Drivetrain BOOH YA ! Awesome dyno #'s !!
Old May 7, 2005 | 04:19 AM
  #26
Koopah's Avatar
Koopah
Originally Posted by 002
Actually you need to divide the whp by .88. 112bhp equals 98.56 whp and 100 whp equals 113.64 bhp. Its only a small difference, but the math is wrong and will be worse with bigger numbers.
bhp*.88 = whp
whp/.88 = bhp
( this is for a 12% loss)
Ok. So let's recast those numbers with your math:
Stock: 163 BHP * .88 = 143.4 WHP
Mod: 209 WHP / .88 = 237.7 BHP
Mod 209 WHP - Stock 143.4 WHP = 65.5 HP or a 46% gain. So I admit that there's a discrepancy of 0.1 HP in my calculation.
But my point is that these numbers see pretty high for a WHP measurement and may be a result of WHP to BHP confusion/conversion issues. And, if this IS in fact an accurate WHP number, WOW!
Theo
Old May 7, 2005 | 05:22 AM
  #27
eMINI's Avatar
eMINI
Theo
He probably says that every time his right foot itches.
Old May 7, 2005 | 06:06 AM
  #28
El Diablito Rojo-N20Mini's Avatar
Originally Posted by mini d
But wait, I was there! Saw the magic with my own two eyes. The little black beast is a screamer. Every time El messed with the Apexi the numbers went up! All in all, fun day even if I had the most anemic car there at 185 whp.
you were the guy with the "white cane" right???????
Old May 7, 2005 | 06:45 AM
  #29
05JCWS's Avatar
05JCWS
Originally Posted by Tuls
Welcome to the Vette killing club!
Do you really think 209whp is going to kill a Vette? Which one an 1984? The 2005 puts down 350whp, and it's curb weight is only about 500 more lbs than a Mini. I don't see a 209whp Mini put down in the mid 4's for 0-60.
Old May 7, 2005 | 06:58 AM
  #30
Brain1.0's Avatar
Brain1.0
Manufacturer
For anyone interested SCMM is going to do a group buy and install with dyno time. If you are interested contact me and I will get you the same price as SCMM is getting.
2 corrections to an earlier post.
My car is an 05 so its actually rated at 170 crank, and the # are WHP #'s and the car feels like its making power!
Can it kill a vette? Depends who is driving the vette...Personally I will say no when we are talking straight line acceleration but that isnt where the mini shines and not what it was biult for and not what I want it for. Guaranteed to spank honda's though
Old May 7, 2005 | 08:40 AM
  #31
minimc's Avatar
minimc
Just had a look at those plots. Lots of folks would like to see Dyno sheets like those.
I dunno about max power on run 8, but I really like the plot on run 7. ...That hp climbs at an almost perfectly straight line!!! and the torque curve has fewer dips.
Did you decide to further modify fueling for safety? Looking at run 7 vs. 8 there's significantly more fuel in the mix between 5 & 5.5k rpm.
Also noticed that run 8 is a little more lean all the way from 2.5k on up to 5k rpm. But the graph doesn't show much visible gain over run 7 in that range. Did the butt dyno tell you that you were pulling stronger through the mid? Irrespective of this, you'll save some gas on the run 8 tune for daily driving. ...Unless you have your foot into it constantly.
El, what was your A/F target(s) up in the ranges above 4.5K?
Good stuff guys! & thanks for sharing detlman!
Old May 7, 2005 | 09:05 AM
  #32
Brain1.0's Avatar
Brain1.0
Manufacturer
I am not really sure about the tuning part because that is El's dept.
All I can say is my car pulls very strong from about 3K all the way to the limiter! clean smooth and linear. There are a couple little spots I need to work on with the low throttle settings. Alll around good stuff !
Old May 7, 2005 | 10:30 AM
  #33
JCampos's Avatar
JCampos
Originally Posted by El Diablito Rojo-N20Mini
just for the record.............
I "butt dyno'd " the car at Steve's on Sunday.... (rough tune by feel)
that laid down the 202whp first run
2 tweaks later and 209whp...... with a few ponies still sitting in reserve
first car I have seen lay down over 205whp with STOCK injectors....
As soon as one of these unichip tuners gets their damn dyno working Ill do it.
  #34
mini d's Avatar
mini d
Next time please post in braille.
Still looking for that white cane. So would you call what I have blind faith in TBD (Tuned by the Devil)=Thinking inside the box.
Old May 7, 2005 | 10:33 AM
  #35
Brain1.0's Avatar
Brain1.0
Manufacturer
Is that what I ran over when I was leaving ? Damn canes!
Old May 7, 2005 | 11:48 AM
  #36
MINIAC's Avatar
MINIAC
Originally Posted by detlman
My car is an 05 so its actually rated at 170 crank ...
The 170 figure is actually metric horsepower which equates to 168 horsepower
https://www.northamericanmotoring.co...0&postcount=10
Old May 7, 2005 | 01:42 PM
  #37
Brain1.0's Avatar
Brain1.0
Manufacturer
works for me
Old May 7, 2005 | 01:52 PM
  #38
mycpr_s's Avatar
mycpr_s
i would put my money down on the mini. i'm pretty sure the mini can pull off the line against the vette and pull on the vette during a roll on.
Old May 8, 2005 | 03:06 AM
  #39
uae mini's Avatar
uae mini
I feel an urge to get a 100+whp boost on my crappy slow car, to me atleast, to really be able to kick butts:smile:
All this talk about HP is making me feel nautious.. not at the most
Nice setup you got there Keep going up and up and up... then you'll need an engine rebuild to handle even more and more and more... you get my point.
Where are the companies that were willing to get the twinscrew setup out and running... it just died out
El D : Is it possible for you to provide us with a 0-100km/h run so we can get an idea of what to expect? A video of the car in action maybe? Am I asking too much?
Old May 8, 2005 | 05:05 AM
  #40
05JCWS's Avatar
05JCWS
Hmmm! The 209whp Mini above has to pull 12.4lbs for every hp while a stock '05 Vette has too only pull 8.9lbs for every hp. The 209whp Mini is making about 67 more hp than a stock Mini. The stock Mini can do 0-60 in 6.9 seconds. I really doubt 67 more hp is going to knock 2+ seconds off a run to 60. Not going to happen. He would have to be putting down 300whp to start giving the Vette a run for his money.
Old May 8, 2005 | 08:33 AM
  #41
JCampos's Avatar
JCampos
And at that point, the vette will have a huge traction advantage and more top end.... the newer ones run 1/4 miles in the 12s
Old May 8, 2005 | 08:58 AM
  #42
andy@ross-tech.com's Avatar
andy@ross-tech.com
Great job! What sort of numbers do stock MCS put down on the same dyno?
Old May 8, 2005 | 09:05 AM
  #43
JCampos's Avatar
JCampos
Im yet to see a stock car on that dyno. However, the place that is tuning my unichip is going to use a different dyno than the one Ive been using to measure mod gains.... we will see if I can throw down 200+ on both of em
Most 15%+intake+exhaust cars are throwing down low 180s.
Old May 8, 2005 | 09:30 AM
  #44
over 100 mini's have been dyno'd on this particular dyno
I have done mine there and in Phoenix and they were within 1-2 hp of each other.... If you do the tests the same there are very little differences in dyno's.... it's operator error in my opinion
Old May 8, 2005 | 10:14 AM
  #45
BelowRadar's Avatar
BelowRadar
My 05 dyno'd the following at DRS:
1st run 152.8 hp 142.6 ft/lbs.
2nd run 154.4 hp 140.3 ft/lbs.
3rd run 156.9 hp 141.5 ft/lbs.
My a/f ratio was 15 (ouch)
There were two other stock engines there that day. One did 153.6 hp, and the other did 161.9 hp. I believe they were both 04's. I was really bummed that I didn't do better when I saw that guy pull 161.9 hp with an older model. But his car wasn't completely stock. He had no engine mods, but he had lightweight rims. I don't know if light rims (in contrast to us running the S Lites on the dyno) would transmit into that much of a difference, but the completely stock 04 and me (both running S Lites) were relatively close, with my 05 edging slightly above. I'd like to go dyno my car with new rims to see if there's a difference, but I'll at least have my pulley on by the time I'm ready to buy new corners.
The only people who have dyno'd above 200 hp there without a twincharge (El correct me if I'm wrong) are detlman and D1JL, who have all the typical bolt-ons plus cam, head, and A'PEXi. In fact, I believe the only MCS's who have run over 200 hp there are running the A'PEXi...
Old May 8, 2005 | 12:14 PM
  #46
yes, only 2 have done it.... D1JL and detlman
both had APEX-1 on their cars
Old May 8, 2005 | 02:02 PM
  #47
caminifan's Avatar
caminifan
And, since we are talking about a modified MINI, it is only fair to consider what a modified Corvette can do as well: Just N.A. to N.A. a C-5 can be relatively easily tuned (CAI, larger throttle body, heads & cam, headers and cat-back) to produce 465 hp and 435 ft/lbs. The C-6 Z06 with 427 c.i. (7.0 liters) LS7 engine is going to be producing in the neighborhood of 500/500 from the factory. Wait until people like Lingenfelter Performance get to tweaking the LS7 engine. Think the MINI is going to be a vette killer? Maybe in a wet dream. In fact, the Viper better watch out; a LS7-engined Z06 is taking a bead on it.
Old May 8, 2005 | 03:14 PM
  #48
uae mini's Avatar
uae mini
How many Mini engnes are those
You better trailer a gas station behind you in that Z06 then maybe two when modded.. lol
Old May 8, 2005 | 04:46 PM
  #49
caminifan's Avatar
caminifan
Not really. I happen to own a 2003 C-5 with the modifications that I originally described. With a Yank 3200 torque converter and 3.15 rear end, I get 20 mpg City and 28 Highway running 93 octane.
Old May 8, 2005 | 05:16 PM
  #50
Koopah's Avatar
Koopah
My a/f ratio was 15 (ouch)...{snip}
Ok. Let's go over those numbers again...
1. MINI has rated the '05 MCS in stock form at 168 (US) BHP.
2. BelowRadar has a stock '05 MCS.
3. BelowRadar's best pull was 156.9 WHP on the DRS DynoJet.
Using the accepted 12% driveline loss factor, we can verify the accuracy of the DRS DynoJet WHP calculation by dividing BelowRadar's 156.9 WHP by the .88 driveline loss factor to arrive at MINI's 168 BHP rating, yes?
156.9 WHP / .88 = 178.3 BHP ????
This is obviously 10.3 BHP higher than the stock factory BHP specification. How can that be? Read into that what you may but I believe that DRS's DynoJet may be the culprit and may be consistently reading about 10.3 HP too high.
However, detlman's best pull was 209 WHP and, assuming the 10.3 HP dyno inaccuracy is fixed and not linear or exponential, the new BHP can be calculated as follows:
209 WHP / .88 = 237.5 BHP - 10.3 HP correction = 227.2 BHP
Based on the mods detlman has made, 225 - 227 BHP sounds right on target.
In and of itself, the 10.3 HP correction does not affect the good work El Diablo Rojo does; he is working with net-change analysis from run-to-run. It is when one those numbers is taken as an absolute value to the "outside" world as a "standard measurement" that a problem surfaces.
I suppose the only way to truly develop a "standard dyno rating" is to use a single, high-end dyno (like the Mustang??) to measure all MINIs; obviously not a practical answer. Thus, we have to recognize that there will be a variance between dynos from the various manufacturers.
Again, The Red Devil at DRS has done a terrific job tuning these MINIs and I am not trying to flame anyone's fine efforts or well-sorted mods here. You are all helping to push the performance envelope of our cars and you should be recognized for this.
However, as with many numbers that are thrown around these forums, there needs to be a common sense examination to determine what's behind them. There are some very smart technicians hanging out on NAM (Ryan Malcolm, Randy Webb, Andy Ross, and many others) and I think they will echo my concern for a more critical assessment of the "pronouncement of numbers".
Andy Ross' signature says it all.
Theo
