Drivetrain So I installed my Alta Intake on my 2005...and...
Old May 28, 2005 | 07:33 AM
  #26
vegasdan's Avatar
vegasdan
I want everything I can get.
Old May 29, 2005 | 12:04 AM
  #27
Xman's Avatar
Xman
Pat, I wouldn't worry about it. I had the wall for the longest time before I drilled two big holes in it and can't feel or hear any difference.
I still got 185whp on the dyno with the wall (and other mods ;-) so who cares...
Do as you feel, and enjoy your new Intake
Old May 30, 2005 | 07:11 PM
  #28
inmimini's Avatar
inmimini
i have the same intake on my 2005 , if you want the full effect you need to do the complete install. its not hard just follow instructions step by step and it will be done before u know it. it gives a nice sound inside the car im not sure that it bumped up any power because i had it in before i even broke in the car. good luck with it.
Old May 31, 2005 | 10:41 AM
  #29
Green Giant's Avatar
Green Giant
What happened to your Pilo CAI??
I'm curious to know if you can tell the difference between the two?
Old May 31, 2005 | 11:35 AM
  #30
Mini03Tiger84's Avatar
Mini03Tiger84
My dyno run shows changing filter alone there will be negligable HP gains.
Attached is a dyno plot of my car a year or so ago.
There were 3 runs...
        There was hardly any HP gains with no filter in the path, so adding a Alta or Pilo filter alone will not add significant HP. All the restriction is in the stock intake tube.
        I have not been back to dyno since I added my Alta (with silcone tube and no wall) but my butt dyno says there is slight improvement at higher end. That could be because my wallet is $250 lighter.
        Anyway Pat... nice bling under the hood. Remove the wall if you want the extra intake sounds and get the silicone tube for the HP gains.
        AWOL
        Mar 28, 2016 10:51 AM
        Mib4840
        Oct 13, 2015 10:10 AM
        stierzy34
        Sep 15, 2015 04:40 PM
        jrezzo
        Aug 9, 2015 10:32 PM
