Drivetrain VIDEO: SPI BREAKS 400WHP on FIRST ATTEMPT
Old May 9, 2005 | 06:01 PM
Fireballed Hubie's Avatar
Fireballed Hubie
http://spipowerexcel.com/newimages/dyno_400.wmv
We have taken our project to the next level.....500WHP is in our sights.
Old May 9, 2005 | 06:05 PM
kyriian's Avatar
kyriian
keep it up!
Old May 9, 2005 | 06:07 PM
kaelaria's Avatar
kaelaria
Me want!!
Old May 9, 2005 | 06:09 PM
Dr Obnxs's Avatar
Dr Obnxs
I was watching away...
and I guess others saw the post. Needless to say, I'm sure your server is getting hammered, because my playback locked up! Boo hoo hoo.
And congrats! Now, can I get that for under a thousand dollars?
Matt
Old May 9, 2005 | 06:17 PM
fishey72's Avatar
fishey72
"This is crazy, this is crazy, this is crazy" ~Chevy Chase
Old May 9, 2005 | 06:35 PM
danielg's Avatar
danielg
I can't believe my eyes. Get that thing on the drag strip.
mini d's Avatar
mini d
Congrats Hubie!
Man, it didn't take long to reach the rev limiter!!
Old May 9, 2005 | 06:47 PM
MyPocketRocket's Avatar
MyPocketRocket
Thank you SPI! You made my dream come true!
Old May 9, 2005 | 06:56 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Now THIS is the kinda thing I like to see!
Awesome job!
Old May 9, 2005 | 07:13 PM
Morales's Avatar
Morales
WOW!
Old May 9, 2005 | 07:19 PM
jlm's Avatar
jlm
that was Hubie at the wheel, complaining about only getting 426
Old May 9, 2005 | 07:28 PM
El Diablito Rojo-N20Mini's Avatar
a head / cam and a few other tricks and 500whp will be tested
Old May 9, 2005 | 08:04 PM
TheBlackBrian's Avatar
TheBlackBrian
How much does this car weigh? Isnt a stock cooper s around 2800lbs? If so, that would bring the power/weight to just over 6.5lbs/1hp!!! Isnt that like a ferrari 360?
Old May 9, 2005 | 08:15 PM
1nf3rn0's Avatar
1nf3rn0
That is just insane :O
Old May 9, 2005 | 08:20 PM
DunWaiten's Avatar
DunWaiten
Is this how a typical dyno run is conducted?
I've never watched a automotive dyno run before, and am excited to see one. It looks like the way this one was conducted was to run part-way up the tachometer in first gear, part-way up the tach in 2nd gear, then shift into 3rd gear and floor-it up to redline.
Is that the way a dyno run is typically conducted? Not having seen one, I imagined a much slower run-up toward red-line under full throttle, controlled by varying the load the dynamometer presents, so that the power measured is closer to steady-state.
Old May 9, 2005 | 08:25 PM
1nf3rn0's Avatar
1nf3rn0
I have the same question actually...
Old May 9, 2005 | 08:30 PM
TonyB's Avatar
TonyB
How can congrats not go out for such achievement?! Awesome work guys
Would love to hear what ingredients went into this run, and what boost level was reached to get such an output...
Again, congratulations!
Old May 9, 2005 | 08:33 PM
npartist's Avatar
npartist
yes, that is a standard dyno run. Done in 3rd to prevent wheel slip (which completely messes up the figures) and I am sure there is another reason.
Old May 9, 2005 | 08:35 PM
1nf3rn0's Avatar
1nf3rn0
Im guessing its calibrated for 3rd too... Do you need to give gear ratios, etc before you do a run?
Old May 9, 2005 | 08:38 PM
peterwhit's Avatar
peterwhit
Hubie, I also need 430....
Old May 9, 2005 | 08:39 PM
1nf3rn0's Avatar
1nf3rn0
I'l be happy with my expected 250 thank you very much.
Old May 9, 2005 | 08:55 PM
peterwhit's Avatar
peterwhit
does this mean he is only running a really large turbo with huge injectors and serious cooling system?
JeffS's Avatar
JeffS
Power runs are typically done just like this either in 3rd or 4th gear, whichever is closer to a 1:1 ratio for the particular car.
Load testing, like you described, is good for tuning (assuming the dyno is capable), but that assumes that you have a tuning aid capable of making adjustments at specific load/throttle/rpm settings.
Does anyone know if Hubie is still trying to use the SAFC or has he switched to something more capable now?
Old May 9, 2005 | 09:02 PM
he is running the same turbo as the Helix turbo
which is a GT28RS
the car is still twincharged
Old May 9, 2005 | 09:10 PM
1nf3rn0's Avatar
1nf3rn0
Amazing. Is he planning to sell his modification as a kit, or is it just a test for him to see how far he can push his car?
Also, Is he running all of that power through stock pistons, etc?
