Drivetrain Pilo Racing Cylinder Head Flow Bench Numbers Released!
Well,
We have finally decided to release our flow bench numbers. As you can see, there is a huge increase in both the intake and exhause side. This is our Race 2 Version with Larger Valves.
minipilo
i assume these numbers translate into some good gains, in the same time... with oem components i can see even with a high flow intake and exhaust readings.... means that if the header or the tb isn't taking the right amount of air in you'd still be bottle-necked... right?
In Regards to good HP numbers, Our first version wich flows about 60% as well as this version, we gained 13HP with stock throttle body and header. So there are some relly good gains to be had, even with out replacing these parts.
DPR Really did their research and testing on these products. Here are some pictures of them working it on the flow bench.
