Drivetrain M7 AGS... image
Old May 11, 2005 | 06:48 PM
  #51
SCA's Avatar
SCA
Another thread-spoiler
Originally Posted by MadMick
It looks good, it sounds good but where are real dyno numbers? Here in germany we say: I d`ont buy the cat in a closed bag ;-)
Oh come on, don't spoil this happy thread with your unreasonable demands for numbers. Who cares about numbers when the friggin' Pamela Anderson of intakes is resting in your engine bay.
Old May 11, 2005 | 06:54 PM
  #52
M7's Avatar
M7
The plug... ????
Are you talking about the elbow on the filter housing IE. crank case vent tube return.
Or the red plug IE. a cover over the T-band hose clamp bolt.
Or the new CNC machined vaccum aluminum elbow on the TB.
Hope that helped.....
peter
M7 Tuning
562-608-8123
  #53
peterwhit's Avatar
peterwhit
who sells cats in bags? Those crazy germans
Old Jun 14, 2005 | 10:11 AM
  #54
MSFITOY's Avatar
MSFITOY
Hey Peter, what's happened to ALL the AGS images. I can't find any anywhere
Originally Posted by M7
Finaly found some time to photograph the AGS in it's full glory.
As you can see the AGS tube is in line with the supercharger, allowing absolutly
perfect, unimpeded airflow to the supercharger. Not only is the tube perfectly straight but there also no intrusions in the air-path , not only slowing down the
air flow but also disturbing the laminar flow, robbing power from the engine.
The throttle body was moved approx 4" down necessitating us to either ask you
the consumer to hack in to the wiring harness, or us making a custom 12"
harness adapter....We did chose the latter.
peter
Team M7= Think outside the box
562-608-8123
Complete AGS-Pro with 62mm TB
Old Jun 14, 2005 | 10:22 AM
  #55
M7's Avatar
M7
I do not know....
But I will look in to it later.
peter
Old Jun 14, 2005 | 10:24 AM
  #56
Pir8 97's Avatar
Pir8 97
You could always go to their site http://www.m7tuning.com/products/ags.htm
Old Jun 14, 2005 | 11:51 AM
  #57
ingsoc's Avatar
ingsoc
I looked and they've remained in the M7 gallery. They just aren't in the threads as they should be. Weird.
Old Jun 14, 2005 | 11:57 AM
  #58
JeffS's Avatar
JeffS
It's clearly not a broken link, or you'd see the red X's.
I've noticed images removed from M7 threads since I started reading the board and always thought it was the creator choosing to remove them. It's either that, or a moderator doing it, which seems doubtful.
Every time I bring it up someone indignantly states something like "they're all over the place, like in thread Y, if you'd just look for them. Just like the person above pointing to their website - as if that had a thing to do with the question at hand.
Old Jun 14, 2005 | 01:38 PM
  #59
webstrands's Avatar
webstrands
Just click on "Gallery" next to Peters name on one of his messages.
Waszak
Oct 21, 2017 05:55 PM
donniedarko
Oct 21, 2015 01:15 PM
Tires, Wheels & Brakes
Sep 4, 2015 12:35 PM
Sep 4, 2015 08:25 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
