Drivetrain Water/alcohol injection
Old Aug 10, 2005 | 03:56 PM
MSFITOY's Avatar
MSFITOY
Here it is...
Thanks to John Petrich for his helpful advice Look carefully around the incooler. I have it plumbed preinjector as he did and also because I fear that the Nitrous at the other end would immediately freeze the water/alcohol coming out next to it. I installed a small LED on top of the steering column which lights up when the injector is active and will stay on if the injector is clogged. Nice temperature drop improvement. No, have not dynoed to measure the power improvement.
Old Aug 10, 2005 | 04:03 PM
TonyB's Avatar
TonyB
MSFITOY, the photo didn't come-out... Sounds great!
Old Aug 10, 2005 | 04:31 PM
MSFITOY's Avatar
MSFITOY
Stupid image station Fixed now...
Old Aug 10, 2005 | 05:25 PM
Wake|MCS's Avatar
Wake|MCS
I've never really understood how this works. But then again i've never really read about it. So I searched and read the threads dealing with water injection so I now understand the concept. Good luck with your system, post more pics of the pump, reservoir, etc. Hope you get good gains.
Old Aug 10, 2005 | 06:55 PM
Petrich's Avatar
Petrich
Sid,
What a beautiful looking installation. Can see lots of cool options here with the WI for 'normal' driving and the Nitrous for those 'special' times. I suspect that the Nitrous will cool the intake charge all by itself.
Please keep us posted as to your driving impressions.
Regards,
John Petrich in Seattle
Old Aug 10, 2005 | 06:57 PM
MSFITOY's Avatar
MSFITOY
Will do John Have you looked into the "progressive" controller? Someone posted under your thread once. I asked for more detail but didn't get a response.
Sid
Old Aug 10, 2005 | 08:45 PM
bouray's Avatar
bouray
Care to tell us how much temp drop you measure and what is your rate of injection?
Old Aug 10, 2005 | 08:50 PM
Coop d'etat's Avatar
Coop d'etat
Learning
Setup sounds nice!!!
Old Aug 10, 2005 | 08:53 PM
TonyB's Avatar
TonyB
Sid, you are all over it! When you get the tank situation resolved, please also share, with a photo or two
Old Aug 11, 2005 | 03:36 AM
jlm's Avatar
jlm
are you injecting at both ends of the intercooler?
Old Aug 11, 2005 | 05:13 AM
Ozbone's Avatar
Ozbone
More details please!!!
Old Aug 11, 2005 | 08:53 AM
TonyB's Avatar
TonyB
jlm, I can't be certain, but I think Sid is doing the mix pre IC only. But, after looking at the photo again, I see why you ask... I thought post IC was just the nitrous...
Old Aug 11, 2005 | 09:09 AM
MSFITOY's Avatar
MSFITOY
The pump pressurize the fluid to 100psi. I made a custom bracket (top right bolt of the IC cover) to locate the injector solenoid, the boost switch, and the clogged nozzle detector in one area. Trust me, there is no vacancy under my bonnet The hose you see at the right side near the Nitrous is a tap to the boost pressure which is connected to the adjustable boost switch. I could reverse the boost tap and the water/alcohol injector's location if I chose to but I'm afraid I'd need to move the Nitrous for the aforementioned reason. I'll post closeups later:smile:
Old Aug 11, 2005 | 11:52 AM
Profpatpending's Avatar
Profpatpending
am very interested in your NOS and WI systems
Old Aug 11, 2005 | 11:55 AM
MSFITOY's Avatar
MSFITOY
Does that mean I need to keep an eye on my Mini
Old Aug 11, 2005 | 12:00 PM
Profpatpending
unless you come to Ireland you have nothing to Fear
looks like you have spent a lot on mod's,
that engine bay is pretty sweet.
Old Aug 11, 2005 | 12:05 PM
MSFITOY's Avatar
MSFITOY
Thank you:smile: ...I spent a lot "time" on mods. Money isn't everything
Old Aug 11, 2005 | 03:49 PM
jlm's Avatar
jlm
speaking of intake air temps, today I saw 190 deg F pre-intercooler and 160 post. that was puttering around (less than 0 psi boost) in NYC traffic in 95 deg mugginess. uhhg!
Old Aug 11, 2005 | 05:40 PM
1FSTMINI's Avatar
1FSTMINI
JLM......im guessin ur in the city.....Im out on the Island and work for MINI.....maybe we can get some people together for a meet around here maybe at Jones beach or Tobay.....Lemme know.
Old Aug 20, 2005 | 08:27 AM
MSFITOY's Avatar
MSFITOY
It's raining at the Woodward cruise Good time to catch up with my project postings. The water injection LED is lit when the water/alcohol is flowing at preset +-11psi (above small arrow). My AF is not really at 15.7 The motor is off...
A wider view of my office:smile:
The tank/pump sits snugly next to the N2O bottle in the boot. I know this is bad form (high CG) but I literally couldn't find another spot to mount a good size tank/pump any lower. After the rear seats goes away, I will fabricate custom tanks and fit them in the rear foot wells. For now, I'm using a 3 gallon marine fuel tank which has a handy level gauge and is quick connected for easy removal.
Old Aug 20, 2005 | 09:14 AM
1FSTMINI's Avatar
1FSTMINI
Damn Msfitoy........You got enough electronics in there.
Im using the tank for the headlight washers which i dont have for my IC sprayer which fits nicely in the left fender. Bought a STI nozzle n im good to go.
Old Aug 20, 2005 | 09:35 AM
MSFITOY's Avatar
MSFITOY
That's what the dealer said Warranty? What's that? I thought about using the washer bottle but it wouldn't last very long with WI...
Old Aug 20, 2005 | 09:36 AM
TonyB's Avatar
TonyB
Sid, thanks for sharing, and for paving the way! I hope to do something very similar, maybe this Winter. I would ideally prefer an IAT trigger, as opposed to boost, but that is proving to be a bit more challenging...
Sounds like you are on a cruise now... Man, if I were on a cruise and my wife caught me posting on that 'MINI website,' I'd get some grief, even on a rainy day Enjoy!
Old Aug 20, 2005 | 09:41 AM
MSFITOY's Avatar
MSFITOY
Tony...using boost is a better way to go don't you think as WI is only applied when the tough gets going (higher rpms) which usually coincides with IAT rises It would be nice to cool the charge in situation like the Dream Cruise where max speed is around 3 mph. But, WI at such low rpms could choke your motor. Sophisticated systems like Aquamist uses injector timing to achieve progressive WI control. Very nice but very expensive...maybe later down the road.
I was going to take the wife to the cruise but it's raining/humid as usual. After the Dream Cruise tomorrow will be a perfect sunny 77 degree day...go figure
Next stop...front camber plates
Old Aug 20, 2005 | 10:01 AM
1FSTMINI's Avatar
1FSTMINI
I dont use it as an injector system....Its just to spray the IC when the "goin gets tough" during a race, as you put it MSFITOY.
3 more hours of work n im heading to Randells Island in Manhattan for Amsterjam......PARTY time.
