Drivetrain Cooper S Intake Icing?
Old Feb 24, 2005 | 08:06 PM
jimj's Avatar
jimj
I think I had an ice build-up in my Throttle Body this morning while
driving in Nevada through the mountains with outside temp between
25-32 degrees f. I have the Alta intake on the car and I believe
the conditions were just right with the Temp. and moisture in the air
to form ice in the throttle body from the venturi effect.
I took the car up to about 115 mph on a lonely highway
and the engine suddenly sounded like it was running on 2 cylinders with loss of power.
I backed off and it didn't get better. I stopped to checked
spark plug wires and they were fine. After a couple minutes I started
the car and it ran fine. This happened twice.
I am a pilot and remember that aircraft sometimes have
carburator icing problems. That's why they have a "Carb
Heat" lever to melt the ice, or prevent it from accumulating.
I think the Alta intake ,that uses the air from the cowl below the
windscreen, was sucking in too much cold, moist air.
Has anyone else had this happen to them??
Or if not, put this in your memory banks so your not beating you head
against the wall trying to figure out what is wrong with your car.
Old Feb 24, 2005 | 08:28 PM
nerd's Avatar
nerd
I've heard of this too. Isn't that why coolent is pasted throught the intake manifold on some cars? To keep it warm so ice doesn't form?
Brad
Old Feb 24, 2005 | 11:25 PM
jimj's Avatar
jimj
Brad
I think so. At least on cars with carburetors.
Old Feb 24, 2005 | 11:55 PM
WindMeUp's Avatar
WindMeUp
On C4 corvettes coolant is passed through the throttle body to prevent it from freezing
Old Feb 25, 2005 | 08:35 AM
gt5816v's Avatar
gt5816v
Most modern European cars pass coolant through the TB.
bobbiemartin
Jan 20, 2016 05:28 PM
MiniJess
Aug 10, 2015 09:51 PM
jrezzo
Aug 9, 2015 10:32 PM
joelcseymour
Aug 7, 2015 12:43 PM
