Drivetrain Question about used Magnaflow
Old Jun 11, 2005 | 07:30 AM
BuckeyeMCS's Avatar
BuckeyeMCS
I bought a used Magnaflow system that did not have the bolts that connect the resonator to the cat. I went to Home Depot and bout 3/8 X 1 1/2 SS bolts with cut washers. The worry I have is the washers, they look thin. Any thoughts on if I should leave it the way it is or get thicker washers. It is nice and tight.
Also, any ideas on how to drop the tips a bit? I am worried they are too close to the trim (smelled a bit of burning plastic when I got out and looked at it).
BTW I love the sound!!
Old Jun 11, 2005 | 11:56 AM
robthemininut's Avatar
robthemininut
Don't think there is a way to move it down but you can move it back producing similar results. Loosen the sliding joints, push the rear portion of the system toward the back and tighten. At least an inch of play. Because of the shape of the tips, this will increase the distance to plastic.
Yes, the sound rocks.
Rob
Old Jun 11, 2005 | 12:53 PM
obehave's Avatar
obehave
You can move it back as mentioned. You can also drop it down. I did mine.
You need to carefully bend the hangin rods up.
I used 2 ppe wrenches. One to hold the bar steady just above the attachment point at the muffler and one at the end of the rod to flex it up slightly.
I measured across the tips of the rods. Moving them 1/2" closer together total, gave me a decent drop.
I did it by hand but you could use something else.
I don't like the look of the tips sticking out.
Old Jun 11, 2005 | 01:54 PM
BuckeyeMCS's Avatar
BuckeyeMCS
I thought about doing that. I'm not sure I want to hassle with trying to hang it from all 4 hangers again.
:smile:
Old Jun 11, 2005 | 03:13 PM
obehave's Avatar
obehave
:smile:
I can appreciate that. Hanging that back section by yourself is a PITA.
Old Jun 11, 2005 | 04:39 PM
ted leist's Avatar
ted leist
You have a pm.
Old Jun 12, 2005 | 07:19 AM
BuckeyeMCS's Avatar
BuckeyeMCS
Truth! I thought I was pretty strong but holding that sucker up was brutal!
Ted,
I got it! Thank you.
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
rob&JCW
Sep 10, 2015 12:06 PM
Robree
Sep 9, 2015 08:43 AM
