Drivetrain Intakes
Old May 19, 2005 | 07:37 AM
  #26
webstrands's Avatar
webstrands
jlm
I was wondering about that, myself. Wouldn't the additional airflow (cowl) be good to produce torque at the lower range?
Old May 19, 2005 | 07:48 AM
  #27
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The only reason for the intake flap arrangement on the JCW is for noise control during 'sedate' driving. Any open element arrangement, be it Alta, Madness, Pilo, HAI, or AGS does not have noise control as a primary or even secondary concern. Granted, with some CAI arrangements you have a choice of whether or not to open up the firewall partition for additional cold air and resulting in-cabin noise.
Many people get the AGS- and Alta-style CAI not solely for the performace gains but the sound as well. It seems to have been established that the AGS produces the most prominent intake note of any of the others, and that is precisely the reason some folks go for it.
For the record I have a JCW intake fitted with an Alta hose. I wanted my car to be quiet during normal street driving but be able to wake the beast up and let him roar at times. The intake coupled with the Milltek exhaust makes for the perfect setup for this IMO. Some might say the differences are like night and day.
Old May 19, 2005 | 08:02 AM
  #28
sfjames2's Avatar
sfjames2
Originally Posted by blown9746
My wife has an 05 MCS that I'm thinking of adding some parts to. It is all stock right now and I've been looking at the CAI The three in particular are the minimania, bmp, and Dinan. Will these work on an otherwise stock car or are there additional mods needed. Anyone recommend one over the other? I am new to the Mini world and just looking for a little advice.
If you decide on a Minimania intake and want to save some cash, PM me cuz I have one that I no longer use.
I went from Minimania to Alta and am currently waiting for the M7 AGS.
Chose the Alta over Minimania's for power looks and sound.
Changing from Alta to the M7 AGS to get more power and sound, but I lose the looks.:smile:
Old May 19, 2005 | 08:11 AM
  #29
kyriian's Avatar
kyriian
bottom line is pretty simple, it's watever that floats your boat..
dinan and jcw are nice and sedate (jcw only makes the sound when its at wot), they are pricey though
alta and m7 both are tops in power gains, i dont know what a m7 sounds like but they are priced around the same (m7 base kit vs. alta with silicone hose)
pilo and hai is at the price corner.. if you just wnt a cai that performs, and wont nit-pick over the hp figures, or looks ... you cant go wrong with the pilo or the hai
Old May 19, 2005 | 08:17 AM
  #30
sfjames2's Avatar
sfjames2
Man that (Alta) hose looks cool though!! I'm gonna have to think of a way to keep it under the bonnett and make it look functional even.
Old May 19, 2005 | 08:24 AM
  #31
kaelaria's Avatar
kaelaria
Originally Posted by jlm
did anyone ever determine the need for the JCW intake to open it's input flap tot he cowl, rather than draw from there all the time? Noise? water?
I emailed JCW and they did not respond.
I asked Downtown Mini's Service guy that does the aftermarket work (sorry, don't remember his name) and he said he always recommendes leaving the flap in place for the purpose of increased torque on the lowend compared to an open cone design, or an open flap. I left mine on to begin with and certainly have no lag in the low-end as I've seen posted with an open cone.
Old May 19, 2005 | 08:34 AM
  #32
jlm's Avatar
jlm
here is an un-obstructed intake:
Old May 19, 2005 | 09:14 AM
  #33
BriNYU's Avatar
BriNYU
Does anyone have SOUND CLIPS of the AGS and the Alta?
Old May 19, 2005 | 09:20 AM
  #34
eVal's Avatar
eVal
I believe this is the case as my before and after run showed distinct improvement to the torque curve. I don't think the flap design came from wanting the intake to be quieter vs open intakes at minor throttle, but rather is a side effect
Edit: Just to clarify, the day I added the JCW intake and exhaust we did a before and after dyno run which showed the improvement, in particular, to the torque
Old May 19, 2005 | 09:46 AM
  #35
flyboy2160's Avatar
flyboy2160
this makes no sense: a more restictive air path far, far upstream of the intake valves is good for low end torque? ask this service guy for the engineering principles behind his claim.......
Old May 19, 2005 | 10:04 AM
  #36
webstrands's Avatar
webstrands
AGS Sound
https://www.northamericanmotoring.co...24&postcount=1
Old May 19, 2005 | 10:49 AM
  #37
kaelaria's Avatar
kaelaria
Restricting an intake increases the stream velocity, which helps on the low-end. It becomes too much of a hinderance at higher RPMs, hence the cowl flap opening.
Old May 19, 2005 | 01:43 PM
  #38
whovous's Avatar
whovous
I had planned a CAI as my first performance mod, but let my stepson talk me into an Alta pulley at the Dragon. Good choice, but now I have questions like the original poster raised.
Do I correctly understand that all CAIs are louder than stock? JCW looks to be the quietest, but it is also more than I want to spend.
How does the Alta sound under non-spirited driving conditions? Is it very noticeable then? I'd like to be the one who decides when I get loud.
Old May 19, 2005 | 01:50 PM
  #39
kaelaria's Avatar
kaelaria
Originally Posted by whovous
Do I correctly understand that all CAIs are louder than stock? How does the Alta sound under non-spirited driving conditions? Is it very noticeable then?
Yes.
It sounds whistly and whiny, moreso as you open the throttle.
Yes you notice it, compared to stock. Open cones are never quiet.
Old May 19, 2005 | 02:04 PM
  #40
meb's Avatar
meb
Personally I find very little sound difference between the stock intake and my JCW intake. I can hear a throatier growl above 4,500rpm, but I have to listen for it. That might be different with other components, dunno.
Old May 19, 2005 | 02:43 PM
  #41
sfjames2's Avatar
sfjames2
whovous, the Alta gives sort of a whistle sound with the slight throttle inputs and gulping sound when full throttle is applied followed by a nice SC scream at redline.
Old May 19, 2005 | 03:25 PM
  #42
kaelaria's Avatar
kaelaria
Then it is probably installed incorrectly. When the flap open (yours probably is not) it is OBVIOUS.
Old May 19, 2005 | 03:29 PM
  #43
kyriian's Avatar
kyriian
ive heard tons of people vouch the dinan is the most 'stock sounding'
when i first installed my alta i did not find the additional supercharger whine to be an annoyance... at crusing speed, the alta does make a loud whistle at about 0.1 vacuum (according to my boost gauge)....
anything else... you won't hear much difference...
Old May 19, 2005 | 05:00 PM
  #44
SpiderKnight's Avatar
SpiderKnight
I have a JCW intake. When the car goes above 4500 with full throttle, I hear a nice whine from the SC. If I am not at full throttle, but coasting or maintaining, I do not hear the whine so much.
It is different from before where the whine level was more linear. Sound about right?
Old May 19, 2005 | 05:54 PM
  #45
kaelaria's Avatar
kaelaria
Yes.
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
