Drivetrain Miletek best price ??
Old Aug 23, 2005 | 08:48 PM
  #26
J0kER's Avatar
J0kER
chili is sooo good when it burns ur' face off........
fair enough! i've just been getting mixed feed back about it (plugs) i've used them in my air cooled VW's so have alittle experience, but when it comes to d' mini people say dont use them and some swear by them so all d' info i can get will help. seems to me like it would help more in D' forced induction motors than D' naturally aspired motors. that JCW air box is still a box so not to thrilled w/it & plus i heard that its really designed to work w/their modified supercharger. know what i mean.
Originally Posted by gmcdonnell
I really want the air intake dyno tests to happen! I drove two MINIs this evening at the Metroplex Mini happy hour - one with a JCW intake and one with the Alta. Still haven't driven one with the AGS. That Alta really sings, let me tell you! The JCW is as quiet as the stock intake to my ears - until you get to about 5500 RPM and then the noise from the secondary flap opening becomes really noticable.
Sign on name is just short for "Gary McDonnell" - my real world name. I'm not terribly original when it comes to monikers. But I make a mean bowl of chili so it all works out.
Past experience with other cars led me to the decision to get the colder plugs. Plus the JCW kit includes colder plugs and other than the improved cylinder head it includes that's pretty much where I'll be once I have the cat-back exhaust in.
/gary
Old Aug 24, 2005 | 06:26 AM
  #27
gmcdonnell's Avatar
gmcdonnell
HA! I was an air cooled VW junkie for years! Had a 68 bug - the colder plugs were essential to getting consistent performance out of it. I still have a copy of John Muir's "How To Keep Your Volkswagen Alive" repair manual stored away somewhere. The VW experience is a big reason I'm going with colder plugs.
My thought is the colder plugs will almost certainly help, and if they make things worse they're easy to swap back out.
Old Aug 24, 2005 | 09:38 PM
  #28
J0kER's Avatar
J0kER
was it D' semi-automatic or was that 69', i have a 63' w/big roll roof in canvas and a 67' type 3 fastback (one of a kind year) pancake engine 48's IDA's. enough about that so what type plugs have U' tried. i'll check 2see if i have that book if not uwanna sell it??
Old Aug 25, 2005 | 05:32 AM
  #29
gmcdonnell's Avatar
gmcdonnell
The semi-automatic was in 69 - came out with it when they went to the double jointed axles instead of the "swing axle".
I loved the big canvas sun roof - wish I'd had one. My parents had a 67 type 3 fastback for years - that was where I got my interest in VWs in fact.
I did a couple of dune buggy engines with Weber 48IDAa and one with Weber 44MX carbs. They were bad *** fast but they sucked gas big time. I used the "Holly-Weber Progressive 2 barrel" carb on my street engines. My biggest engine was a 2180cc (92mm pistions and some kind of stroker crank). Made 197 horsepower on an engine dyno and lasted my friend two years in his dune buggy.
I really miss the simplicity of those engines. That Bug got me through high school and college and sparked my interest in all things mechanical - one of the main reasons I ended up getting my undergrad in Mechanical Engineering.
The book is still available today from Amazon. do a search on "How to Keep Your Volkswagen Alive" - best book ever. I would never sell my copy - too many good memories.
Old Aug 28, 2005 | 11:53 PM
  #30
J0kER's Avatar
J0kER
so ur definitely an AIR cooled v-dub fan those 48's can pull ur face right off, and ur wallet due to the gas fact. 2180 is big i have a 2110 ithink thats right dont remember that blue print i've gone w/so many combos its hard to keep up currently im lookin' into a type 4 build w/porsche internals & shroud full flowed block & Carillo rods, so u see im a bit of an air kooled nut. my first love was them german air suckers due to economical ways nothing like workin' on them have a 63' chevy SS Impala as well and its still easier to work on VW's so what type of plugs did U choose? did U get ur milltek? mine still not here hope its easy to install.
Old Aug 29, 2005 | 02:59 AM
  #31
gmcdonnell's Avatar
gmcdonnell
I will be getting the Milltek cat-back exhaust. Won't be getting a header any time soon. I've gotten to ride in several cars with various exhausts and I like the relative subtly of the Milltek sound.
I have the colder NGK plugs part number NGK BKR 7 EQUP and the 17% Alta pulley but they're not installed yet. I'm ordering an air intake this week and will put all of the equipment on at once. I already have the "standard" MTH software installed - I love it but will go to Apexi or MTH tuner software down the line.
Next phase will include JCW injectors and the Milltek exhaust. Probably around the first of the year.
Let us know how the Milltek install goes. What else are you doing to your MINI?
Old Aug 29, 2005 | 07:05 AM
  #32
supergimp's Avatar
supergimp
Hey, just a note if you are doing it yourself. Randy noted the "throatiness" of my Milltek when he was getting ready to install my pulley at the pulley party this weekend. When he had it on the lift, George, of Bimmers Clinic, noted I was missing a flange bolt. I know I was careful to get those tight, but George pointed out that the supplied bolts were not "exhaust appropriate." He said he sees that a lot and standard hardware can work itself loose with heating and cooling cycles. He set me up with exhaust bolts with self locking nuts (sort of an orangeish-bronze color). They are designed not to expand and contract so much with heat, thus are not as likely to work themselves loose. Something I'll keep in mind for exhaust installs on other cars.
Needless to say, my Milltek is back to it's usual purr.
Old Aug 29, 2005 | 08:46 AM
  #33
Larry Clemens's Avatar
Larry Clemens
How do you like the pulley? I had a Milltek exhaust installed yesterday. I love the look, sound and feel. I am glad that George was able to help you. Is is a great guy, very knowledgeable and has the cleanest shop in town.
Old Aug 29, 2005 | 08:56 AM
  #34
supergimp's Avatar
supergimp
Pulley's awesome. You're spot on about George, and proud as hell of his shop - as he should be. Did you get the tour? I swear he personally showed us every bottl of fluid in the place - and explained his rationale behind his choice of oil, brake fluid, ATF, etc. Learned a lot that day, for George and Randy.
Old Aug 29, 2005 | 10:05 AM
  #35
Skiploder's Avatar
Skiploder
I've had the Milltek header and catback on for a year. I've made it part of my pre and post track routines to check all of the bolts and tighten as necessary.
Old Sep 20, 2005 | 11:25 AM
  #36
J0kER's Avatar
J0kER
the install was easy quick-fast i had the playmini b4 and the sound is much nicer but real close...ill be doing the head & header next (matchport and all) then mayb some cam work!? not sure yet.. whats progress on urs??
rtk90
Aug 29, 2019 09:08 AM
actualsize37
Nov 18, 2015 08:58 AM
gmonde
Sep 28, 2015 05:22 PM
OutMotoring
Sep 8, 2015 06:27 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
