Drivetrain Any experience w/ topside oil changer?
Old Mar 1, 2005 | 09:46 PM
ZenAudio's Avatar
ZenAudio
ProMini has a topside oil changer that sounds like it could be a great way to change the oil? Anyone actually have experience with this?
Thanks in advance,
Mike
Old Mar 1, 2005 | 11:24 PM
Nick_T.'s Avatar
Nick_T.
I’ve had an oil sucker that looks similar (but with a bicycle pump type handle) to the one at Griot’s for a couple of years, but haven’t used it on my MINI yet.
The first time that I used it on my Z3 I pulled the drain plug after sucking out all the oil that the oil sucker could pickup and only got about one ounce more oil. It makes changing oil very quick, clean, and a lot less expensive that going to the dealer.
Old Mar 2, 2005 | 05:38 AM
Koopah's Avatar
Koopah
There is usually a lot of debate about this. You can probably find all the arguments (pro and con) by searching other threads.
I use one on my cars and love it!
YMMV,
Theo
Old Mar 2, 2005 | 06:40 PM
ScottinBend's Avatar
ScottinBend
Me too ! ! ! !
Used one for over a year now. (total of 3 changes.......lol)
Old Mar 3, 2005 | 03:07 PM
ZenAudio's Avatar
ZenAudio
I did a search and didn't find much at all. It sounds like good clean fun so I think I'm going to get one.
Thanks,
Mike
Old Mar 3, 2005 | 03:40 PM
minimc's Avatar
minimc
I've used a topside oil changer since day one with the MINI. Purchased the compressor unit from Griots.
I had it ready and waiting the day I brought my MCS home from the dealer (27 miles on the clock). I immediately drained the nasty BLACK factory oil with it. After it appeared to have sucked up all the oil it could I pulled the drain plug - just to make sure the pan was completely drained ...I doubt a thimbleful came out in total.
Benefits of the model I have are the translucent reservoir with measure lines (you can tell precisely how much oil came out). This is quite useful in monitoring oil consumption. The other is that the whole top portion threads off - easy for cleaning & you needn't poor through a tiny spout.
First time you use it you'll need to figure out when the tube has hit the oil pan bottom, but once you've done it a few times its a no-brainer
Old Mar 3, 2005 | 04:59 PM
rg's Avatar
rg
I've been using the Griot's pump style for several years now, on several different vehicles. No problems yet! I've heard arguments against them, but none have convinced me to switch yet. The one i hear the most is that it "doesn't get out the stuff that settles to the bottom like slivers of metal, etc." The way i see it, if i've got slivers of metal in there, then i've got bigger problems to worry about!
Old Mar 6, 2005 | 06:25 PM
Electric_S's Avatar
Electric_S
i might have to get one of these too.
Old Mar 6, 2005 | 06:26 PM
Electric_S's Avatar
Electric_S
Do you have to have an air line to use that one, or does it come with its own little comressor?
Old Mar 6, 2005 | 07:34 PM
namwob's Avatar
namwob
My Mini came with a drain plug. Can you put the fresh oil back in with it also?
Old Mar 6, 2005 | 07:55 PM
minimc's Avatar
minimc
Air line neccesary.
But not with this one
Old Mar 6, 2005 | 07:58 PM
Nick_T.'s Avatar
Nick_T.
Sure - - if you roll the car over on it's top.
Old Mar 7, 2005 | 08:47 PM
Electric_S's Avatar
Electric_S
Air line neccesary.
U have a link to a site that sells that one?
Old Mar 7, 2005 | 09:00 PM
minimc's Avatar
minimc
griotsgarage.com
FYI
if you select the image & check its properties you'll see the url
Old Mar 7, 2005 | 09:46 PM
Nick_T.'s Avatar
Nick_T.
Air line neccesary.
That is the one that I have, but I can no longer find it in Griot's on-line catalog.
Old Mar 7, 2005 | 09:57 PM
minimc's Avatar
minimc
Here ya go:
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
woodstudio
Mar 15, 2020 08:28 AM
minicoclub
Aug 25, 2015 09:07 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
danraabe
Aug 18, 2015 09:32 AM
stellaherself
Aug 13, 2015 03:48 PM
