons - no
Many thanks...
I know that some have replaced their MCS pistons with forged ones. Oh, the modification list goes on and on . Perhaps a sign of sanity is the recognition of when to stop or why one shouldn't even start going down the slippery slope of the modification highway ...
Old Sep 8, 2005 | 05:15 PM
  #88
ingsoc's Avatar
ingsoc
True words!
Old Sep 9, 2005 | 02:09 AM
  #89
XTREEM's Avatar
XTREEM
Would you rather that they didn't share what data they know of? They don't have a dyno of their own [it was done independently and the results were shared...]. So, what are they supposed to do? Tell and be criticized or don't tell and be criticized?
What should be done is M7 should either test their own gear and provide the numbers or get a independant like Randy Webb to do it for them. "Works for companys like Alta"
I'm sorry but the NO DYNO just doesnt cut it, It would be a minimum outlay to take a car to the dyno after each stage of modification for a $100 power run!!!!!
I know M7 have their very own bunch of disciples who would buy their products regardless of data or performance, and that may be all they are looking for?? but I'm also sure that the increased market share they would pick up by having a proper test & data system in place would more than cover their dyno time expenses.
John.
Old Sep 9, 2005 | 02:21 AM
  #90
XTREEM's Avatar
XTREEM
Originally Posted by M7
Extreme.....
[font=&quot]
What can I say, if you like to find faults with us, and our products go ahead. But the bottom line is we did dyno the upgrade and it did give us
17whp. If you think that's a huge claim
The 16% pulley is a measly 1.3% change in gearing, let's give the gearing
3whp, the MTH map was a standard map, that will give you 4-5whp at the most, the rest is from the SC IE. 8-9whp I find that a very acceptable [/font][font=&quot] for $695.[/font]
[font=&quot]
As for not showing Dyno runs......this thread proves why, no one (some)
will ever believe you no matter what.
If you need more info please call me, as I am to busy to hang out on the forum, talking endlessly about something we already gone over.
peter
Team M7
562-608-8123 [/font]
Peter,
I was thinking more of the huge claims you were making about the AGS before you went all quiet on the subject
I dont see anybody here argueing the dyno numbers you have provided, only that they are not relevent to the supercharger porting Surely you see where people are coming from?
John.
Old Sep 9, 2005 | 04:49 AM
  #91
SpiderX's Avatar
SpiderX
I belive this is a Stegmeir (sp?) of St Louis product.
Old Sep 12, 2005 | 08:26 AM
  #92
MSFITOY's Avatar
MSFITOY
What happened to the Autorotor?
Old Sep 12, 2005 | 09:26 AM
  #93
ingsoc's Avatar
ingsoc
Originally Posted by MSFITOY
Exchange rates murder you. I believe Randy can order one-offs, but don't be surprised to pay >3k for the blower alone! [I think I remember].
Old Sep 13, 2005 | 01:39 PM
  #94
Angus's Avatar
Angus
Wanted: Looking for one certifiable fool with stock MCS to run errands.
Important: Must take time off work from McDonald's and use your own savings for this task.
Specifics: Take MCS, go to the dyno shop, run it, take the front end off, jack the motor, remove the SC, install new SC, reassemble, run it again, send data to everyone.
Reward: None. You're doing this because you don't have a life and desperately hope this altruistic effort will gain you friendship among the elitest number guys. They will no doubt tell you that you took too long inbetween runs, therefore, the data is useless and you get a wedgy + a whirly :smile:
What's a whirly? I might be interested.
Old Sep 13, 2005 | 01:44 PM
  #95
iDiaz's Avatar
iDiaz
Coordinator :: Motoring Underground Club Forum
Is that anything like a swirly?
Old Sep 13, 2005 | 01:50 PM
  #96
MSFITOY's Avatar
MSFITOY
Trust me, you would definitely NOT be interested. Back in the 70's high school, if you were a "nerd" unlucky enough to be caught in the "john" by a group of "jocks", they'd lift you up by your ankles and lowered your head into the toilet and another would flush it for you Fortunatly for me, "Kung Fu" was a very popular show then...:smile:
Same as Swirly, Head mop, Toilet brush...
Old Sep 13, 2005 | 01:55 PM
  #97
Angus's Avatar
Angus
Bummer! My piles are aching and that wedgy sounded really good.
